shiro与Spring Boot 整合
yd_249383650 发表于 2023/05/23 09:42:33 2023/05/23
【摘要】 ​ 框架整合创建模块​编辑添加依赖  <parent> <groupId>org.springframework.boot</groupId> <artifactId>spring-boot-starter-parent</artifactId> <version>2.2.1.RELEASE</version> ...
 框架整合
创建模块
​编辑
添加依赖
    <parent>
        </parent>
        <dependencies>
            <dependency>
                <groupId>org.apache.shiro</groupId>
                <artifactId>shiro-spring-boot-web-starter</artifactId>
                <version>1.9.0</version>
            </dependency>
            <!--mybatis-plus-->
            <dependency>
                <groupId>com.baomidou</groupId>
                <artifactId>mybatis-plus-boot-starter</artifactId>
                <version>3.0.5</version>
            </dependency>
            <!--mysql-->
            <dependency>
                <groupId>mysql</groupId>
                <artifactId>mysql-connector-java</artifactId>
                <version>5.1.46</version>
            </dependency>
            <dependency>
                <groupId>org.projectlombok</groupId>
                <artifactId>lombok</artifactId>
            </dependency>
            <dependency>
                <artifactId>spring-boot-starter-thymeleaf</artifactId>
            </dependency>
        </dependencies>
添加配置文件
添加配置文件 application.yml,添加基础配置
mybatis-plus:
 configuration:
     log-impl: org.apache.ibatis.logging.stdout.StdOutImpl
 mapper-locations: classpath:mapper/*.xml
spring:
 datasource:
     type: com.zaxxer.hikari.HikariDataSource
     driver-class-name: com.mysql.jdbc.Driver
     url: jdbc:mysql://localhost:3306/shirodb?characterEncoding=utf8&useSSL=false
     username: root
     password: 123123
 jackson:
     date-format: yyyy-MM-dd HH:mm:ss
     time-zone: GMT+8
shiro:
 loginUrl: /myController/login
添加启动类
​编辑
@SpringBootApplication
@MapperScan("com.atguigu.shiro.mapper")
public class ShiroApplication {
         SpringApplication.run(ShiroApplication.class, args);
 登录认证实现
访问数据库获取用户信息,实现登录认证
后端接口服务实现
(1)创建库表
CREATE DATABASE IF NOT EXISTS `shirodb` CHARACTER SET utf8mb4;
USE `shirodb`;
CREATE TABLE `user` (
 `id` BIGINT(20) NOT NULL AUTO_INCREMENT COMMENT '编号',
 `name` VARCHAR(30) DEFAULT NULL COMMENT '用户名',
 `pwd` VARCHAR(50) DEFAULT NULL COMMENT '密码',
 `rid` BIGINT(20) DEFAULT NULL COMMENT '角色编号',
 PRIMARY KEY (`id`)
) ENGINE=INNODB AUTO_INCREMENT=2 DEFAULT CHARSET=utf8 COMMENT='用户表';
(2)创建实体
​编辑
@Data
@NoArgsConstructor
@AllArgsConstructor
public class User {
 private Integer id;
 private String name;
 private String pwd;
 private Integer rid;
(3)创建 mapper
​编辑
@Repository
public interface UserMapper extends BaseMapper<User> {
(4)创建 service
创建接口
​编辑
public interface UserService {
 //用户登录
 User getUserInfoByName(String name);
创建实现类
​编辑
@Service
public class UserServiceImpl implements UserService {
 @Autowired
 private UserMapper userMapper;
 @Override
 public User getUserInfoByName(String name) {
     QueryWrapper<User> wrapper = new QueryWrapper<>();
     wrapper.eq("name",name);
     User user = userMapper.selectOne(wrapper);
     return user;
(5)自定义realm
​编辑
@Component
public class MyRealm extends AuthorizingRealm {
    @Autowired
    private UserService userService;
    //自定义授权方法
    @Override
    protected AuthorizationInfo doGetAuthorizationInfo(PrincipalCollection principalCollection) {
