部署kubernetes集群 1.25.0
yd_230456711 发表于 2023/05/12 16:13:40 2023/05/12
【摘要】 aa
关闭 swap
#临时关闭
swapoff -a
#永久关闭
sed -ri 's/.*swap.*/#&/' /etc/fstab
设置主机名称,使用命令
hostnamectl set-hostname master
在
master节点中添加 hosts,即节点 IP地址+节点名称;
[root@master ~]# cat /etc/hosts
::1     localhost       localhost.localdomain   localhost6      localhost6.localdomain6
127.0.0.1       localhost       localhost.localdomain   localhost4      localhost4.localdomain4
127.0.0.1       master  master
172.16.1.150 master
将桥接的 IPv4 流量传递到 iptables 的链(所有节点都设置);
#设置
cat > /etc/sysctl.d/k8s.conf << EOF
net.bridge.bridge-nf-call-ip6tables = 1
net.bridge.bridge-nf-call-iptables = 1
EOF
#使其生效
sysctl -p
# 部署docker
yum install -y yum-utils   device-mapper-persistent-data   lvm2
# 写入docker源信息
sudo yum-config-manager \
    --add-repo \
    https://mirrors.tuna.tsinghua.edu.cn/docker-ce/linux/centos/docker-ce.repo
# 更新源信息并进行安装
yum update
yum install docker-ce docker-ce-cli containerd.io
# 配置加速器
sudo mkdir -p /etc/docker
sudo tee /etc/docker/daemon.json <<-'EOF'
  "registry-mirrors": ["https://ted9wxpi.mirror.aliyuncs.com"],
  "exec-opts": ["native.cgroupdriver=systemd"]
EOF
sudo systemctl daemon-reload
sudo systemctl restart docker
# 安装cri-docker
# 由于1.24以及更高版本不支持docker所以安装cri-docker
# 下载cri-docker
wget  https://ghproxy.com/https://github.com/Mirantis/cri-dockerd/releases/download/v0.2.5/cri-dockerd-0.2.5.amd64.tgz
# 解压cri-docker
tar xvf cri-dockerd-0.2.5.amd64.tgz
cp cri-dockerd/cri-dockerd  /usr/bin/
# 写入启动配置文件
cat >  /usr/lib/systemd/system/cri-docker.service <<EOF
[Unit]
Description=CRI Interface for Docker Application Container Engine
Documentation=https://docs.mirantis.com
After=network-online.target firewalld.service docker.service
Wants=network-online.target
Requires=cri-docker.socket
[Service]
Type=notify
ExecStart=/usr/bin/cri-dockerd --network-plugin=cni --pod-infra-container-image=registry.aliyuncs.com/google_containers/pause:3.7
ExecReload=/bin/kill -s HUP $MAINPID
TimeoutSec=0
RestartSec=2
Restart=always
StartLimitBurst=3
StartLimitInterval=60s
LimitNOFILE=infinity
LimitNPROC=infinity
LimitCORE=infinity
TasksMax=infinity
Delegate=yes
KillMode=process
[Install]
WantedBy=multi-user.target
EOF
# 写入socket配置文件
cat > /usr/lib/systemd/system/cri-docker.socket <<EOF
[Unit]
Description=CRI Docker Socket for the API
PartOf=cri-docker.service
[Socket]
ListenStream=%t/cri-dockerd.sock
SocketMode=0660
SocketUser=root
SocketGroup=docker
[Install]
WantedBy=sockets.target
EOF
# 进行启动cri-docker
systemctl daemon-reload ; systemctl enable cri-docker --now
# 安装 kubelet
版本 1.25.0
添加阿里云 yum 源
此步骤是为了便于今后的下载,在每个节点中执行以下配置;
cat > /etc/yum.repos.d/kubernetes.repo << EOF
[Kubernetes]
name=kubernetes
baseurl=https://mirrors.aliyun.com/kubernetes/yum/repos/kubernetes-el7-x86_64
enabled=1
gpgcheck=0
repo_gpgcheck=0
gpgkey=https://mirrors.aliyun.com/kubernetes/yum/doc/yum-key.gpg
https://mirrors.aliyun.com/kubernetes/yum/doc/rpm-package-key.gpg
EOF
# kubeadm、kubelet、kubectl 的安装
此处指定版本为 1.25.0,如果不指定默认下载最新版本。
#下载软件
yum install -y kubelet-1.25.0 kubeadm-1.25.0 kubectl-1.25.0
#开机自启动
systemctl enable kubelet
# 初始化集群 --apiserver-advertise-address= 自己私网ip
kubeadm init --apiserver-advertise-address=172.16.1.214  --image-repository registry.aliyuncs.com/google_containers --kubernetes-version v1.25.0 --service-cidr=10.96.0.0/12 --pod-network-cidr=10.244.0.0/16 --ignore-preflight-errors=all --cri-socket /var/run/cri-dockerd.sock
# 添加集群配置文件
mkdir -p $HOME/.kube
sudo cp -i /etc/kubernetes/admin.conf $HOME/.kube/config
sudo chown $(id -u):$(id -g) $HOME/.kube/config
# 配置kubernetes 网络插件 flanner
kubectl apply -f https://raw.githubusercontent.com/coreos/flannel/master/Documentation/kube-flannel.yml
