OpenStack超级架构-1OpenStack部分
小源博客 发表于 2023/04/11 11:53:47 2023/04/11
【摘要】 OpenStack部分主机规划主机名IPcq-kz-h-controller1-0-10.ang.local192.168.0.10cq-kz-h-controller2-0-11.ang.local192.168.0.20cq-kz-h-lvsvip1-0-12.ang.local192.168.0.30cq-kz-h-lvsvip2-0-13.ang.local192.168.0.40c...
OpenStack部分
主机规划
主机名 IP
cq-kz-h-controller1-0-10.ang.local 192.168.0.10
cq-kz-h-controller2-0-11.ang.local 192.168.0.20
cq-kz-h-lvsvip1-0-12.ang.local 192.168.0.30
cq-kz-h-lvsvip2-0-13.ang.local 192.168.0.40
cq-kz-h-compute1-0-14.ang.local 192.168.0.50
cq-kz-h-compute2-0-15.ang.local 192.168.0.60
更改主机名与关闭防火墙
  • 更改主机名
地区----机房简称----虚拟机(h)/物理机(v)----业务名称---ip地址---域名后缀
例子:cq-kz-v-taobao-lvs-0-100.xier.local
hostnamectl set-hostname cq-kz-h-template-0-5.xier.local
  • 关闭防火墙与selinux
sed -i 's/SELINUX=enforcing/SELINUX=disabled/g' /etc/selinux/config; systemctl stop firewalld; systemctl disable firewalld;setenforce 0
配置免密
sshpass  -p000000 ssh-copy-id -i /root/.ssh/id_rsa.pub root@192.168.20.20 "-o StrictHostKeyChecking=no"
安装基本工具
yum install  vim iotop bc gcc gcc-c++ glibc glibc-devel pcre pcre-devel openssl  openssl-devel zip unzip zlib-devel  net-tools lrzsz tree  telnet lsof tcpdump wget libevent libevent-devel bc  systemd-devel bash-completion traceroute bridge-utils  -y
配置hosts解析
cat /etc/hosts
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6
192.168.0.10 cq-kz-h-controller1-0-10.xier.local cq-kz-h-controller1-0-10
192.168.0.20 cq-kz-h-controller2-0-20.xier.local cq-kz-h-controller2-0-20
192.168.0.50 cq-kz-h-lvs1-0-50.xier.local cq-kz-h-lvs1-0-50
192.168.0.60 cq-kz-h-lvs2-0-60.xier.local cq-kz-h-lvs2-0-60
192.168.0.30 cq-kz-h-compute1-0-30.xier.local cq-kz-h-compute1-0-30
192.168.0.40 cq-kz-h-compute2-0-40.xier.local cq-kz-h-compute2-0-40
192.168.0.100 openstack-vip.ang.local
配置时间服务器
  • controller1节点
dnf install -y chrony
vi /etc/chrony.conf
server ntp6.aliyun.com iburst
allow all
local stratum 10
systemctl restart chronyd
clock -w
  • 其它所有节点
vi /etc/chrony.conf
server 192.168.0.10 iburst
clock -w
controller所有节点MySQL主主架构
wget https://downloads.mysql.com/archives/get/p/23/file/mysql-5.7.26-linux-glibc2.12-x86_64.tar.gz
tar xf mysql-5.7.26-linux-glibc2.12-x86_64.tar.gz
useradd -s /sbin/nologin mysql
mkdir /application/mysql -pv
mkdir /data/mysql/data -pv
mkdir /data/mysql/binlog -pv
echo  "PATH=/application/mysql/bin:$PATH" > /etc/profile.d/mysql.sh
source  /etc/profile.d/mysql.sh
mv mysql-5.7.26-linux-glibc2.12-x86_64/* /application/mysql/
mysqld --initialize-insecure  --user=mysql --basedir=/application/mysql --datadir=/data/mysql/data
vim  /etc/my.cnf
[mysqld]
user=mysql
socket=/tmp/mysql.sock
server_id=6    # data2设置为8,不一样即可
port=3306
log_bin=/data/mysql/binlog/mysql-bin
character_set_server=utf8
[mysql]
chown -R mysql.mysql /data/
cp /application/mysql/support-files/mysql.server /etc/init.d/mysqld
service mysqld start
yum install libncurses* -y
mysql
grant replication slave on *.* to repl@'%' identified by '123';
  • controller1与controller2节点互相操作
mysql> show master status;
| File             | Position | Binlog_Do_DB | Binlog_Ignore_DB | Executed_Gtid_Set |
| mysql-bin.000001 |      437 |              |                  |                   |
help change master to;
CHANGE MASTER TO
MASTER_HOST='10.0.0.17',    # 注意对方之间的值
MASTER_USER='repl',
MASTER_PASSWORD='123',
MASTER_PORT=3306,
MASTER_LOG_FILE='mysql-bin.000002',
MASTER_LOG_POS=154;
部署rabbitmq与memcached
  • controller所有节点
dnf install -y centos-release-openstack-victoria
[root@localhost yum.repos.d]# sed -i -e "s|mirrorlist=|#mirrorlist=|g" -e "s|#baseurl=http://mirror.centos.org|baseurl=http://vault.centos.org|g" -e 's|http://vault.centos.org/[^/]*/[^/]*/|https://mirrors.aliyun.com/centos-vault/8.5.2111/|g' /etc/yum.repos.d/*
  • 由于源的问题,使用华为源即可解决不能安装rabbitmq问题
dnf install wget -y
wget -O /etc/yum.repos.d/CentOS-Base.repo https://repo.huaweicloud.cn/repository/conf/CentOS-8-reg.repo
dnf install -y rabbitmq-server memcached
systemctl enable --now rabbitmq-server
  • controller1
scp /var/lib/rabbitmq/.erlang.cookie root@192.168.0.20:/var/lib/rabbitmq/.erlang.cookie
  • controller2
systemctl restart rabbitmq-server
rabbitmq-plugins enable rabbitmq_management
  • controller2
# 1.停止服务
rabbitmqctl stop_app
# 2.重置状态
rabbitmqctl reset
# 3.节点加入
rabbitmqctl join_cluster rabbit@gz-zy-h-data1-0-16
# 4.重启服务
rabbitmqctl start_app
接触集群
# 1.停止服务
# 2.重置集群状态
rabbitmqctl reset
# 3.重启服务
vim /etc/sysconfig/memcached
PORT="11211"
USER="memcached"
MAXCONN="2048"
CACHESIZE="1024"
OPTIONS="-l 0.0.0.0,::1"
systemctl enable --now memcached
  • controller1
rabbitmqctl add_user openstack openstack123
rabbitmqctl set_permissions openstack ".*" ".*" ".*"
lvsvip所有节点代理
配置邮件报警
dnf install -y ipvsadm keepalived
vim  /etc/keepalived/keepalived.conf
! Configuration File for keepalived
global_defs {
 notification_email {
   acassen@firewall.loc
   failover@firewall.loc
   sysadmin@firewall.loc
 notification_email_from Alexandre.Cassen@firewall.loc
 smtp_server 127.0.0.1
 smtp_connect_timeout 30
 router_id cq-kz-h-lvsvip2-0-60.ang.local    # 这里更改为自己的主机名
 vrrp_skip_check_adv_addr
 vrrp_strict
 vrrp_garp_interval 0
 vrrp_gna_interval 0
include /etc/keepalived/conf.d/*.conf
mkdir /etc/keepalived/conf.d/
vim /etc/keepalived/conf.d/mail.conf
vrrp_instance mail {
state BACKUP
interface ens33
virtual_router_id 66
priority 100          # lvsvip2设置为80
advert_int 1
nopreempt
virtual_ipaddress {
  192.168.0.100/24 dev ens33 label ens33:1
notify_master "/etc/keepalived/notify.sh master"
notify_backup "/etc/keepalived/notify.sh backup"
notify_fault "/etc/keepalived/notify.sh fault"
vim /etc/keepalived/notify.sh
#!/bin/bash
contact='2443599212@qq.com'
notify() {
mailsubject="$(hostname) to be $1, vip floating"    # 发送标题
mailbody="$(date +'%F %T'): vrrp transition, $(hostname) changed to be $1"   # 发送内容
echo "$mailbody" | mail -s "$mailsubject" $contact
case $1 in
master)
notify master
backup)
notify backup
fault)
notify fault
echo "Usage: $(basename $0) {master|backup|fault}"
exit 1
esac
chmod +x /etc/keepalived/notify.sh
dnf install -y mailx
vim /etc/mail.rc
set from=2443599212@qq.com
set smtp=smtp.qq.com
set smtp-auth-user=2443599212@qq.com
set smtp-auth-password=rqqwhmnmumasebhe
systemctl restart keepalived
配置lvs高可用并代理MySQL
  • controller1与controller2节点配置lvs环境
vim /root/lvs-dr-rs.sh
#!/bin/bash
# LVS DR默认初始化脚本
LVS_VIP=10.0.0.100/32
DEV=lo:1
# source /etc/rc.d/init.d/functions
case "$1" in
start)
/sbin/ifconfig lo:0 $LVS_VIP netmask 255.255.255.255 # broadcast $LVS_VIP
# /sbin/route add -host $LVS_VIP dev lo:0
echo 1 > /proc/sys/net/ipv4/conf/all/arp_ignore
