手牵手SpringBoot之ORM操作MySql
QGS 发表于 2023/04/10 20:40:06 2023/04/10
【摘要】 手牵手SpringBoot之ORM操作MySql
总体框架
@Mapper注解
@Mapper注解:放在dao接口上面。表示该接口会由Mybaits创建mapper代理对象
@MapperScan注解
在主类中使用@MapperScan注解,可解决多个dao接口中使用@Mapper注解的繁琐。
@MapperScan("com.example.dao")
或@MapperScan(basePackages = "com.example.dao")
Pom.xml配置文件
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.7.10</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.example</groupId>
    <artifactId>springboot-Mybatis</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>springboot-Mybatis</name>
    <description>springboot-Mybatis</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <groupId>org.mybatis.spring.boot</groupId>
            <artifactId>mybatis-spring-boot-starter</artifactId>
            <version>2.3.0</version>
        </dependency>
        <dependency>
            <groupId>com.mysql</groupId>
            <artifactId>mysql-connector-j</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <resources>
            <resource>
                <!--所在的目录-->
                <directory>src/main/java</directory>
                <includes>
                    <!--包括目录下的.properties .xml文件都会扫描到-->
                    <include>**/*.properties</include>
                    <include>**/*.xml</include>
                </includes>
                <filtering>false</filtering>
            </resource>
        </resources>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
创建Dao接口与Mapper文件
dao
//@Mapper //表示该接口会创建mapper代理
public interface StaffDao {
    //查询所有
    List<Staff> selectALL();
Mapper
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "https://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.example.dao.StaffDao">
    <select id="selectALL" resultType="com.example.pojo.Staff">
        SELECT * FROM staff;
    </select>
</mapper>
Pojo类
public class Staff {
    private int id;
    private String name;
    private String diploma;
    private String title;
    private String marriage;
    private String status;
    private String workTime;
        //get+set+toString
Server接口
public interface StaffService {
Server实现类
@Service
public class StaffServiceImpl implements StaffService {
    @Resource
    private StaffDao staffDao;
    @Override
    public List<Staff> selectALL() {
        List<Staff> staffs = staffDao.selectALL();
        return staffs;
application.properties配置文件
#application.properties配置文件
server.port=8080
server.servlet.context-path=/boot
#指定时区
serverTimezone=Asia/Shanghai
#serverTimezone=GMT%2B8
#连接数据库
spring.datasource.driver-class-name=com.mysql.cj.jdbc.Driver
spring.datasource.url=jdbc:mysql://IP:3306/mysql?useUnicode=true&characterEncoding=UTF-8
spring.datasource.username=root
spring.datasource.password=pwd
Application类启动
浏览器访问
Dao与mapper分开管理
需要在application.properties配置mapper路径
#指定mapper文件路径
mybatis.mapper-locations=classpath:mapper/*.xml
Pom.xml配置
<resources>
    <resource>
        <!--所在的目录-->
        <directory>src/main/resources</directory>
        <includes>
            <!--包括目录下的所有文件都会扫描到-->
            <include>**/*.*</include>
        </includes>
    </resource>
</resources>
开启Mybatis日志
#配置mybatis启动日志
mybatis.configuration.log-impl=org.apache.ibatis.logging.stdout.StdOutImpl
开启事务控制
事务管理器:DataSourceTransactionManager
Spring实现事务的两种方式
编程式事务:编写代码来实现事务的管理
声明式事务*:基于注解的方式、基于xml配置方式
声明式事务处理
只需要通过配置就可以完成对事务的管理,而无需手动编程。
事务隔离级别的四个级别:
读未提交:READ_UNCOMMITTEN
       这种隔离级别:存在脏读问题,所谓的脏读(dirty read)表示能够读取到其他事务未提交的数据。
读提交:READ_COMMITTED            (oracle)
       解决了脏读问题,其他事务提交之后才能读到,但存在不可重复读问题
可重复读:REPEATABLE_READ     (MYSQL)
       解决了不可重复读,可以达到可重复读效果,只要当前事务不结束,读取到的数据移植都是一样的。但存在幻读问题。
序列化:SERIALLZABLE
       解决了幻读问题,事务排毒执行。不支持并发。
事务处理方式:1、Spring框架的@Transaction注解。2、aspectj框架xml配置,声明事务控制的内容。
SpringBoot中事务的使用的两种方式:1、业务方法上使用@Transaction注解。2、启动类使用@EnableTransactionManagement
