软件测试|使用docker搞定 Python环境搭建
霍格沃兹软件测试开发 发表于 2023/03/30 17:56:58 2023/03/30
【摘要】 前言当我们在公司的电脑上搭建了一套我们需要的Python环境,比如我们的版本是3.8的Python,那我可能有一天换了一台电脑之后,我整套环境就需要全部重新搭建,不只是Python,我们一系列的第三方库都需要重新安装,那么我们有没有解决问题的方法,当然有,我们可以使用docker解决困扰我们的环境问题。 搜索镜像docker search : 从Docker Hub(https://hub...
前言
搜索镜像
docker search : 从Docker Hub(https://hub.docker.com)中搜索指定的镜像,例如我们要搜索一个基于centos7环境安装的Python3.8版本。命令如下:
docker search python
  • NAME 镜像仓库名称
  • DESCRIPTION 镜像描述信息
  • STARS 镜像收藏数
  • OFFICIAL 是否为docker官方发布的镜像
  • AUTOMATED 是否为自动化构建的镜像
输出如下:
[root@xxxx ~]# docker search python
NAME                             DESCRIPTION                                     STARS               OFFICIAL            AUTOMATED
python                           Python is an interpreted, interactive, objec…   4288                [OK]
django                           Django is a free web application framework, …   847                 [OK]
pypy                             PyPy is a fast, compliant alternative implem…   193                 [OK]
kaggle/python                    Docker image for Python scripts run on Kaggle   123                                     [OK]
arm32v7/python                   Python is an interpreted, interactive, objec…   37
centos/python-38-centos7         Platform for building and running Python 3.8…   36
joyzoursky/python-chromedriver   Python with Chromedriver, for running automa…   33                                      [OK]
circleci/python                  Python is an interpreted, interactive, objec…   29
nikolaik/python-nodejs           Python with Node.js                             18                                      [OK]
arm64v8/python                   Python is an interpreted, interactive, objec…   17
centos/python-36-centos7         Platform for building and running Python 3.6…   17
centos/python-27-centos7         Platform for building and running Python 2.7…   15
iron/python                      Tiny Python Microcontainer                      9
publicisworldwide/python-conda   Basic Python environments with Conda.           6                                       [OK]
dockershelf/python               Repository for docker images of Python. Test…   4                                       [OK]
i386/python                      Python is an interpreted, interactive, objec…   3
bitnami/python                   Bitnami Python Docker Image                     3                                       [OK]
komand/python-plugin             DEPRECATED: Komand Python SDK                   2                                       [OK]
centos/python-34-centos7         Platform for building and running Python 3.4…   2
muccg/python-base                Base images that use python                     1                                       [OK]
amd64/python                     Python is an interpreted, interactive, objec…   1
ccitest/python                   CircleCI test images for Python                 0                                       [OK]
saagie/python                    Repo for python jobs                            0
qbtrade/python                   python 3.6.5 with requirements last update s…   0
openshift/python-33-centos7      DEPRECATED: A Centos7 based Python v3.3 imag…   0
[root@xxxx ~]#
拉取镜像
使用docker pull可以拉取我们想要拉取的镜像,命令如下:
docker pull centos/python-38-centos7
输出如下:
[root@xxxx ~]# docker pull centos/python-38-centos7
Using default tag: latest
latest: Pulling from centos/python-38-centos7
8ba884070f61: Pull complete
c3dca185eb14: Pull complete
ee720ba20823: Pull complete
497ef6ea0fac: Pull complete
ebf1fb961f61: Pull complete
b8249f70ce00: Pull complete
ebd817e2efe7: Pull complete
d3d10dd0937c: Pull complete
a8ad47ec8182: Pull complete
Digest: sha256:d10c46b6db436357965a96716e9f5d230d9b1a58c6db1f0c4f43c1fb1994cd79
Status: Downloaded newer image for centos/python-36-centos7:latest
[root@xxxx ~]#
查看镜像
使用docker images查看本地已经下载好的镜像,命令如下:
docker images
输出如下:
[root@xxxx ~]# docker images
REPOSITORY                 TAG                 IMAGE ID            CREATED             SIZE
centos/python-38-centos7   latest              b8d15efaa8ec        2 months ago        651MB
ubuntu                            15.10               9b9cb95443b5        2 years ago         137MB
training/webapp               latest              6fae60ef3446        4 years ago         349MB
运行交互式的容器
Docker会在隔离的容器中运行进程。当运行docker run命令时,Docker会启动一个进程,并为这个进程分配其独占的文件系统、网络资源和以此进程为根进程的进程组。
在容器启动时,镜像可能已经定义了要运行的二进制文件、暴露的网络端口等,但是用户可以通过docker run命令重新定义
最基本的docker run命令的格式如下:
$ sudo docker run [OPTIONS] IMAGE[:TAG] [COMMAND] [ARG...]