echo 1 > /proc/sys/net/ipv4/conf/lo/arp_ignore
echo 2 > /proc/sys/net/ipv4/conf/all/arp_announce
echo 2 > /proc/sys/net/ipv4/conf/lo/arp_announce
sysctl -p > /dev/null 2>&1
echo "RealServer RS Start OK"
stop)
/sbin/ifconfig lo:0 down
# /sbin/route del $LVS_VIP > /dev/null 2>&1
echo 0 > /proc/sys/net/ipv4/conf/all/arp_ignore
echo 0 > /proc/sys/net/ipv4/conf/lo/arp_ignore
echo 0 > /proc/sys/net/ipv4/conf/all/arp_announce
echo 0 > /proc/sys/net/ipv4/conf/lo/arp_announce
echo "RealServer RS Stoped"
echo "Usage: $0 {start|stop}"
exit 1
esac
exit 0
# 启动脚本
bash lvs-dr-rs.sh start
  • lvsvip1与lvsvip2配置代理MySQL
# 需要一个传输层做铺垫
vim /etc/keepalived/conf.d/http.conf
virtual_server 10.0.0.100 80 {
 delay_loop 6
 lb_algo wrr
 lb_kind DR
 protocol TCP
 sorry_server 127.0.0.1 80
 real_server 10.0.0.10 80 {
     weight 100
     TCP_CHECK {
         connect_timeout 5
         nb_get_retry 3
         delay_before_retry 3
         connect_port 80
 real_server 10.0.0.11 80 {
     weight 1
     TCP_CHECK {
         connect_timeout 5
         nb_get_retry 3
         connect_port 80
vim /etc/keepalived/conf.d/mysql.conf
virtual_server 10.0.0.100 3306 {
  delay_loop 3
  lb_algo wrr
  lb_kind DR
  protocol TCP
  real_server 10.0.0.10 3306 {
      weight 10
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
      delay_before_retry 1
  real_server 10.0.0.11 3306 {
      weight 1
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
  • lvsvip1与lvsvip2配置代理rabbitmq
cd /etc/keepalived/conf.d
vim rabbitmq.conf
virtual_server 10.0.0.100 5672 {
  delay_loop 3
  lb_algo wrr
  lb_kind DR
  protocol TCP
  real_server 10.0.0.10 5672 {
      weight 10
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
  real_server 10.0.0.11 5672 {
      weight 1
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
# web
vim rabbitmq_dashboard.conf
virtual_server 10.0.0.100 15672 {
  delay_loop 3
  lb_algo wrr
  lb_kind DR
  protocol TCP
  real_server 10.0.0.10 15672 {
      weight 10
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
  real_server 10.0.0.11 15672 {
      weight 1
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
  • lvsvip1与lvsvip2配置代理memcache
cp rabbitmq.conf memcache.conf
vim memcache.conf
virtual_server 10.0.0.100 11211 {
  delay_loop 3
  lb_algo wrr
  lb_kind DR
  protocol TCP
  real_server 10.0.0.10 11211 {
      weight 10
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
  real_server 10.0.0.11 11211 {
      weight 1
      HTTP_GET {
      connect_timeout 1
      nb_get_retry 3
部署keystone(controller1)
  • controller1创库授权
mysql
CREATE DATABASE keystone;
GRANT ALL PRIVILEGES ON keystone.* TO 'keystone'@'%' IDENTIFIED BY 'keystone123';
  • controller1安装openstack相关软件
dnf install -y python3-openstackclient openstack-selinux crudini
dnf install openstack-keystone httpd python3-mod_wsgi python3-PyMySQL python3-memcached -y
  • 编辑配置文件
cp /etc/keystone/keystone.conf{,.bak}
grep -Ev '^$|#' /etc/keystone/keystone.conf.bak > /etc/keystone/keystone.conf
crudini --set /etc/keystone/keystone.conf database connection mysql+pymysql://keystone:keystone123@openstack-vip.xier.local/keystone
crudini --set /etc/keystone/keystone.conf token provider fernet
  • 同步数据库
su -s /bin/sh -c "keystone-manage db_sync" keystone
# 检查
mysql -ukeystone -pkeystone123 -e "use keystone; show tables"
  • 初始化 Fernet 密钥存储库
keystone-manage fernet_setup --keystone-user keystone --keystone-group keystone
keystone-manage credential_setup --keystone-user keystone --keystone-group keystone
  • 初始化keystone
keystone-manage bootstrap --bootstrap-password admin \
--bootstrap-admin-url http://openstack-vip.xier.local:5000/v3/ \
--bootstrap-internal-url http://openstack-vip.xier.local:5000/v3/ \
--bootstrap-public-url http://openstack-vip.xier.local:5000/v3/ \
--bootstrap-region-id RegionOne
  • 配置apache HTTP服务
vim /etc/httpd/conf/httpd.conf
ServerName 192.168.0.10
  • 创库软链接
ln -s /usr/share/keystone/wsgi-keystone.conf /etc/httpd/conf.d/
  • 启动服务
systemctl enable --now httpd.service
  • 创建生成环境变量
cat > /etc/keystone/admin-openrc << EOF
export OS_PROJECT_DOMAIN_NAME=Default
export OS_USER_DOMAIN_NAME=Default
export OS_PROJECT_NAME=admin
export OS_USERNAME=admin
export OS_PASSWORD=admin
export OS_AUTH_URL=http://openstack-vip.xier.local:5000/v3
export OS_IDENTITY_API_VERSION=3
export OS_IMAGE_API_VERSION=2
EOF
配置keystone的lvs规则代理并验证
  • lvsvip1
cp mysql.conf keystone.conf
sed  -i "s/3306/5000/g" keystone.conf
systemctl reload keepalived
  • 创建域、项目
openstack domain create --description "An Example Domain" example
openstack project create --domain default   --description "Service Project" service
  • controller1验证
unset OS_AUTH_URL OS_PASSWORD
# 输入密码admin
openstack --os-auth-url http://openstack-vip.xier.local:5000/v3 \
--os-project-domain-name Default --os-user-domain-name Default \
--os-project-name admin --os-username admin token issue
部署glance
  • 创库授权
mysql
CREATE DATABASE glance;
GRANT ALL PRIVILEGES ON glance.* TO 'glance'@'%' IDENTIFIED BY 'glance123';
  • 创建用户、角色、glance实体、镜像API
openstack user create --domain default --password glance glance
openstack role add --project service --user glance admin
openstack service create --name glance --description "OpenStack Image" image
openstack endpoint create --region RegionOne image public http://openstack-vip.xier.local:9292
openstack endpoint create --region RegionOne image internal http://openstack-vip.xier.local:9292
openstack endpoint create --region RegionOne image admin http://openstack-vip.xier.local:9292
  • 安装相关软件包
dnf install openstack-glance -y
  • 编辑配置文件
cp /etc/glance/glance-api.conf{,.bak}
grep -Ev '^$|#' /etc/glance/glance-api.conf.bak > /etc/glance/glance-api.conf
crudini --set /etc/glance/glance-api.conf database connection mysql+pymysql://glance:glance123@openstack-vip.xier.local/glance
crudini --set /etc/glance/glance-api.conf keystone_authtoken www_authenticate_uri  http://openstack-vip.xier.local:5000
crudini --set /etc/glance/glance-api.conf keystone_authtoken auth_url http://openstack-vip.xier.local:5000
crudini --set /etc/glance/glance-api.conf keystone_authtoken auth_type password
crudini --set /etc/glance/glance-api.conf keystone_authtoken project_domain_name Default
crudini --set /etc/glance/glance-api.conf keystone_authtoken user_domain_name Default
crudini --set /etc/glance/glance-api.conf keystone_authtoken project_name service
crudini --set /etc/glance/glance-api.conf keystone_authtoken username glance
crudini --set /etc/glance/glance-api.conf keystone_authtoken password glance
crudini --set /etc/glance/glance-api.conf paste_deploy flavor keystone
