SpringCloud Stream消息驱动代码实战
yd_249383650 发表于 2023/03/27 09:23:50 2023/03/27
【摘要】 ​ 工程中新建三个子模块在7001端口使用eureka注册服务中心(自行准备)cloud-stream-rabbitmq-provider8801, 作为生产者进行发消息模块cloud-stream-rabbitmq-consumer8802,作为消息接收模块cloud-stream-rabbitmq-consumer8803  作为消息接收模块消息驱动之生产者新建Module:cloud-...
 工程中新建三个子模块
消息驱动之生产者
新建Module:cloud-stream-rabbitmq-provider8801
pom文件
版本已交给父工程控制
 <!-- 统一管理jar包版本 -->
    <!-- 统一管理jar包版本 -->
    <properties>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
        <maven.compiler.source>1.8</maven.compiler.source>
        <maven.compiler.target>1.8</maven.compiler.target>
        <junit.version>4.12</junit.version>
        <log4j.version>1.2.17</log4j.version>
        <lombok.version>1.16.18</lombok.version>
        <mysql.version>8.0.16</mysql.version>
        <druid.version>1.1.16</druid.version>
        <mybatis.spring.boot.version>1.3.0</mybatis.spring.boot.version>
    </properties>
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <parent>
        <artifactId>mscloud</artifactId>
        <groupId>com.atguigu.springcloud</groupId>
        <version>1.0-SNAPSHOT</version>
    </parent>
    <modelVersion>4.0.0</modelVersion>
    <artifactId>cloud-stream-rabbitmq-provider8801</artifactId>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-actuator</artifactId>
        </dependency>
        <dependency>
            <groupId>org.springframework.cloud</groupId>
            <artifactId>spring-cloud-starter-netflix-eureka-client</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-cloud-starter-stream-rabbit</artifactId>
        </dependency>
        <!--基础配置-->
        <dependency>
            <artifactId>spring-boot-devtools</artifactId>
            <scope>runtime</scope>
            <optional>true</optional>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
</project>
yml文件
server:
  port: 8801
spring:
  application:
  cloud:
      stream:
        binders: # 在此处配置要绑定的rabbitmq的服务信息;
          defaultRabbit: # 表示定义的名称,用于于binding整合
            type: rabbit # 消息组件类型
            environment: # 设置rabbitmq的相关的环境配置
              spring:
                rabbitmq:
                  host: localhost
                  port: 5672
                  username: guest
                  password: guest
        bindings: # 服务的整合处理
          output: # 这个名字是一个通道的名称
            destination: studyExchange # 表示要使用的Exchange名称定义
            content-type: application/json # 设置消息类型,本次为json,文本则设置“text/plain”
            binder: defaultRabbit # 设置要绑定的消息服务的具体设置
eureka:
  client: # 客户端进行Eureka注册的配置
    service-url:
      defaultZone: http://localhost:7001/eureka
  instance:
    lease-renewal-interval-in-seconds: 2 # 设置心跳的时间间隔(默认是30秒)
    lease-expiration-duration-in-seconds: 5 # 如果现在超过了5秒的间隔(默认是90秒)
    instance-id: send-8801.com  # 在信息列表时显示主机名称
    prefer-ip-address: true     # 访问的路径变为IP地址
  cloud:
      stream:
              spring:
                rabbitmq:
                  host: localhost
                  port: 5672
                  username: guest
                  password: guest
        bindings: # 服务的整合处理
 主启动类
@SpringBootApplication
public class StreamMQMain8801
    public static void main(String[] args)
        SpringApplication.run(StreamMQMain8801.class,args);
业务类
发送消息接口
public interface IMessageProvider
