java:How to use variable parameter? (easy to understand)
Cyan_RA9 发表于 2023/04/03 09:53:20 2023/04/03
【摘要】 It's the first time to write a blog in English for me. (About variable parameter)
Catalogue:
I.Preface :
II.Syntax :
III.NOTICE(significant) :
IV.Code Demonstrate :
        1.Show notice one, notice two and notice three :
        2.Show notice four :
        3.Show notice five :
        4.Exercise:
I.Preface :
        java allows us to encapsulate many methods which have the same name and function but have different number of parameters into one method  at one class.
        We achieve it by using variable parameter in the list of formal parameters.
        By the way, we will use variable parameter in the module java reflect, etc.
II.Syntax :
        access_modifier return_type method_name (data_structures... parameters) {
        ΔIn the list of formal parameters, the format of three points "..." is fix.
        1. The number of actual parameter can range from 0 to n.(n = 1, 2, 3, 4, 5......)
        2. The actual parameter can be an array directly.
        3. The variable parameter is actually an array, so you can use it as an array.
        4. When variable parameter is used with ordinary parameter, make sure that the             variable parameter is at last of the list of formal parameter.
        5. There could be only one variable parameter at one parameter list.
        Hey, guys, I am about to demonstrate all the notices mentioned above in code.
package csdn.varparameter;
public class VariableParameter {
            Test1 t1 = new Test1();
            int[] array1 = {2, 11, 211, 985, 141};
            //1. The number of actual parameter can range from 0 to n.(n = 1, 2, 3, 4, 5......)
            System.out.println(t1.getSum(0, 1, 2, 3, 4, 5));
            System.out.println(t1.getSum(array1));
            //2. The actual parameter can be an array directly.
            System.out.println("------------------------");
class Test1 {
    public int getSum(int... parameters) {
        System.out.println(parameters.length + " parameters were received.");
        //3. The variable parameter is actually an array, so you can use it as an array.
        int num = 0;
        for (int i = 0; i < parameters.length; ++i) {
            num += parameters[i];
        System.out.print("The Sum of parameters passed is : ");
        return num;
        Output result :
            Test2 t2 = new Test2();
            int[] array2 = {1, 2, 7};
            System.out.println(t2.getSum2(array1, 1, 3, 1));
            System.out.println(t2.getSum2(array1, array2));
class Test2 {
    public int getSum2(int[] arr, int... parameters) {
        int sum1 = 0;
        int sum2 = 0;
        for (int i = 0; i < arr.length; ++i) {
            sum1 += arr[i];
        }   //Use sum1 variable to store the sum of "arr" array.
            sum2 += parameters[i];
        }   //Use sum2 variable to store the sum of "variable parameter".
        System.out.print("The total sum of parameters passed is : ");
        return sum1 + sum2;
        Output result :
         Actually it's easy to understand the notice five, because we have got the notice four :  When variable parameter is used with ordinary parameter, make sure that the variable parameter is at last of the list of formal parameter. So, if you have variable parameters, more than one, you can't promise that every variable parameters is at the end of the the list of formal parameters. Absolutely you can't achieve it!
        Let's have a look at the demonstration,a GIF picture, as follow:
        Apparently, we can see the IDEA report a error, and the reason is actually what we're talking about above.
        4.Exercise:
        requirement : Encapsulate one static method in a arbitrary class, whatever, and the formal parameters you need to pass in are Student's name, Student's grade and the scores of his or her every subjects.We supposed that the Student totally examines five subject. When this method is invoked, the student's name, grade and five subjects' sum scores will be printed on the console.
        Code Demonstration :
        System.out.println(Test3.studentScore("Cyan", 14, 141,135,80,75));
class Test3 {
    public static String studentScore(String name, int grade, int... scores) {
        int scoreNum = 0;
        for (int i = 0; i < scores.length; ++i) {
            scoreNum += scores[i];
        return name + ", who is in " + grade + " class, got totally " + scoreNum + " points";
        Output result :
System.out.println("END---------------------------------------------------------------------");