crudini --set /etc/glance/glance-api.conf glance_store stores file,http
crudini --set /etc/glance/glance-api.conf glance_store default_store file
crudini --set /etc/glance/glance-api.conf glance_store filesystem_store_datadir /var/lib/glance/images/
  • 同步数据库
su -s /bin/sh -c "glance-manage db_sync" glance
  • 启动服务
systemctl enable --now openstack-glance-api.service
配置glance的lvs规则代理并验证
  • lvsvip1
cp mysql.conf glance.conf
sed -i "s/3306/9292/g" glance.conf
  • controller1验证
wget http://download.cirros-cloud.net/0.4.0/cirros-0.4.0-x86_64-disk.img
glance image-create --name "cirros"   --file cirros-0.4.0-x86_64-disk.img   --disk-format qcow2 --container-format bare   --visibility=public
openstack image list
部署placement
  • 创库授权
mysql
CREATE DATABASE placement;
GRANT ALL PRIVILEGES ON placement.* TO 'placement'@'%' IDENTIFIED BY 'placement123';
  • 创建用户、角色、API
openstack user create --domain default --password placement placement
openstack role add --project service --user placement admin
openstack service create --name placement --description "Placement API" placement
openstack endpoint create --region RegionOne placement public http://openstack-vip.xier.local:8778
openstack endpoint create --region RegionOne placement internal http://openstack-vip.xier.local:8778
openstack endpoint create --region RegionOne placement admin http://openstack-vip.xier.local:8778
  • 安装软件包
yum install openstack-placement-api -y
  • 编辑配置文件
cp /etc/placement/placement.conf{,.bak}
grep -Ev "^$|#" /etc/placement/placement.conf.bak > /etc/placement/placement.conf
crudini --set /etc/placement/placement.conf placement_database connection mysql+pymysql://placement:placement123@openstack-vip.xier.local/placement
crudini --set /etc/placement/placement.conf api auth_strategy keystone
crudini --set /etc/placement/placement.conf keystone_authtoken memcached_servers openstack-vip.xier.local:11211
crudini --set /etc/placement/placement.conf keystone_authtoken auth_url http://openstack-vip.xier.local:5000/v3
crudini --set /etc/placement/placement.conf keystone_authtoken auth_type  password
crudini --set /etc/placement/placement.conf keystone_authtoken project_domain_name Default
crudini --set /etc/placement/placement.conf keystone_authtoken user_domain_name Default
crudini --set /etc/placement/placement.conf keystone_authtoken project_name service
crudini --set /etc/placement/placement.conf keystone_authtoken username placement
crudini --set /etc/placement/placement.conf keystone_authtoken password placement
cat >> /etc/httpd/conf.d/00-placement-api.conf << EOF
<Directory /usr/bin>
 <IfVersion >= 2.4>
    Require all granted
 </IfVersion>
 <IfVersion < 2.4>
    Order allow,deny
    Allow from all
 </IfVersion>
</Directory>
EOF
  • 同步数据库
su -s /bin/sh -c "placement-manage db sync" placement
  • 启动服务
systemctl restart httpd
配置placement的lvs规则代理并验证
  • lvsvip1
cp /etc/keepalived/conf.d/mysql.conf /etc/keepalived/conf.d/placement.conf
sed -i "s/3306/8778/g" /etc/keepalived/conf.d/placement.conf
  • controller1验证
placement-status upgrade check
部署nova
controller1节点
  • 创库授权
CREATE DATABASE nova_api;
CREATE DATABASE nova;
CREATE DATABASE nova_cell0;
GRANT ALL PRIVILEGES ON nova_api.* TO 'nova'@'%' IDENTIFIED BY 'nova123';
GRANT ALL PRIVILEGES ON nova.* TO 'nova'@'%' IDENTIFIED BY 'nova123';
GRANT ALL PRIVILEGES ON nova_cell0.* TO 'nova'@'%' IDENTIFIED BY 'nova123';
  • 创建nova服务凭证
openstack user create --domain default --password nova nova
openstack role add --project service --user nova admin
openstack service create --name nova --description "OpenStack Compute" compute
openstack endpoint create --region RegionOne compute public http://openstack-vip.xier.local:8774/v2.1
openstack endpoint create --region RegionOne compute internal http://openstack-vip.xier.local:8774/v2.1
openstack endpoint create --region RegionOne compute admin http://openstack-vip.xier.local:8774/v2.1
  • 安装软件包
dnf install -y openstack-nova-api openstack-nova-conductor openstack-nova-novncproxy openstack-nova-scheduler
  • 编辑配置文件
cp /etc/nova/nova.conf{,.bak}
grep -Ev "^$|#" /etc/nova/nova.conf.bak > /etc/nova/nova.conf
crudini --set /etc/nova/nova.conf DEFAULT enabled_apis osapi_compute,metadata
crudini --set /etc/nova/nova.conf api_database connection  mysql+pymysql://nova:nova123@openstack-vip.xier.local/nova_api
crudini --set /etc/nova/nova.conf database connection mysql+pymysql://nova:nova123@openstack-vip.xier.local/nova
crudini --set /etc/nova/nova.conf DEFAULT transport_url rabbit://openstack:openstack123@openstack-vip.xier.local:5672/
crudini --set /etc/nova/nova.conf api auth_strategy keystone
crudini --set /etc/nova/nova.conf keystone_authtoken www_authenticate_uri http://openstack-vip.xier.local:5000/
crudini --set /etc/nova/nova.conf keystone_authtoken auth_url http://openstack-vip.xier.local:5000/
crudini --set /etc/nova/nova.conf keystone_authtoken memcached_servers openstack-vip.xier.local:11211
crudini --set /etc/nova/nova.conf keystone_authtoken auth_type password
crudini --set /etc/nova/nova.conf keystone_authtoken project_domain_name Default
crudini --set /etc/nova/nova.conf keystone_authtoken user_domain_name Default
crudini --set /etc/nova/nova.conf keystone_authtoken project_name service
crudini --set /etc/nova/nova.conf keystone_authtoken username nova
crudini --set /etc/nova/nova.conf keystone_authtoken password nova
crudini --set /etc/nova/nova.conf DEFAULT my_ip 10.0.0.10
crudini --set /etc/nova/nova.conf vnc enabled true
crudini --set /etc/nova/nova.conf vnc server_listen '$my_ip'
crudini --set /etc/nova/nova.conf vnc server_proxyclient_address '$my_ip'
crudini --set /etc/nova/nova.conf glance api_servers http://openstack-vip.xier.local:9292
crudini --set /etc/nova/nova.conf oslo_concurrency lock_path /var/lib/nova/tmp
crudini --set /etc/nova/nova.conf placement region_name RegionOne
crudini --set /etc/nova/nova.conf placement project_domain_name Default
crudini --set /etc/nova/nova.conf placement project_name service
crudini --set /etc/nova/nova.conf placement auth_type password
crudini --set /etc/nova/nova.conf placement user_domain_name Default
crudini --set /etc/nova/nova.conf placement auth_url http://openstack-vip.xier.local:5000/v3
crudini --set /etc/nova/nova.conf placement username placement
crudini --set /etc/nova/nova.conf placement password placement
  • 同步数据库
su -s /bin/sh -c "nova-manage api_db sync" nova
su -s /bin/sh -c "nova-manage cell_v2 map_cell0" nova
su -s /bin/sh -c "nova-manage cell_v2 create_cell --name=cell1 --verbose" nova
su -s /bin/sh -c "nova-manage db sync" nova