比如我这里要启动centos7,进入交互模式,通过docker的两个参数 -i -t,让docker运行的容器实现"对话"的能力
  • t: 在新容器内指定一个伪终端或终端
  • i: 允许你对容器内的标准输入 (STDIN) 进行交互
docker run -i -t centos/python-38-centos7 /bin/bash
如下进入centos终端后,进python交互环境打印"hello, i’m Muller.",最后用exit退出,内容如下:
[root@xxxx ~]# docker run -i -t centos/python-36-centos7 /bin/bash
(app-root) python
Python 3.6.3 (default, Mar 20 2018, 13:50:41)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-16)] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> print("hello, i'm Muller.")
hello, i'm Muller.
>>> exit()
(app-root) exit
后台模式启动
run加上-i -t是进交互模式,如果不想进交互模式直接执行脚本,可以直接使用run,比如echo “hello world”,屏幕会输出"hello world"
docker run centos/python-38-centos7 /bin/echo "hello world"
如果不想在前台执行,一般我们运行环境会选择挂后台,加个-d 参数即可
docker run -d centos/python-38-centos7 /bin/echo "hello world"
[root@xxxx ~]# docker run centos/python-38-centos7 /bin/echo "hello world"
hello world
[root@xxxx ~]# docker run -d centos/python-38-centos7 /bin/echo "hello world"
1e5c22451bf2215f6c098e066b74363f1db9cde97e9ecea02947ccbbf2fa7e8f
[root@xxxx ~]#
使用-d后台执行后,会发现下面多了一长串,这个就是容器的唯一id,可以通过这个id找到容器
ps查看容器
先run下 training/webapp
docker run -d -p 5000:5000 training/webapp python app.py
使用docker ps查看正在运行的容器
docker ps
输出如下:
[root@xxxx ~]# docker ps
CONTAINER ID        IMAGE               COMMAND             CREATED             STATUS              PORTS
c9e8a325b145        training/webapp     "python app.py"     16 hours ago        Up 16 hours         0.0.0.0:32768->5000/tcp
[root@xxxx ~]#
上面的echo "hello world"只是一个很简单的输出指令,执行完就关闭了,所以ps查找正在运行的查不到,可以加个-a参数,显示所有的容器,包括未运行的
ps 查找参数相关语法
  • -a :显示所有的容器,包括未运行的
  • -f :根据条件过滤显示的内容
  • –format :指定返回值的模板文件
  • -l :显示最近创建的容器
  • -n :列出最近创建的n个容器
  • –no-trunc :不截断输出
  • -q :静默模式,只显示容器编号
  • -s :显示总的文件大小
logs查看日志
可以通过容器id或者容器name去查运行的日志
docker logs [容器id]
docker logs [容器name]
停止容器
停止容器的话,可以用stop容器的id或者容器NAME名称
docker stop [容器id]
docker stop [容器name]
启动容器
docker start启动容器
docker start [容器id]
正在运行的容器,可以使用 docker restart 命令来重启
docker restart [容器id]
删除容器
docker rm 命令来删除不需要的容器
docker rm [容器id]
docker rm [容器name]
注:当删除运行中的容器时,需要先stop停止容器,再执行删除命令
本文主要介绍了使用docker搭建Python环境,以及对于docker拉取镜像,docker容器的主要操作,包括运行容器,停止容器,删除容器等。希望对大家学习docker能有所帮助。
