浅谈Spring6之事务场景(注解方式)
QGS 发表于 2023/03/25 20:29:52 2023/03/25
【摘要】 浅谈Spring6之事务场景(注解方式)
以银行账户转账为案例
数据库表
spring6整合mybatis
pom.xml配置文件
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>org.example</groupId>
    <artifactId>spring6-transaction-bank</artifactId>
    <version>1.0-SNAPSHOT</version>
    <properties>
        <maven.compiler.source>17</maven.compiler.source>
        <maven.compiler.target>17</maven.compiler.target>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
    </properties>
    <!--    打包方式jar-->
    <packaging>jar</packaging>
    <!--配置多个仓库 -->
    <repositories>
        <!-- Spring6 -->
        <repository>
            <id>repository.spring.milestone</id>
            <name>Spring Milestone Repository</name>
            <url>https://repo.spring.io/milestone</url>
        </repository>
    </repositories>
    <!-- 依赖-->
    <dependencies>
<!--        @Resource注入注解-->
        <dependency>
            <groupId>jakarta.annotation</groupId>
            <artifactId>jakarta.annotation-api</artifactId>
            <version>2.1.0</version>
        </dependency>
        <!-- 引入Spring context依赖-->
        <dependency>
            <groupId>org.springframework</groupId>
            <artifactId>spring-context</artifactId>
            <version>6.0.0-M2</version>
        </dependency>
        <!--引入Spring-jdbc-->
        <dependency>
            <artifactId>spring-jdbc</artifactId>
        </dependency>
        <!--引入mysql驱动-->
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
            <version>8.0.17</version>
        </dependency>
        <!--引入mybatis依赖-->
        <dependency>
            <groupId>org.mybatis</groupId>
            <artifactId>mybatis</artifactId>
            <version>3.5.11</version>
        </dependency>
        <!--引入mybatis-spring依赖-->
        <dependency>
            <artifactId>mybatis-spring</artifactId>
            <version>3.0.1</version>
        </dependency>
        <!-- 引入德鲁伊连接池-->
        <dependency>
            <groupId>com.alibaba</groupId>
            <artifactId>druid</artifactId>
            <version>1.2.15</version>
        </dependency>
        <!-- Spring框架对Junit支持的依赖-->
        <dependency>
            <artifactId>spring-test</artifactId>
            <!--6.0.0-M2既支持junit4又支持junit5-->
        </dependency>
        <!--junit依赖-->
        <dependency>
            <groupId>org.junit.jupiter</groupId>
            <artifactId>junit-jupiter-api</artifactId>
            <version>5.8.2</version>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <resources>
            <resource>
                <!--所在的目录-->
                <directory>src/main/java</directory>
                <includes>
                    <!--包括目录下的.properties .xml文件都会扫描到-->
                    <include>**/*.properties</include>
                    <include>**/*.xml</include>
                </includes>
                <filtering>false</filtering>
            </resource>
        </resources>
    </build>
</project>
jdbc.properties文件
jdbc.driver=com.mysql.cj.jdbc.Driver
jdbc.url=jdbc:mysql://IP:3306/mysql
jdbc.user= root
jdbc.password= xxxxxx
mybatis-config.xml配置文件
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE configuration
        PUBLIC "-//mybatis.org//DTD Config 3.0//EN"
        "https://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration>
    <settings>
        <!-- logImpl设置mybatis输出日志-->
        <setting name="logImpl" value="STDOUT_LOGGING"/>
    </settings>
    <mappers>
        <package name="com.qgs.dao"/>
    </mappers>
</configuration>
SpringConfig.xml配置文件
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:context="http://www.springframework.org/schema/context"
       xmlns:tx="http://www.springframework.org/schema/tx"
       xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
                           http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context.xsd http://www.springframework.org/schema/tx http://www.springframework.org/schema/tx/spring-tx.xsd">
        <!--组件扫描-->
        <context:component-scan base-package="com.qgs"></context:component-scan>
        <!--引入外部文件-->
        <context:property-placeholder location="jdbc.properties"/>
        <!--声明数据来源-->
        <bean id="dateSource" class="com.alibaba.druid.pool.DruidDataSource">
                <property name="driverClassName" value="${jdbc.driver}"></property>
                <property name="url" value="${jdbc.url}"></property>
                <property name="username" value="${jdbc.user}"></property>
                <property name="password" value="${jdbc.password}"></property>
        </bean>
        <!--配置SqlSessionFactoryBean-->
        <bean id="factory" class="org.mybatis.spring.SqlSessionFactoryBean">
                <!--注入数据源-->
                <property name="dataSource" ref="dateSource"/>
                <!--指定Mybatis-config.xml主配置文件-->
                <property name="configLocation" value="mybatis-config.xml"/>
                <!--注入别名-->
                <property name="typeAliasesPackage" value="com.qgs.pojo"/>
        </bean>
                <!--扫描mapper配置器 SqlSession.Mapper()-->