# 验证
su -s /bin/sh -c "nova-manage cell_v2 list_cells" nova
  • 启动服务
systemctl enable --now openstack-nova-api.service openstack-nova-scheduler.service openstack-nova-conductor.service openstack-nova-novncproxy.service
配置nova的lvs规则代理并验证
  • lvsvip1
cp /etc/keepalived/conf.d/mysql.conf /etc/keepalived/conf.d/vnc.conf
sed -i "s/3306/6080/g" /etc/keepalived/conf.d/vnc.conf
cp /etc/keepalived/conf.d/mysql.conf /etc/keepalived/conf.d/nova.conf
sed -i "s/3306/8774/g" /etc/keepalived/conf.d/nova.conf
compute1节点
  • 安装软件包
dnf install -y crudini wget
dnf install -y openstack-nova-compute
  • 编辑配置文件
crudini --set /etc/nova/nova.conf DEFAULT my_ip 10.0.0.14
crudini --set /etc/nova/nova.conf vnc server_listen 0.0.0.0
crudini --set /etc/nova/nova.conf vnc novncproxy_base_url http://openstack-vip.xier.local:6080/vnc_auto.html
  • 启动服务
systemctl enable --now libvirtd.service openstack-nova-compute.service
尝试使用应用层
controller1主机发现
  • 配置主机发现
openstack compute service list --service nova-compute
su -s /bin/sh -c "nova-manage cell_v2 discover_hosts --verbose" nova
crudini --set /etc/nova/nova.conf scheduler discover_hosts_in_cells_interval 300
systemctl restart openstack-nova-api.service openstack-nova-scheduler.service openstack-nova-conductor.service openstack-nova-novncproxy.service
部署neutron
  • 创库授权
CREATE DATABASE neutron;
GRANT ALL PRIVILEGES ON neutron.* TO 'neutron'@'%' IDENTIFIED BY 'neutron123';
  • 创建用户、角色、API
openstack user create --domain default --password neutron neutron
openstack role add --project service --user neutron admin
openstack service create --name neutron --description "OpenStack Networking" network
openstack endpoint create --region RegionOne network public http://openstack-vip.xier.local:9696
openstack endpoint create --region RegionOne network internal http://openstack-vip.xier.local:9696
openstack endpoint create --region RegionOne network admin http://openstack-vip.xier.local:9696
  • 安装软件
dnf install -y openstack-neutron openstack-neutron-ml2 openstack-neutron-linuxbridge ebtables
  • 编辑配置文件
cp /etc/neutron/neutron.conf{,.bak}
grep -Ev "^$|#" /etc/neutron/neutron.conf.bak > /etc/neutron/neutron.conf
crudini --set /etc/neutron/neutron.conf database connection mysql+pymysql://neutron:neutron123@openstack-vip.xier.local/neutron
crudini --set /etc/neutron/neutron.conf DEFAULT core_plugin ml2
crudini --set /etc/neutron/neutron.conf DEFAULT service_plugins router
crudini --set /etc/neutron/neutron.conf DEFAULT allow_overlapping_ips true
crudini --set /etc/neutron/neutron.conf DEFAULT transport_url rabbit://openstack:openstack123@openstack-vip.xier.local
crudini --set /etc/neutron/neutron.conf DEFAULT auth_strategy keystone
crudini --set /etc/neutron/neutron.conf keystone_authtoken www_authenticate_uri http://openstack-vip.xier.local:5000
crudini --set /etc/neutron/neutron.conf keystone_authtoken auth_url http://openstack-vip.xier.local:5000
crudini --set /etc/neutron/neutron.conf keystone_authtoken memcached_servers openstack-vip.xier.local:11211
crudini --set /etc/neutron/neutron.conf keystone_authtoken auth_type password
crudini --set /etc/neutron/neutron.conf keystone_authtoken project_domain_name default
crudini --set /etc/neutron/neutron.conf keystone_authtoken user_domain_name default
crudini --set /etc/neutron/neutron.conf keystone_authtoken project_name service
crudini --set /etc/neutron/neutron.conf keystone_authtoken username neutron
crudini --set /etc/neutron/neutron.conf keystone_authtoken password neutron
crudini --set /etc/neutron/neutron.conf DEFAULT notify_nova_on_port_status_changes true
crudini --set /etc/neutron/neutron.conf DEFAULT notify_nova_on_port_data_changes true
crudini --set /etc/neutron/neutron.conf nova auth_url http://openstack-vip.xier.local:5000
crudini --set /etc/neutron/neutron.conf nova auth_type password
crudini --set /etc/neutron/neutron.conf nova project_domain_name default
crudini --set /etc/neutron/neutron.conf nova user_domain_name default
crudini --set /etc/neutron/neutron.conf nova region_name RegionOne
crudini --set /etc/neutron/neutron.conf nova project_name service
crudini --set /etc/neutron/neutron.conf nova username nova
crudini --set /etc/neutron/neutron.conf nova password nova
crudini --set /etc/neutron/neutron.conf oslo_concurrency lock_path  /var/lib/neutron/tmp
cp /etc/neutron/plugins/ml2/ml2_conf.ini{,.bak}
grep -Ev "^$|#" /etc/neutron/plugins/ml2/ml2_conf.ini.bak > /etc/neutron/plugins/ml2/ml2_conf.ini
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini ml2 type_drivers flat,vlan,vxlan
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini ml2 tenant_network_types vxlan
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini ml2 mechanism_drivers linuxbridge,l2population
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini ml2 extension_drivers port_security
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini ml2_type_flat flat_networks extnet
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini ml2_type_vxlan vni_ranges 1:1000
crudini --set /etc/neutron/plugins/ml2/ml2_conf.ini securitygroup enable_ipset true
cp /etc/neutron/plugins/ml2/linuxbridge_agent.ini{,.bak}
grep -Ev "^$|#" /etc/neutron/plugins/ml2/linuxbridge_agent.ini.bak > /etc/neutron/plugins/ml2/linuxbridge_agent.ini
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini linux_bridge physical_interface_mappings extnet:eth0
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini vxlan enable_vxlan true
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini vxlan local_ip 10.0.0.10
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini vxlan l2_population true
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini securitygroup enable_security_group true
cat >> /etc/sysctl.conf << EOF
net.bridge.bridge-nf-call-iptables = 1
net.bridge.bridge-nf-call-ip6tables = 1
EOF
modprobe br_netfilter
sysctl -p
cp /etc/neutron/l3_agent.ini{,.bak}
grep -Ev "^$|#" /etc/neutron/l3_agent.ini.bak > /etc/neutron/l3_agent.ini
crudini --set /etc/neutron/l3_agent.ini DEFAULT interface_driver linuxbridge
cp /etc/neutron/dhcp_agent.ini{,.bak}
grep -Ev "^$|#" /etc/neutron/dhcp_agent.ini.bak > /etc/neutron/dhcp_agent.ini
crudini --set /etc/neutron/dhcp_agent.ini DEFAULT interface_driver linuxbridge
crudini --set /etc/neutron/dhcp_agent.ini DEFAULT dhcp_driver neutron.agent.linux.dhcp.Dnsmasq
crudini --set /etc/neutron/dhcp_agent.ini DEFAULT enable_isolated_metadata true
cp /etc/neutron/metadata_agent.ini{,.bak}
grep -Ev "^$|#" /etc/neutron/metadata_agent.ini.bak > /etc/neutron/metadata_agent.ini
crudini --set /etc/neutron/metadata_agent.ini DEFAULT nova_metadata_host 10.0.0.10
