ListView的数据更新问题
梦笔生花 发表于 2023/03/07 21:53:06 2023/03/07
【摘要】 1.先写个正常的demoentity类:Data.java/** * Created by Jay on 2015/9/21 0021. */public class Data { private int imgId; private String content; public Data() {} public Data(int imgId, String cont...
1.先写个正常的demo
entity类:Data.java
public class Data {
    private int imgId;
    public Data() {}
    public Data(int imgId, String content) {
        this.imgId = imgId;
        this.content = content;
    public int getImgId() {
        return imgId;
    public String getContent() {
        return content;
    public void setImgId(int imgId) {
        this.imgId = imgId;
    public void setContent(String content) {
Activity布局以及列表项布局:
activity_main.xml:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:tools="http://schemas.android.com/tools"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:orientation="vertical"
    tools:context=".MainActivity">
    <ListView
        android:id="@+id/list_one"
        android:layout_height="match_parent" />
</LinearLayout>
item_list.xml:
    android:orientation="horizontal">
    <ImageView
        android:id="@+id/img_icon"
        android:layout_width="56dp"
        android:layout_height="56dp"/>
    <TextView
        android:id="@+id/txt_content"
        android:layout_width="wrap_content"
        android:layout_height="wrap_content"
        android:layout_marginTop="20dp"
        android:layout_marginLeft="10dp"
        android:textSize="18sp" />
</LinearLayout>
自定义BaseAdapter的实现:MyAdapter.java:
public class MyAdapter extends BaseAdapter {
    private Context mContext;
    private LinkedList<Data> mData;
    public MyAdapter() {}
    public MyAdapter(LinkedList<Data> mData, Context mContext) {
        this.mData = mData;
        this.mContext = mContext;
    @Override
    public int getCount() {
        return mData.size();
    @Override
    public Object getItem(int position) {
        return null;
    @Override
    public long getItemId(int position) {
        return position;
    @Override
    public View getView(int position, View convertView, ViewGroup parent) {
        ViewHolder holder = null;
        if(convertView == null){
            convertView = LayoutInflater.from(mContext).inflate(R.layout.item_list,parent,false);
            holder = new ViewHolder();
            holder.img_icon = (ImageView) convertView.findViewById(R.id.img_icon);
            holder.txt_content = (TextView) convertView.findViewById(R.id.txt_content);
            convertView.setTag(holder);
        }else{
            holder = (ViewHolder) convertView.getTag();
        holder.img_icon.setImageResource(mData.get(position).getImgId());
        holder.txt_content.setText(mData.get(position).getContent());
        return convertView;
    private class ViewHolder{
        ImageView img_icon;
        TextView txt_content;
MainActivity.java的编写:
public class MainActivity extends AppCompatActivity {
    private ListView list_one;
    private MyAdapter mAdapter = null;
    private List<Data> mData = null;
    private Context mContext = null;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mContext = MainActivity.this;
        bindViews();
        mData = new LinkedList<Data>();
        mAdapter = new MyAdapter((LinkedList<Data>) mData,mContext);
        list_one.setAdapter(mAdapter);
    private void bindViews(){
        list_one = (ListView) findViewById(R.id.list_one);
可以运行,运行后发现我们的页面并没有任何的数据,白茫茫的一片,这样的用户体验并不好, 我们可以通过调用ListView的一个setEmptyView(View)的方法,当ListView数据为空的时候, 显示一个对应的View,另外发现这个方法很奇葩,动态添加的View,竟然无效,只能在ListView 所在的布局文件中添加当ListView无数据时,想显示的View,另外用这个setEmptyView设置后的 View,加载的时候竟然不会显示出来,好灵异....比如这里的是没有数据时显示一个没有数据 的TextView,部分代码如下
<TextView
        android:id="@+id/txt_empty"
        android:layout_gravity="center"
        android:textSize="15pt"
        android:textColor="#000000"/>
txt_empty = (TextView) findViewById(R.id.txt_empty);
txt_empty.setText("暂无数据~");
list_one.setEmptyView(txt_empty);
当然除了这种方法外我们还可以定义一个与ListView一样大小位置的布局,然后设置, android:visibility="gone",在Java代码中对mData集合的size进行判断,如果==0, 说明没数据,让这个布局显示出来,当有数据的时候让这个布局隐藏~
2.添加一条记录
好的,我们弄个添加按钮,没按一次添加一条记录哈~
运行效果图:
代码实现
在我们自定义的BaseAdapter中定义一个方法,方法内容如下:
public void add(Data data) {
    if (mData == null) {
        mData = new LinkedList<>();
    mData.add(data);
    notifyDataSetChanged();
然后布局自己加个按钮,然后设置下事件,代码如下:
private Button btn_add;
btn_add = (Button) findViewById(R.id.btn_add);
btn_add.setOnClickListener(this);
@Override
public void onClick(View v) {
    switch (v.getId()){
        case R.id.btn_add:
            mAdapter.add(new Data(R.mipmap.ic_icon_qitao,"给猪哥跪了~~~ x " + flag));
            flag++;
            break;
嘿嘿,成了,添加数据就这么简单~,如果你想插入到特定位置,也行,我们Adapter类里,再另外 写一个方法:
//往特定位置,添加一个元素
public void add(int position,Data data){
    mData.add(position,data);
然后加个按钮,写个事件:
private Button btn_add2;
btn_add2 = (Button) findViewById(R.id.btn_add2);
btn_add2.setOnClickListener(this);
case R.id.btn_add2:
//position从0开始算的
mAdapter.add(4,new Data(R.mipmap.ic_icon_qitao,"给猪哥跪了~~~ x " + flag));
break;
运行效果图:
可以看到我们的第九项插入到了第五个位置
3.删除某一项
同样的,我们写两个方法,一个直接删对象,一个根据游标来删:
public void remove(Data data) {
    if(mData != null) {
        mData.remove(data);
public void remove(int position) {
    if(mData != null) {
        mData.remove(position);
然后加两个Button,调用下这两个方法:
case R.id.btn_remove:
    mAdapter.remove(mData_5);
    break;
case R.id.btn_remove2:
    mAdapter.remove(2);
    break;
运行效果图:
从图中我们可以看到,第五项被移除了,然后点击游标删除数据,一直删的是第三项!
4.移除所有的记录:
这个更加简单,直接调用clear方法即可!方法代码如下:
public void clear() {
    if(mData != null) {
        mData.clear();
5.更新某一个记录
细心的你应该发现了,进行了数据修改操作后,都会调用一个notifyDataSetChanged(); 一开始我以为:
notifyDataSetChanged()会把界面上现实的的item都重绘一次,这样会影响ui性能吧,如果数据量 很大,但是我改变一项就要重新绘制所有的item,这肯定不合理是吧!于是乎,我用了一个傻办法 来修改某个Item中控件的值,我在Java代码中写了这样一段代码:
private void updateListItem(int postion,Data mData){
    int visiblePosition = list_one.getFirstVisiblePosition();
    View v = list_one.getChildAt(postion - visiblePosition);
    ImageView img = (ImageView) v.findViewById(R.id.img_icon);
    TextView tv = (TextView) v.findViewById(R.id.txt_content);
    img.setImageResource(mData.getImgId());
    tv.setText(mData.getContent());
notifyDataSetChanged()方法会判断是否需要重新渲染,如果当前item没有必要重新渲染 是不会重新渲染的,如果某个Item的状态发生改变,都会导致View的重绘,而重绘的并不是 所有的Item,而是View状态发生变化的那个Item!所以我们直接notifyDataSetChange()方法 即可,当然知道多一个上面的方法也没什么。
代码下载:
ListViewDemo3.zip