        <bean class="org.mybatis.spring.mapper.MapperScannerConfigurer">
                <property name="sqlSessionFactoryBeanName" value="factory"></property>
                <property name="basePackage" value="com.qgs.dao"/>
        </bean>
                <!--事务管理器-->
        <bean id="TransactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
        </bean>
                <!--启动事务注解-->
        <tx:annotation-driven transaction-manager="TransactionManager"/>
</beans>
BankDao接口
public interface BankDao {
     * 根据账号查询账户信息
    List<Bank> selectAll();
     * 根据actno查询账户信息
     * @param actno
     * @return
    Bank selectByActno(String actno);
     * 更新账户信息
     * @param act
     * @return
    int update(Bank act);
BankDao.xml
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "https://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.qgs.dao.BankDao">
    <select id="selectAll" resultType="com.qgs.pojo.Bank">
        select * from bank
    </select>
    <select id="selectByActno" resultType="com.qgs.pojo.Bank">
        select actno,balance from bank where actno = #{actno}
    </select>
    <update id="update">
        update bank set  balance=#{balance}  where actno =#{actno}
    </update>
</mapper>
pojo实体类
package com.qgs.pojo;
 * @author QGS
 * @version 1.0.0
 * @date 2023年03月24日 16:36:58
 * @packageName com.qgs.pojo
 * @className Bank
 * @describe TODO
public class Bank {
    private String actno;
    private Double balance;
    public Bank() {
    public Bank(String actno, Double balance) {
        this.actno = actno;
        this.balance = balance;
    public String getActno() {
        return actno;
    public void setActno(String actno) {
        this.actno = actno;
    public Double getBalance() {
        return balance;
    public void setBalance(Double balance) {
    @Override
    public String toString() {
        return "Bank{" +
                "actno='" + actno + '\'' +
                ", balance=" + balance +
BankService 接口
public interface BankService {
     * 转账方法
     * @param fromActno 转出账户
     * @param toActno 转入账户
     * @param money 金额
    void transfer(String fromActno ,String toActno ,double money);
BankService 接口实现类
package com.qgs.service;
import com.qgs.dao.BankDao;
import com.qgs.pojo.Bank;
import jakarta.annotation.Resource;
import org.springframework.stereotype.Service;
import org.springframework.transaction.annotation.Propagation;
import org.springframework.transaction.annotation.Transactional;
 * @author QGS
 * @version 1.0.0
 * @date 2023年03月25日 11:15:24
 * @packageName com.qgs.service
 * @className BankServiceImpl
 * @describe TODO
@Service("bankServiceImpl")
//@Transactional
public class BankServiceImpl implements BankService{
    @Resource(name ="bankDao")
    private BankDao bankDao;
    @Override
    //@Transactional默认propagation = Propagation.REQUIRED
    @Transactional(propagation = Propagation.REQUIRED)
    public void transfer(String fromActno, String toActno, double money) {
        //查询转出账户余额
        Bank fromBank = bankDao.selectByActno(fromActno);
        if (fromBank.getBalance() <money){
            throw new RuntimeException("余额不足");
        //查询转入账户余额
        Bank toBank = bankDao.selectByActno(toActno);
        //将内存中转出与转入账户余额修改
        fromBank.setBalance(fromBank.getBalance() - money);
        toBank.setBalance(toBank.getBalance() + money);
        //更新数据库
        int count = bankDao.update(fromBank);
        int count2 = bankDao.update(toBank);
        count +=count2;
        if (count !=2){
            //回滚事务,转账失败
            throw new RuntimeException("失败");
@Test
    public void BankTest(){
        ApplicationContext applicationContext =new ClassPathXmlApplicationContext("SpringConfig.xml");
        BankService bankService = applicationContext.getBean("bankServiceImpl", BankService.class);
        try {
            bankService.transfer("act01","act2",300);
        }catch (Exception e){
            e.printStackTrace();
事务的传播行为
事务传播行为在spring框架中被定义为枚举类型。
事务的传播行为有7种:
REQUIRED:支持当前事务,如果不存在就新建一个(默认模式)
SUPPORTS:支持当前事务,如果当前没有事务,就以非事务方式执行。
MANDATORY:必须运行在一个事务中,如果当前没有事务正在发生,将抛出一个异常。
REQUIRES_NEW:开启一个新的事务,如果一个事务已经存在,则将这个存在的事务挂起。
NOT_SUPPORTED:以非事务方式运行,如果事务存在,挂起当前事务。
NEVER:以非事务方式运行,如果有事务存在,抛出异常。
NESTED:如果当前争优一个事务在进行中,则该方法应当运行一个嵌套事务中。被嵌套的事务可以单独于外层事务进行提交或回滚。如果外层事务不存在,行为就像REQUIRED。
spring事务隔离界别
数据库中读取数据存在的三大读问题
脏读:读取到没有提交的数据库的数据。
不可重复读:在同一个事务当中,第一次和第二次读取的数据不一样。
幻读:读到的数据是假的。(事务并发,一定存在幻读)
事务隔离级别的四个级别:
读未提交:READ_UNCOMMITTEN
	这种隔离级别:存在脏读问题,所谓的脏读(dirty read)表示能够读取到其他事务未提交的数据。
读提交:READ_COMMITTED		(oracle)
	解决了脏读问题,其他事务提交之后才能读到,但存在不可重复读问题
可重复读:REPEATABLE_READ     (MYSQL)
	解决了不可重复读,可以达到可重复读效果,只要当前事务不结束,读取到的数据移植都是一样的。但存在幻读问题。
序列化:SERIALLZABLE
	解决了幻读问题,事务排毒执行。不支持并发。
Spring事务超时
@Transactional(timeout = 10)   表示设置事务的超时时间为10秒。
超过10秒如果该事务所有的DML语句还没有执行完毕,最终选择回滚。
在当前事务中,最后一条DML语句执行之前的时间。最后一条DML语句后面还有很多业务逻辑(非DML语句),这些业务代码执行的时间不被记入超时时间
默认值为:timeout = -1 、表示没有时间限制。
Spring启动只读事务
@Transactional(readOnly = true)  作用:启动Spring优化策略,提高select语句执行效率
Spring事务设置异常回滚问题
设置RuntimeException异常时回滚
@Transactional(rollbackFor = RuntimeException.class)
设置NullPointerException异常不回滚
@Transactional(noRollbackFor = NullPointerException.class)