crudini --set /etc/neutron/metadata_agent.ini DEFAULT metadata_proxy_shared_secret ang
crudini --set /etc/nova/nova.conf  neutron auth_url http://openstack-vip.xier.local:5000
crudini --set /etc/nova/nova.conf  neutron auth_type password
crudini --set /etc/nova/nova.conf  neutron project_domain_name default
crudini --set /etc/nova/nova.conf  neutron user_domain_name default
crudini --set /etc/nova/nova.conf  neutron region_name RegionOne
crudini --set /etc/nova/nova.conf  neutron project_name service
crudini --set /etc/nova/nova.conf  neutron username neutron
crudini --set /etc/nova/nova.conf  neutron password neutron
crudini --set /etc/nova/nova.conf  neutron service_metadata_proxy true
crudini --set /etc/nova/nova.conf  neutron metadata_proxy_shared_secret ang
ln -s /etc/neutron/plugins/ml2/ml2_conf.ini /etc/neutron/plugin.ini
  • 同步数据库
su -s /bin/sh -c "neutron-db-manage --config-file /etc/neutron/neutron.conf --config-file /etc/neutron/plugins/ml2/ml2_conf.ini upgrade head" neutron
  • 启动重启相关服务
systemctl enable --now neutron-server.service neutron-linuxbridge-agent.service neutron-dhcp-agent.service neutron-metadata-agent.service neutron-l3-agent.service
配置neutron的lvs规则代理
  • lvsvip1
cp /etc/keepalived/conf.d/mysql.conf /etc/keepalived/conf.d/neutron.conf
sed -i "s/3306/9696/g" /etc/keepalived/conf.d/neutron.conf
compute1节点部署neutron
  • compute1安装软件
yum install openstack-neutron-linuxbridge ebtables ipset -y
  • 配置文件
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini linux_bridge physical_interface_mappings extner:eth0
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini vxlan local_ip 10.0.0.14
crudini --set /etc/neutron/plugins/ml2/linuxbridge_agent.ini securitygroup firewall_driver neutron.agent.linux.iptables_firewall.IptablesFirewallDriver
EOF
sysctl -p
  • 重启启动相关服务
systemctl restart openstack-nova-compute.service
systemctl enable --now neutron-linuxbridge-agent.service
验证
openstack network agent list
部署dashboard
  • 安装软件
yum install openstack-dashboard -y
  • 配置文件
vim /etc/openstack-dashboard/local_settings
# -*- coding: utf-8 -*-
# NOTE: The default values of the settings are defined in
# openstack_dashboard/defaults.py. Previously most available settings
# were listed in this example file, but it is no longer true.
# For available settings, see openstack_dashboard/defaults.py and
# the horizon setting reference found at
# https://docs.openstack.org/horizon/latest/configuration/settings.html.
# Django related settings and HORIZON_CONFIG still exist here.
# Keep in my mind that they will be revisit in upcoming releases.
import os
from django.utils.translation import ugettext_lazy as _
from openstack_dashboard.settings import HORIZON_CONFIG
DEBUG = False
# This setting controls whether or not compression is enabled. Disabling
# compression makes Horizon considerably slower, but makes it much easier
# to debug JS and CSS changes
#COMPRESS_ENABLED = not DEBUG
# This setting controls whether compression happens on the fly, or offline
# with `python manage.py compress`
# See https://django-compressor.readthedocs.io/en/latest/usage/#offline-compression
# for more information
#COMPRESS_OFFLINE = not DEBUG
# If horizon is running in production (DEBUG is False), set this
# with the list of host/domain names that the application can serve.
# For more information see:
# https://docs.djangoproject.com/en/dev/ref/settings/#allowed-hosts
ALLOWED_HOSTS = ["*"]
# Set SSL proxy settings:
# Pass this header from the proxy after terminating the SSL,
# and don't forget to strip it from the client's request.
# https://docs.djangoproject.com/en/dev/ref/settings/#secure-proxy-ssl-header
#SECURE_PROXY_SSL_HEADER = ('HTTP_X_FORWARDED_PROTO', 'https')
# If Horizon is being served through SSL, then uncomment the following two
# settings to better secure the cookies from security exploits
#CSRF_COOKIE_SECURE = True
#SESSION_COOKIE_SECURE = True
# If provided, a "Report Bug" link will be displayed in the site header
# which links to the value of this setting (ideally a URL containing
# information on how to report issues).
#HORIZON_CONFIG["bug_url"] = "http://bug-report.example.com"
# Show backdrop element outside the modal, do not close the modal
# after clicking on backdrop.
#HORIZON_CONFIG["modal_backdrop"] = "static"
# Specify a regular expression to validate user passwords.
#HORIZON_CONFIG["password_validator"] = {
#    "regex": '.*',
#    "help_text": _("Your password does not meet the requirements."),
# Turn off browser autocompletion for forms including the login form and
# the database creation workflow if so desired.
#HORIZON_CONFIG["password_autocomplete"] = "off"
# Setting this to True will disable the reveal button for password fields,
# including on the login form.
#HORIZON_CONFIG["disable_password_reveal"] = False
LOCAL_PATH = '/tmp'
# Set custom secret key:
# You can either set it to a specific value or you can let horizon generate a
# default secret key that is unique on this machine, e.i. regardless of the
# amount of Python WSGI workers (if used behind Apache+mod_wsgi): However,
# there may be situations where you would want to set this explicitly, e.g.
# when multiple dashboard instances are distributed on different machines
# (usually behind a load-balancer). Either you have to make sure that a session
# gets all requests routed to the same dashboard instance or you set the same
# SECRET_KEY for all of them.
SECRET_KEY='e53a2174d8aa1ad8e169'
# We recommend you use memcached for development; otherwise after every reload
# of the django development server, you will have to login again. To use
# memcached set CACHES to something like below.
# For more information, see
# https://docs.djangoproject.com/en/1.11/topics/http/sessions/.
CACHES = {
   'default': {
       'BACKEND': 'django.core.cache.backends.memcached.MemcachedCache',
       'LOCATION': 'openstack-vip.xier.local:11211',
# If you use ``tox -e runserver`` for developments,then configure
# SESSION_ENGINE to django.contrib.sessions.backends.signed_cookies
# as shown below:
#SESSION_ENGINE = 'django.contrib.sessions.backends.signed_cookies'
SESSION_ENGINE = 'django.contrib.sessions.backends.cache'
# Send email to the console by default
EMAIL_BACKEND = 'django.core.mail.backends.console.EmailBackend'
# Or send them to /dev/null
#EMAIL_BACKEND = 'django.core.mail.backends.dummy.EmailBackend'
# Configure these for your outgoing email host
#EMAIL_HOST = 'smtp.my-company.com'
#EMAIL_PORT = 25
#EMAIL_HOST_USER = 'djangomail'
#EMAIL_HOST_PASSWORD = 'top-secret!'
