手搭手SpringBoot2使用Mybatis生成器
QGS 发表于 2023/04/09 17:11:53 2023/04/09
【摘要】 手搭手SpringBoot2使用Mybatis生成器
Pom.xml配置
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.7.10</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.example</groupId>
    <artifactId>springboot-transactional</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>springboot-transactional</name>
    <description>springboot-transactional</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <groupId>org.mybatis.spring.boot</groupId>
            <artifactId>mybatis-spring-boot-starter</artifactId>
            <version>2.3.0</version>
        </dependency>
        <dependency>
            <groupId>com.mysql</groupId>
            <artifactId>mysql-connector-j</artifactId>
            <scope>runtime</scope>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <resources>
            <resource>
                <!--所在的目录-->
                <directory>src/main/resources</directory>
                <includes>
                    <!--包括目录下的所有文件都会扫描到-->
                    <include>**/*.*</include>
                </includes>
                <filtering>false</filtering>
            </resource>
        </resources>
        <plugins>
            <!--pom.xml配置mybatis代码自动生成插件-->
            <plugin>
                <groupId>org.mybatis.generator</groupId>
                <artifactId>mybatis-generator-maven-plugin</artifactId>
                <version>1.3.7</version>
                <configuration>
                    <configurationFile>GeneratorMapper.xml</configurationFile>
                    <verbose>true</verbose>
                    <overwrite>true</overwrite>
                </configuration>
            </plugin>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
使用Mybatis生成器
GeneratorMapper.xml配置文件
<!DOCTYPE generatorConfiguration
        PUBLIC "-//mybatis.org//DTD MyBatis Generator Configuration 1.0//EN"
        "http://mybatis.org/dtd/mybatis-generator-config_1_0.dtd">
<generatorConfiguration>
    <!-- 指定连接数据库的JDBC驱动包所在位置,指定到你本机的完整路径,需确保本地路径下存在该jar -->
    <classPathEntry location="C:\Users\13631\.m2\repository\com\mysql\mysql-connector-j\8.0.32\mysql-connector-j-8.0.32.jar"/>
    <!-- 配置table表信息内容体,targetRuntime指定采用MyBatis3的版本 -->
    <context id="tables" targetRuntime="MyBatis3">
        <!--序列化-->
        <plugin type="org.mybatis.generator.plugins.SerializablePlugin"/>
        <!--以下需要插件  -->
            插入成功后返回ID
           <plugin type="cn.doity.common.generator.plugin.InsertAndReturnKeyPlugin"/>
           分页查询功能
           <plugin type="cn.doity.common.generator.plugin.SelectByPagePlugin"/>
           生成带有for update后缀的select语句插件
           <plugin type="cn.doity.common.generator.plugin.SelectForUpdatePlugin"/> -->
        <!-- 抑制生成注释,由于生成的注释都是英文的,可以不让它生成 -->
        <commentGenerator>
            <property name="suppressAllComments" value="true" />
        </commentGenerator>
        <!-- 配置数据库连接信息 -->
        <jdbcConnection driverClass="com.mysql.cj.jdbc.Driver"
                        connectionURL="jdbc:mysql://IP:3306/mysql?useUnicode=true&amp;characterEncoding=UTF-8&amp;#serverTimezone=GMT%2B8"
                        userId="root"
                        password="pwd">
        </jdbcConnection>
        <!-- 生成model(pojo)类,targetPackage指定model类的包名, targetProject指定生成的model放在eclipse的哪个工程下面-->
        <javaModelGenerator
                targetPackage="com.example.pojo"
                targetProject="F:\IDEADemo\SpringbootDemo\springboot-transactional\src\main\java">
            <property name="enableSubPackages" value="false" />
            <property name="trimStrings" value="false" />
        </javaModelGenerator>
        <!-- 生成MyBatis的Mapper.xml文件,targetPackage指定mapper.xml文件的包名, targetProject指定生成的mapper.xml放在eclipse的哪个工程下面 -->
        <sqlMapGenerator
                targetPackage="mapper"
                targetProject="src/main/resources">
        </sqlMapGenerator>
        <!-- 生成MyBatis的dao接口类文件,targetPackage指定dao接口类的包名, targetProject指定生成的Mapper接口放在eclipse的哪个工程下面 -->
        <javaClientGenerator type="XMLMAPPER"
                             targetPackage="com.example.dao"
                             targetProject="src/main/java">
        </javaClientGenerator>
        <!-- 数据库表名及对应的Java模型类名 -->
        <table tableName="staff" domainObjectName="Staff"
               enableCountByExample="false"
               enableUpdateByExample="false"
               enableDeleteByExample="false"
               enableSelectByExample="false"
               selectByExampleQueryId="false"/>
    </context>
</generatorConfiguration>
生成
application.properties配置
#application.properties配置文件
server.port=8080
server.servlet.context-path=/boot
#指定时区
serverTimezone=Asia/Shanghai
#连接数据库
spring.datasource.driver-class-name=com.mysql.cj.jdbc.Driver
spring.datasource.url=jdbc:mysql://IP:3306/mysql?useUnicode=true&characterEncoding=UTF-8
spring.datasource.username=root
spring.datasource.password=pwd
#指定mapper文件路径
mybatis.mapper-locations=classpath:mapper/*.xml
#配置mybatis启动日志
mybatis.configuration.log-impl=org.apache.ibatis.logging.stdout.StdOutImpl