    public String send() ;
发送消息接口实现类
@EnableBinding(Source.class) // 可以理解为是一个消息的发送管道的定义
public class MessageProviderImpl implements IMessageProvider
    @Resource
    private MessageChannel output; // 消息的发送管道
    @Override
        String serial = UUID.randomUUID().toString();
        this.output.send(MessageBuilder.withPayload(serial).build()); // 创建并发送消息
        System.out.println("***serial: "+serial);
        return serial;
Controller
@RestController
public class SendMessageController
    @Resource
    private IMessageProvider messageProvider;
    @GetMapping(value = "/sendMessage")
    public String sendMessage()
        return messageProvider.send();
测试1:启动7001 8801服务
查看rabbitMQ界面查看
​编辑
访问
http://localhost:8801/sendMessage
​编辑
且可以在图形化界面中可以看到波峰起伏
​编辑
 消息驱动之消费者
新建Module:cloud-stream-rabbitmq-consumer8802
pom文件
    <parent>
    </parent>
    <dependencies>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <!--基础配置-->
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <dependency>
            <scope>test</scope>
        </dependency>
    </dependencies>
</project>
yml文件
server:
  port: 8802
spring:
  application:
  cloud:
      stream:
              spring:
                rabbitmq:
                  host: localhost
                  port: 5672
                  username: guest
                  password: guest
        bindings: # 服务的整合处理
          input: # 这个名字是一个通道的名称
            content-type: application/json # 设置消息类型,本次为对象json,如果是文本则设置“text/plain”
eureka:
    service-url:
  instance:
    instance-id: receive-8802.com  # 在信息列表时显示主机名称
  cloud:
      stream:
              spring:
                rabbitmq:
                  host: localhost
                  port: 5672
                  username: guest
                  password: guest
        bindings: # 服务的整合处理
主启动类
public class StreamMQMain8802
        SpringApplication.run(StreamMQMain8802.class,args);
业务类
@Component
@EnableBinding(Sink.class)
public class ReceiveMessageListener
    @Value("${server.port}")
    private String serverPort;
    @StreamListener(Sink.INPUT)
    public void input(Message<String> message)
        System.out.println("消费者1号,------->接收到的消息:" + message.getPayload()+"\t port: "+serverPort);
 测试2:
启动8801 8802 7001
8801控制台
​编辑
 8802控制台:
​编辑
依照8802,clone出来一份运行8803
除端口号不一样外,其他的一致,即该端口号为8803
测试3:
启动7001 8803 8802 8801
访问
可以看到由8801发送的消息被8802 8803都会消费
运行后有两个问题
有重复消费问题
消息持久化问题
重复消费问题
目前是8802/8803同时都收到了,存在重复消费问题
如何解决?分组和持久化属性group
比如在如下场景中,订单系统我们做集群部署,都会从RabbitMQ中获取订单信息,
那如果一个订单同时被两个服务获取到,那么就会造成数据错误,我们得避免这种情况。
这时我们就可以使用Stream中的消息分组来解决
​编辑
注意在Stream中处于同一个group中的多个消费者是竞争关系,就能够保证消息只会被其中一个应用消费一次。
不同组是可以全面消费的(重复消费),
同一组内会发生竞争关系,只有其中一个可以消费。
操作原理,进行操作
微服务应用放置于同一个group中,就能够保证消息只会被其中一个应用消费一次。
不同的组是可以消费的,同一个组内会发生竞争关系,只有其中一个可以消费。
修改8801的yml文件:
​编辑
增加分组group:atguiguA
 修改8802的yml文件:
​编辑
 增加分组group:atguiguB
测试4:
重复测试3还是一样的结果
现在的目的:
8802/8803实现轮询分组,每次只有一个消费者8801模块的发的消息只能被8802或8803其中一个接收到,这样避免了重复消费。
将8803的yml文件中分组修改成为:
  group: atguiguA
测试4:
重复测试3,在这次访问俩次 http://localhost:8801/sendMessage
8801控制台:
​编辑
 8802控制台:
​编辑
8803控制台:
​编辑 可以发现已经实现目的
持久化
 通过上述,解决了重复消费问题,再看看持久化
修改:
停止8802/8803并去除掉8802的分组group: atguiguA
8803的分组group: atguiguA没有去掉
测试6:
8801先发送4条消息到rabbitmq,即访问http://localhost:8801/sendMessage四次
8801控制台:
​编辑
先启动8802,无分组属性配置,后台没有打出来消息
8802控制台:
​编辑
再启动8803,有分组属性配置,后台打出来了MQ上的消息
​编辑