OPENSTACK_HOST = "10.0.0.10"
OPENSTACK_KEYSTONE_URL = "http://%s/identity/v3" % OPENSTACK_HOST
OPENSTACK_KEYSTONE_MULTIDOMAIN_SUPPORT = True
OPENSTACK_API_VERSIONS = {
   "identity": 3,
   "image": 2,
   "volume": 3,
OPENSTACK_KEYSTONE_DEFAULT_DOMAIN = "Default"
OPENSTACK_KEYSTONE_DEFAULT_ROLE = "user"
OPENSTACK_NEUTRON_NETWORK = {
   'enable_router': True,
   'enable_quotas': True,
   'enable_distributed_router': True,
   'enable_ha_router': True,
   'enable_lb': True,
   'enable_firewall': True,
   'enable_vpn': True,
   'enable_fip_topology_check': True,
WEBROOT = "/dashboard"
# The timezone of the server. This should correspond with the timezone
# of your entire OpenStack installation, and hopefully be in UTC.
TIME_ZONE = "Asia/Shanghai"
# Change this patch to the appropriate list of tuples containing
# a key, label and static directory containing two files:
# _variables.scss and _styles.scss
#AVAILABLE_THEMES = [
#    ('default', 'Default', 'themes/default'),
#    ('material', 'Material', 'themes/material'),
#    ('example', 'Example', 'themes/example'),
LOGGING = {
   'version': 1,
   # When set to True this will disable all logging except
   # for loggers specified in this configuration dictionary. Note that
   # if nothing is specified here and disable_existing_loggers is True,
   # django.db.backends will still log unless it is disabled explicitly.
   'disable_existing_loggers': False,
   # If apache2 mod_wsgi is used to deploy OpenStack dashboard
   # timestamp is output by mod_wsgi. If WSGI framework you use does not
   # output timestamp for logging, add %(asctime)s in the following
   # format definitions.
   'formatters': {
       'console': {
           'format': '%(levelname)s %(name)s %(message)s'
       'operation': {
           # The format of "%(message)s" is defined by
           # OPERATION_LOG_OPTIONS['format']
           'format': '%(message)s'
   'handlers': {
       'null': {
           'level': 'DEBUG',
           'class': 'logging.NullHandler',
       'console': {
           # Set the level to "DEBUG" for verbose output logging.
           'level': 'DEBUG' if DEBUG else 'INFO',
           'class': 'logging.StreamHandler',
           'formatter': 'console',
       'operation': {
           'level': 'INFO',
           'formatter': 'operation',
   'loggers': {
       'horizon': {
           'handlers': ['console'],
           'level': 'DEBUG',
           'propagate': False,
       'horizon.operation_log': {
           'handlers': ['operation'],
           'level': 'INFO',
           'propagate': False,
       'openstack_dashboard': {
           'level': 'DEBUG',
           'propagate': False,
       'novaclient': {
           'level': 'DEBUG',
           'propagate': False,
       'cinderclient': {
           'level': 'DEBUG',
           'propagate': False,
       'keystoneauth': {
           'level': 'DEBUG',
           'propagate': False,
       'keystoneclient': {
           'level': 'DEBUG',
           'propagate': False,
       'glanceclient': {
           'level': 'DEBUG',
           'propagate': False,
       'neutronclient': {
           'level': 'DEBUG',
           'propagate': False,
       'swiftclient': {
           'level': 'DEBUG',
           'propagate': False,
       'oslo_policy': {
           'level': 'DEBUG',
           'propagate': False,
       'openstack_auth': {
           'level': 'DEBUG',
           'propagate': False,
       'django': {
           'level': 'DEBUG',
           'propagate': False,
       # Logging from django.db.backends is VERY verbose, send to null
       # by default.
       'django.db.backends': {
           'handlers': ['null'],
           'propagate': False,
       'requests': {
           'propagate': False,
       'urllib3': {
           'propagate': False,
       'chardet.charsetprober': {
           'propagate': False,
       'iso8601': {
           'propagate': False,
       'scss': {
           'propagate': False,
# 'direction' should not be specified for all_tcp/udp/icmp.
# It is specified in the form.
SECURITY_GROUP_RULES = {
   'all_tcp': {
       'name': _('All TCP'),
       'ip_protocol': 'tcp',
       'from_port': '1',
       'to_port': '65535',
   'all_udp': {
       'name': _('All UDP'),
       'ip_protocol': 'udp',
       'from_port': '1',
       'to_port': '65535',
   'all_icmp': {
       'name': _('All ICMP'),
       'ip_protocol': 'icmp',
       'from_port': '-1',
       'to_port': '-1',
   'ssh': {
       'name': 'SSH',
       'from_port': '22',
       'to_port': '22',
   'smtp': {
       'name': 'SMTP',
       'from_port': '25',
       'to_port': '25',
   'dns': {
       'name': 'DNS',
       'from_port': '53',
       'to_port': '53',
   'http': {
       'name': 'HTTP',
       'from_port': '80',
       'to_port': '80',
   'pop3': {
       'name': 'POP3',
       'from_port': '110',
       'to_port': '110',
   'imap': {
       'name': 'IMAP',
       'from_port': '143',
       'to_port': '143',
   'ldap': {
       'name': 'LDAP',
       'from_port': '389',
       'to_port': '389',
   'https': {
       'name': 'HTTPS',
       'from_port': '443',
       'to_port': '443',
   'smtps': {
       'name': 'SMTPS',
       'from_port': '465',
       'to_port': '465',
   'imaps': {
       'name': 'IMAPS',
       'from_port': '993',
       'to_port': '993',
   'pop3s': {
       'name': 'POP3S',
       'from_port': '995',
       'to_port': '995',
   'ms_sql': {
       'name': 'MS SQL',
       'from_port': '1433',
       'to_port': '1433',
   'mysql': {
       'name': 'MYSQL',
       'from_port': '3306',
       'to_port': '3306',
   'rdp': {
       'name': 'RDP',
       'from_port': '3389',
       'to_port': '3389',
# Help URL can be made available for the client. To provide a help URL, edit the
# following attribute to the URL of your choice.
#HORIZON_CONFIG["help_url"] = "http://openstack.mycompany.org"
  • 重启服务
配置dashboard的lvs代理
  • lvsvip1
cat dashboard.conf
  delay_loop 3
  lb_algo wrr
  lb_kind DR
  protocol TCP
      weight 100
      connect_timeout 1
      nb_get_retry 3
      weight 1
      HTTP_GET {
        url {
            path /index.html
            status_code 200
      connect_timeout 1
      nb_get_retry 3
部署controller2完成高可用
keystone
  • controller2安装openstack基本服务
  • controller1节点拷贝配置文件
cd /etc/keystone/
tar zcvf keystone-controller.tar.gz ./*
scp keystone-controller.tar.gz root@10.0.0.11:/etc/keystone/keystone-controller.tar.gz
  • controller2节点
tar zxvf /etc/keystone/keystone-controller.tar.gz -C /etc/keystone/
# 如果有不同的改为自己的地址
grep 10.0.0.10 /etc/keystone/* -R
ServerName 172.31.7.102:80
  • 启动服务
glance
  • 安装服务
  • controller1拷贝配置文件
cd /etc/glance/
tar cvf glance-controller1.tar.gz ./*
scp glance-controller1.tar.gz root@10.0.0.11:/etc/glance/
  • controller2节点
tar xvf /etc/glance/glance-controller1.tar.gz -C /etc/glance/
grep 10.0.0.10 /etc/glance/* -R
  • 启动服务
placement
  • 安装软件
  • controller1拷贝配置文件
cd /etc/placement/
tar cvf placement-controller1.tar.gz ./*
scp placement-controller1.tar.gz root@10.0.0.11:/etc/placement/
  • controller2节点
tar xvf /etc/placement/placement-controller1.tar.gz -C /etc/placement/
grep 10.0.0.10 /etc/placement/* -R
 <IfVersion >= 2.4>
    Require all granted
 </IfVersion>
 <IfVersion < 2.4>
    Order allow,deny
    Allow from all
 </IfVersion>
</Directory>
EOF
  • 启动服务
nova
  • 安装软件
  • controller1拷贝配置文件
cd /etc/nova/
tar cvf nova-controller.tar.gz ./*
scp nova-controller.tar.gz root@10.0.0.11:/etc/nova/
  • controller2节点
tar xvf /etc/nova/nova-controller.tar.gz -C /etc/nova/
grep 10.0.0.10 /etc/nova/* -R
sed -i "s/10.0.0.10/10.0.0.11/g" /etc/nova/nova.conf
  • 启动服务
  • 验证
nova service-list
neutron
  • 安装软件
  • controller1拷贝配置文件
cd /etc/neutron/
tar cvf neutron-controller.tar.gz ./*
scp neutron-controller.tar.gz root@10.0.0.11:/etc/neutron/
  • controller2节点
tar xvf /etc/neutron/neutron-controller.tar.gz -C /etc/neutron/
grep 10.0.0.10 /etc/neutron/* -R
net.ipv4.ip_forward = 1
EOF
  • 启动服务
sysctl -p
  • 验证
neutron agent-list
dashboard
  • 安装软件
  • controller1拷贝配置文件
cd /etc/openstack-dashboard/
tar cvf dashboard-controller.tar.gz ./*
scp dashboard-controller.tar.gz root@10.0.0.11:/etc/openstack-dashboard/
  • controller2节点
tar xvf /etc/openstack-dashboard/dashboard-controller.tar.gz -C /etc/openstack-dashboard/
grep 10.0.0.10 /etc/openstack-dashboard/* -R
sed -i "s/10.0.0.10/10.0.0.11/g" /etc/openstack-dashboard/local_settings
  • 启动服务
快速添加计算节点
nova与neutron
  • 在compute1准备好配置文件
cd /etc/nova/
tar cvf nova-compute.tar.gz ./*
cd /etc/neutron/
tar cvf neutron-compute.tar.gz ./*
scp /etc/nova/nova-compute.tar.gz root@10.0.0.15:/root
scp /etc/neutron/neutron-compute.tar.gz root@10.0.0.15:/root
  • conpute2编写脚本
cat >> /root/compute-install.sh << EOF
#!/bin/bash
# 执行脚本请将压缩包放入到root目录下
IP=`ifconfig | awk 'NR==2' | awk '{print $2}'`
# 初始化
echo "开始安装源....."