server.port=8080
#指定时区
#连接数据库
#指定mapper文件路径
#配置mybatis启动日志
Server层实现
public interface StaffServer {
    int insert(Staff staff);
    Staff selectById(Integer id);
@Service
public class StaffServerImpl implements StaffServer {
    @Resource
    private StaffMapper staffDao;
    @Transactional
    @Override
    public int insert(Staff staff) {
        int insert = staffDao.insert(staff);
        return insert;
    @Transactional
    @Override
    public Staff selectById(Integer id) {
        Staff staff = staffDao.selectByPrimaryKey(id);
        return staff;
Controller层
@Controller
public class StaffController {
    @Resource
    private StaffServer staffServer;
    @RequestMapping("/selectById")
    @ResponseBody
    public String selectById(int id){
        System.out.println("id:"+id);
        Staff staff = staffServer.selectById(id);
        System.out.println(staff.toString());
        return staff.toString();
使用Mybatis生成器
<!DOCTYPE generatorConfiguration
        PUBLIC "-//mybatis.org//DTD MyBatis Generator Configuration 1.0//EN"
        "http://mybatis.org/dtd/mybatis-generator-config_1_0.dtd">
<generatorConfiguration>
    <!-- 指定连接数据库的JDBC驱动包所在位置,指定到你本机的完整路径,需确保本地路径下存在该jar -->
    <classPathEntry location="C:\Users\13631\.m2\repository\com\mysql\mysql-connector-j\8.0.32\mysql-connector-j-8.0.32.jar"/>
    <!-- 配置table表信息内容体,targetRuntime指定采用MyBatis3的版本 -->
    <context id="tables" targetRuntime="MyBatis3">
        <!--序列化-->
        <plugin type="org.mybatis.generator.plugins.SerializablePlugin"/>
        <!--以下需要插件  -->
            插入成功后返回ID
           <plugin type="cn.doity.common.generator.plugin.InsertAndReturnKeyPlugin"/>
           分页查询功能
           <plugin type="cn.doity.common.generator.plugin.SelectByPagePlugin"/>
           生成带有for update后缀的select语句插件
           <plugin type="cn.doity.common.generator.plugin.SelectForUpdatePlugin"/> -->
        <!-- 抑制生成注释,由于生成的注释都是英文的,可以不让它生成 -->
        <commentGenerator>
            <property name="suppressAllComments" value="true" />
        </commentGenerator>
        <!-- 配置数据库连接信息 -->
        <jdbcConnection driverClass="com.mysql.cj.jdbc.Driver"
                        connectionURL="jdbc:mysql://IP:3306/mysql?useUnicode=true&amp;characterEncoding=UTF-8&amp;#serverTimezone=GMT%2B8"
                        userId="root"
                        password="pwd">
        </jdbcConnection>
        <!-- 生成model(pojo)类,targetPackage指定model类的包名, targetProject指定生成的model放在eclipse的哪个工程下面-->
        <javaModelGenerator
                targetPackage="com.example.pojo"
                targetProject="src/main/java">
            <property name="enableSubPackages" value="false" />
            <property name="trimStrings" value="false" />
        </javaModelGenerator>
        <!-- 生成MyBatis的Mapper.xml文件,targetPackage指定mapper.xml文件的包名, targetProject指定生成的mapper.xml放在eclipse的哪个工程下面 -->
        <sqlMapGenerator
                targetPackage="mapper"
                targetProject="src/main/resources">
        </sqlMapGenerator>
        <!-- 生成MyBatis的dao接口类文件,targetPackage指定dao接口类的包名, targetProject指定生成的Mapper接口放在eclipse的哪个工程下面 -->
        <javaClientGenerator type="XMLMAPPER"
                             targetPackage="com.example.dao"
        </javaClientGenerator>
        <!-- 数据库表名及对应的Java模型类名 -->
        <table tableName="staff" domainObjectName="Staff"
               enableCountByExample="false"
               enableUpdateByExample="false"
               enableDeleteByExample="false"
               enableSelectByExample="false"
               selectByExampleQueryId="false"/>
    </context>
</generatorConfiguration>
生成
Application
@SpringBootApplication
public class Application {
        SpringApplication.run(Application.class, args);
浏览器访问:
http://localhost:8080/boot/selectById?id=2