        return null;
    //自定义登录认证方法
    @Override
    protected AuthenticationInfo doGetAuthenticationInfo(AuthenticationToken token) throws AuthenticationException {
        //1 获取用户身份信息
        String name = token.getPrincipal().toString();
        //2 调用业务层获取用户信息(数据库中)
        User user = userService.getUserInfoByName(name);
        //3 判断并将数据完成封装
        if (user != null) {
            AuthenticationInfo info = new SimpleAuthenticationInfo(
                    token.getPrincipal(),
                    user.getPwd(),
                    ByteSource.Util.bytes("salt"),
            return info;
        return null;
 (7)实现controller
​编辑
@Controller
@RequestMapping("myController")
public class MyController {
    @GetMapping("userLogin")
    @ResponseBody
    public String userLogin(String name, String pwd) {
        //1 获取 Subject 对象
        Subject subject = SecurityUtils.getSubject();
        //2 封装请求数据到 token 对象中
        AuthenticationToken token = new
                UsernamePasswordToken(name, pwd);
        //3 调用 login 方法进行登录认证
        try {
            subject.login(token);
            return "登录成功";
        } catch (AuthenticationException e) {
            e.printStackTrace();
            System.out.println("登录失败");
            return "登录失败";
 (8)测试
* 确认数据库密码是加盐 3 次加密密码
​编辑
​编辑
*启动服务
*通过浏览器访问:http://localhost:8080/myController/userLogin?name=张三&pwd=z3
​编辑
实现前端页面
Shiro整合Thymeleaf
添加 login 页面
​编辑
<!DOCTYPE html>
<html lang="en">
<head>
 <meta charset="UTF-8">
 <title>Title</title>
</head>
<body>
 <h1>Shiro 登录认证</h1>
 <br>
 <form action="/myController/userLogin">
 <div>用户名:<input type="text" name="name" value=""></div>
 <div>密码:<input type="password" name="pwd" value=""></div>
 <div><input type="submit" value="登录"></div>
 </form>
</body>
</html>
添加 main 页面
<!DOCTYPE html>
<html lang="en" xmlns:th="http://www.thymeleaf.org">
<head>
</head>
<body>
 <h1>Shiro 登录认证后主页面</h1>
 <br>
 登录用户为:<span th:text="${session.user}"></span>
</body>
添加 controller 方法,改造认证方法
    //跳转登录页面
    @GetMapping("login")
    public String login() {
        return "login";
    //登录认证
    public String userLogin(String name, String pwd, HttpSession
            session) {
        //1 获取 Subject 对象
        AuthenticationToken token = new UsernamePasswordToken(name, pwd);
        try {
            session.setAttribute("user", token.getPrincipal().toString());
            return "main";
            return "登录失败";
修改配置文件
​编辑
配置类
​编辑
启动,访问测试
​编辑
​编辑
多个 realm 的认证策略设置
多个realm实现原理
  当应用程序配置多个 Realm 时,例如:用户名密码校验、手机号验证码校验等等。 Shiro 的 ModularRealmAuthenticator 会使用内部的 AuthenticationStrategy 组件判断认 证是成功还是失败。
  AuthenticationStrategy 是一个无状态的组件,它在身份验证尝试中被询问 4 次(这 4 次交互所需的任何必要的状态将被作为方法参数):
(1)在所有 Realm 被调用之前
(2)在调用 Realm 的 getAuthenticationInfo 方法之前
(3)在调用 Realm 的 getAuthenticationInfo 方法之后
(4)在所有 Realm 被调用之后
  认证策略的另外一项工作就是聚合所有 Realm 的结果信息封装至一个 AuthenticationInfo 实例中,并将此信息返回,以此作为 Subject 的身份信息。
Shiro 中定义了 3 种认证策略的实现:
AuthenticationStrategy class 描述
AtLeastOneSuccessfulStrategy ==》只要有一个(或更多)的 Realm 验证成功,那么认证将视为成功
FirstSuccessfulStrategy ==》第一个 Realm 验证成功,整体认证将视为成功,且后续 Realm 将被忽略
AllSuccessfulStrategy==》 所有 Realm 成功,认证才视为成功
ModularRealmAuthenticator 内置的认证策略默认实现是 AtLeastOneSuccessfulStrategy 方式。可以通过配置修改策略
多个realm代码实现
​编辑