sleep 2
echo "源安装完成,正在安装基本软件....."
sleep 2
echo "正在配置华为源....."
sleep 2
# 安装配置nova服务
echo "正在配置nova服务...."
sleep 2
echo "安装nova服务"
sleep 2
echo "解压nova配置文件中....."
sleep 2
tar xvf /root/nova-compute.tar.gz -C /etc/nova/
echo "替换配置文件对应本节点....."
sleep 2
sed -i "s/10.0.0.14/${IP}/g" /etc/nova/nova.conf
echo "启动nova服务中....."
sleep 2
# 安装配置neutron服务
echo "正在配置neutron服务....."
sleep 2
echo "安装neutron服务"
sleep 2
echo "解压neutron配置文件中....."
sleep 2
tar xvf /root/neutron-compute.tar.gz -C /etc/neutron/
echo "正在更改配置文件....."
sleep 2
sed -i "s/10.0.0.14/${IP}/g" /etc/neutron/plugins/ml2/linuxbridge_agent.ini
echo "启动neutron中....."
sleep 2
systemctl restart openstack-nova-compute.service; systemctl enable --now neutron-linuxbridge-agent.service
sleep 1
echo "本计算节点已成功添加到OpenStack中"
EOF
sh compute-install.sh
手机端演示
openstack优化配置
  • 配置虚拟机自启动(计算节点)
# 计算节点 /etc/nova/nova.conf 进行以下配置:
[DEFAULT]
resume_guests_state_on_host_boot=true
  • 配置CPU超限使用(计算节点)
# 默认为16,即允许开启16倍于物理cpu的虚拟cpu个数
[DEFAULT]
cpu_allocation_ratio=16
  • 配置内存超限使用(计算节点)
# 配置允许1.5倍于物理内存的虚拟内存
[DEFAULT]
ram_allocation_ratio=1.5
  • 配置保留磁盘空间(计算节点)
# 即会预留一部分磁盘空间给系统使用
[DEFAULT]
reserved_host_disk_mb=20480
  • 配置预留内存给系统使用(计算节点)
# 即预留一定的内存给系统使用
[DEFAULT]
reserved_host_memory_mb=4096
  • 配置虚拟机类型动态调整(计算节点)
# 有些时候,创建完成的虚拟机因业务需求需要变更内存或cpu或磁盘,因此需要配置允许后期类型调整
[DEFAULT]
allow_resize_to_same_host=true      # 允许调整
  • openstack跨主机迁移/类型调整(控制节点对计算节点做免密)
usermod nova -s /bin/bash
echo 123456 | passwd --stdin nova
su - nova
ssh-keygen      # 一直回车即可
ssh-copy-id nova@10.0.0.14
ssh-copy-id nova@10.0.0.15
OpenStack-API
控制节点安装python3环境和相关模块
# 安装python3
yum install -y python3
# 安装API需要的模块
pip3 install requests -i https://pypi.douban.com/simple
mkdir openstack-api
cd openstack-api
动态获取token
  • 所有API资源创建都需要通过token认证
vim auth.py
#!/usr/bin/python3
import json, requests
# 定义全局路径
headers = {}
headers["Content-Type"] = "application/json"
os_auth_url = 'http://10.0.0.100:5000/v3/auth/tokens'  # 填入controller节点IP
# 多步骤身份验证(2-Factor密码和TOTP)定义请求头
body = {
    "auth": {                                              #授权
        "identity": {                                      #身份
            "methods": ["password"],                       #验证方法:密码
            "password": {
                "user": {
                    "id": "b09096c15b814053bf25264a3dbe5366",  #根据controller的user_id
                    "password": "000000"
        "scope": {                                          #范围
            "project": {
                "id": "93ad92c3e318431099327595bf689acc"    #根据controller的project_id
#获取token值
def get_token():
    reponse = requests.post(os_auth_url, data=json.dumps(body), headers=headers).headers["X-Subject-Token"]     # dumps序列化回服务端
    return reponse
创建flavor(云主机类型)
vim flavor.py
#!/usr/bin/python3
from auth import get_token
headers = {}
headers['X-Auth-Token'] = get_token()
url = "http://10.0.0.100:8774/v2.1/flavors"
body = {
    "flavor": {
        "name": "C2_2G_20G",
        "vcpus": 2,
        "ram": 2048,
        "disk": 20,
def create_flavor():
    re = requests.post(url, data=json.dumps(body), headers=headers).json()
    print(re)
def main_flavor():
    re = requests.get(url, headers=headers).json()
    name = re['flavors']
    for flavor_name in name:
        print(flavor_name["name"])
        if flavor_name["name"] == body["flavor"]["name"]:
            requests.delete(url + f"/{flavor_name['id']}", headers=headers)
            print('....已删除同名云主机类型...正在新建中')
    else:
        create_flavor()
        print('云主机类型创建成功...')
if __name__ == '__main__':
    main_flavor()
创建network(网络)
  • vxlan网络
vim network_vxlan.py
#!/usr/bin/python3
class networks_vxlan:
    headers = {}
    headers['Content-Type'] = 'application/json'
    url = "http://10.0.0.100:9696/v2.0/"
    body = {
        "network": {
            "name": "intnet_vxlan",
            'provider:network_type': 'vxlan',
            'router:external': False,
            'shared': True,
    def intnet_vxlan(self):
        re = requests.post(self.url + "networks", data=json.dumps(self.body), headers=self.headers).json()
        print(re)
    def intsubnet_vxlan(self):
        intnet = requests.get(self.url + "networks", headers=self.headers).json()["networks"]
        for net_id in intnet:
            if net_id['name'] == self.body['network']['name']:
                intnet_id = net_id['id']
        body = {
            "subnet": {
                "name": "intsubnet-vxlan",
                'network_id': intnet_id,
                'cidr': '166.66.66.0/24',
                'gateway_ip': '166.66.66.1',
                'ip_version': 4,
                'dns_nameservers': ['223.6.6.6'],
        re = requests.post(self.url + "subnets", data=json.dumps(body), headers=self.headers).json()
        print(re)
    def main_network(self):
        re = requests.get(self.url + "networks", headers=self.headers).json()
        name = re["networks"]
        for net_name in name:
            print(net_name['name'])
            if net_name['name'] == self.body['network']['name']:
                requests.delete(self.url + f"networks/{net_name['id']}", headers=self.headers)
                print('删除同名网络....新建网络中...')
        else:
            self.intnet_vxlan()
            self.intsubnet_vxlan()
            print('新建网络成功')
    net = networks_vxlan()
    net.main_network()
  • flat网络
vim network_flat.py
#!/usr/bin/python3
class networks_flat:
    headers = {}
    body = {
        "network": {
            "name": "extnet_flat",
            'provider:network_type': 'flat',
            'provider:physical_network': 'extnal',
            'router:external': True,
            'shared': False,
    def extnet_flat(self):
        print(re)
    def extsubnet_flat(self):
        body = {
            "subnet": {
                "name": "extsubnet_flat",
                'cidr': '10.0.0.0/24',
                'gateway_ip': '10.0.0.254',
                'ip_version': 4,
                'allocation_pools': [
                        'start': '10.0.0.30',
                        'end': '10.0.0.240'
        print(re)
        else:
            self.extnet_flat()
            self.extsubnet_flat()
            print('新建网络成功')
    net = networks_flat()
    net.main_network()
创建router(路由器)
vim router.py
#!/usr/bin/python3
from network_flat import networks_flat
class router:
    headers = {}
    re = requests.get(url + "networks", headers=headers).json()
    name = re['networks']
    for net_id in name:
        if net_id['name'] == networks_flat.body['network']['name']:
            ext_flat = net_id['id']
            sub_flat = net_id['subnets'][0]
    body = {
        "router": {
            "name": "ext_router",
            'external_gateway_info': {
                'network_id': ext_flat,
                'enable_snat': True,
                'external_fixed_ips': [
                    {'subnet_id': sub_flat}
    def create_router(self):
        re = requests.post(self.url + "routers", data=json.dumps(self.body), headers=self.headers).json()
        print(re)
    def main_router(self):
        re = requests.get(self.url + "routers", headers=self.headers).json()
        name = re["routers"]
        for router_id in name:
            if router_id['name'] == self.body['router']['name']:
                requests.delete(self.url + f"routers/{router_id['id']}", headers=self.headers)
                print("删除同名路由器...正在新建中...")
        else:
            self.create_router()
            print("路由新建成功...")
    r = router()
    r.main_router()
上传镜像
vim image_push.py
#!/usr/bin/python3
headers = {}
headers['Content-Type'] = 'application/octet-stream'
url = "http://10.0.0.100:9292"
body = {
    "name": "cirros",
    'container_format': 'bare',
    'disk_format': 'qcow2',
def create_image():
    re = requests.post(url + "/v2/images", data=json.dumps(body), headers=headers).json()
    print(re)
    re = requests.put(url + re["file"], data=open("D:\iso镜像\cirros-0.4.0-x86_64-disk.img", "rb"), headers=headers).status_code
    print(re)
def main_image():
    re = requests.get(url + "/v2/images", headers=headers).json()
    name = re['images']
    for image_id in name:
        if image_id['name'] == body['name']:
            requests.delete(url + f"/v2/images/{image_id['id']}", headers=headers)
            print("删除同名镜像成功.....正在新建中")
    else:
        create_image()
        print('镜像上传成功')
    main_image()
创建云主机
vim create_server.py
#!/usr/bin/python3
import flavor
import push_image
from network_vxlan import networks_vxlan
headers = {}
url = "http://10.0.0.100:8774/v2.1/servers"
image_ret = requests.get("http://10.0.0.100:9292/v2/images", headers=headers).json()["images"]
for image_json in image_ret:
    if image_json["name"] == push_image.body["name"]:
        image_id = image_json["id"]
flavor_ret = requests.get("http://10.0.0.100:8774/v2.1/flavors", headers=headers).json()["flavors"]
for flavor_json in flavor_ret:
    if flavor_json["name"] == flavor.body["flavor"]["name"]:
        # print(flavor_json["name"], flavor.body["flavor"]["name"])
        flavor_id = flavor_json['id']
network_ret = requests.get("http://10.0.0.100:9696/v2.0/networks/", headers=headers).json()["networks"]
for network_json in network_ret:
    if network_json["name"] == networks_vxlan.body["network"]["name"]:
        network_id = network_json["id"]
body = {
    "server": {
        "name": "vm01",
        "imageRef": image_id,
        "flavorRef": flavor_id,
        "networks": [{"uuid": network_id}]      # openstack network list
def create_server():
def main_server():
    name = re['servers']
    for server_id in name:
        if server_id['name'] == body['server']['name']:
            requests.delete(url + f"/{server_id['id']}", headers=headers)
            print("删除同名云主机....正在新建中...")
    else:
        create_server()
        print("云主机创建成功")
    main_server()
绑定浮动IP
vim float_ip.py
#!/usr/bin/python3
import create_server
headers = {}
headers["X-Auth-Token"] = get_token()
url_float = 'http://10.0.0.100:9696/v2.0/floatingips'
url_server = "http://10.0.0.100:8774/v2.1/servers"
url_extnet = "http://10.0.0.100:9696/v2.0/networks"
server_name = requests.get(url_server, headers=headers).json()
for server_json in server_name["servers"]:
    if server_json["name"] == create_server.body["server"]["name"]:
        server_id = server_json["id"]
float_name = requests.get("http://10.0.0.100:9696/v2.0/ports", headers=headers).json()
for float_json in float_name["ports"]:
    if float_json["device_id"] == server_id:
        port_id = float_json["id"]
network_name = requests.get(url_extnet, headers=headers).json()
for extnet_json in network_name["networks"]:
    if extnet_json["name"] == networks_flat.body["network"]["name"]:
        extnet_id = extnet_json["id"]
def create_ip():
    body = {
        "floatingip": {
            "floating_network_id": extnet_id,  # 外部网络ID(创建云主机时要内部网络,要把内部网络添加到路由中)
            "port_id": port_id,  # 云主机port的ID (openstack port list)
    float_ret = requests.get(url_float, headers=headers).json()
    for float_data in float_ret["floatingips"]:
        if float_data["port_id"] == port_id:
            return f"浮动IP已绑定,浮动地址为{float_data['floating_ip_address']}"
    else:
        requests.post(url_float, data=json.dumps(body), headers=headers).json()
        return f"浮动IP绑定成功,浮动地址为{float_data['floating_ip_address']}"
    ret = create_ip()
    print(ret)
创建安全组
vim security.py
#!/usr/bin/python3
headers = {}
url = "http://10.0.0.100:9696/v2.0/security-groups/"
body1 = {
    "security_group": {
        "name": "sec_group",
sec_body = requests.get(url, headers=headers).json()
sec_ret = sec_body["security_groups"]
def security_group_create():
    for sec_json in sec_ret:
        if sec_json["name"] == body1["security_group"]["name"]:
            requests.delete(url + f"{sec_json['id']}", headers=headers)
            print("安全组删除成功....正在重新创建....")
    else:
        res = requests.post(url, data=json.dumps(body1), headers=headers).json()
        print("安全组创建成功")
        return res
sec_rules_id = security_group_create()["security_group"]["id"]
def security_group_rules_create():
    url = "http://10.0.0.100:9696/v2.0/security-group-rules/"
    def port(max, min):
        body = {
            'security_group_rule': {
                'direction': 'egress',
                'protocol': 'tcp',
                'ethertype': 'IPv4',
                'remote_ip_prefix': "0.0.0.0/24",
                'port_range_max': max,
                'port_range_min': min,
                'security_group_id': sec_rules_id,
        return body
    list = [port(20, 20), port(21, 21), port(22, 22), port(80, 80), port(3306, 3306)]
    result = []
    for body in list:
        body = requests.post(url, data=json.dumps(body), headers=headers).json()
        result.append(body)
    # print([port for port in result])
