ListView简单实用
梦笔生花 发表于 2023/03/05 20:13:02 2023/03/05
【摘要】 1.自定义BaseAdapter,绑定ListView的最简单例子先看看我们要实现的效果图:一个很简单的ListView,自己写下Item,然后加载点数据这样~ 下面贴下关键代码:Animal.java:/** * Created by Jay on 2015/9/18 0018. */public class Animal { private String aName; pri...
先看看我们要实现的效果图:
Animal.java:
    private String aSpeak;
    private int aIcon;
    public Animal() {
    public Animal(String aName, String aSpeak, int aIcon) {
        this.aName = aName;
        this.aSpeak = aSpeak;
        this.aIcon = aIcon;
    public String getaName() {
        return aName;
    public String getaSpeak() {
        return aSpeak;
    public int getaIcon() {
        return aIcon;
    public void setaName(String aName) {
        this.aName = aName;
    public void setaSpeak(String aSpeak) {
    public void setaIcon(int aIcon) {
        this.aIcon = aIcon;
AnimalAdapter.java:自定义的BaseAdapter:
public class AnimalAdapter extends BaseAdapter {
    private LinkedList<Animal> mData;
    private Context mContext;
    public AnimalAdapter(LinkedList<Animal> mData, Context mContext) {
        this.mData = mData;
        this.mContext = mContext;
    @Override
    public int getCount() {
        return mData.size();
    @Override
    public Object getItem(int position) {
        return null;
    @Override
    public long getItemId(int position) {
        return position;
    @Override
    public View getView(int position, View convertView, ViewGroup parent) {
        convertView = LayoutInflater.from(mContext).inflate(R.layout.item_list_animal,parent,false);
        ImageView img_icon = (ImageView) convertView.findViewById(R.id.img_icon);
        TextView txt_aName = (TextView) convertView.findViewById(R.id.txt_aName);
        TextView txt_aSpeak = (TextView) convertView.findViewById(R.id.txt_aSpeak);
        img_icon.setBackgroundResource(mData.get(position).getaIcon());
        txt_aName.setText(mData.get(position).getaName());
        txt_aSpeak.setText(mData.get(position).getaSpeak());
        return convertView;
最后是MainActivity.java:
public class MainActivity extends AppCompatActivity {
    private List<Animal> mData = null;
    private AnimalAdapter mAdapter = null;
    private ListView list_animal;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        mContext = MainActivity.this;
        list_animal = (ListView) findViewById(R.id.list_animal);
        mData = new LinkedList<Animal>();
        mData.add(new Animal("狗说", "你是狗么?", R.mipmap.ic_icon_dog));
        mData.add(new Animal("牛说", "你是牛么?", R.mipmap.ic_icon_cow));
        mData.add(new Animal("鸭说", "你是鸭么?", R.mipmap.ic_icon_duck));
        mData.add(new Animal("鱼说", "你是鱼么?", R.mipmap.ic_icon_fish));
        mData.add(new Animal("马说", "你是马么?", R.mipmap.ic_icon_horse));
        mAdapter = new AnimalAdapter((LinkedList<Animal>) mData, mContext);
        list_animal.setAdapter(mAdapter);
好的,自定义BaseAdapter以及完成数据绑定就是这么简单~别问我拿示例的代码,刚开始学就会写出这些代码,我只是演示下流程,让大家熟悉而已。另外,也是为下面的属性验证做准备。
2.表头表尾分割线的设置:
listview作为一个列表控件,他和普通的列表一样,可以自己设置表头与表尾: 以及分割线,可供我们设置的属性如下:
  • footerDividersEnabled:是否在footerView(表尾)前绘制一个分隔条,默认为true
  • headerDividersEnabled:是否在headerView(表头)前绘制一个分隔条,默认为true
  • divider:设置分隔条,可以用颜色分割,也可以用drawable资源分割
  • dividerHeight:设置分隔条的高度
翻遍了了API发现并没有可以直接设置ListView表头或者表尾的属性,只能在Java中写代码 进行设置了,可供我们调用的方法如下:
  • addHeaderView(View v):添加headView(表头),括号中的参数是一个View对象
  • addFooterView(View v):添加footerView(表尾),括号中的参数是一个View对象
  • addHeaderView(headView, null, false):和前面的区别:设置Header是否可以被选中
  • addFooterView(View,view,false):同上
对了,使用这个addHeaderView方法必须放在listview.setAdapter前面,否则会报错。
使用示例:
运行效果图:
代码实现:
先编写下表头与表尾的布局:
view_header.xml(表头),表尾一样,就不贴了:
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="match_parent"
    android:layout_height="match_parent"
    android:orientation="vertical"
    android:gravity="center">
    <TextView
        android:layout_height="48dp"
        android:textSize="18sp"
        android:text="表头"
        android:background="#43BBEB"
        android:textColor="#FFFFFF"/>
</LinearLayout>
MainActivty.java:
public class MainActivity extends AppCompatActivity implements AdapterView.OnItemClickListener{
    private LinearLayout ly_content;
    @Override
        //动态加载顶部View和底部View
        final LayoutInflater inflater = LayoutInflater.from(this);
        View headView = inflater.inflate(R.layout.view_header, null, false);
        View footView = inflater.inflate(R.layout.view_footer, null, false);
        //添加表头和表尾需要写在setAdapter方法调用之前!!!
        list_animal.addHeaderView(headView);
        list_animal.addFooterView(footView);
        list_animal.setOnItemClickListener(this);
    @Override
    public void onItemClick(AdapterView<?> parent, View view, int position, long id) {
        Toast.makeText(mContext,"你点击了第" + position + "项",Toast.LENGTH_SHORT).show();
好的,代码还是比较简单的,从上面我们看出来一个要注意的问题,就是:
添加表头表尾后,我们发现positon是从表头开始算的,就是你添加的第一个数据本来的 postion 是 0,但是此时却变成了 1,因为表头也算!!
3.列表从底部开始显示:stackFromBottom
如果你想让列表显示你列表的最下面的话,那么你可以使用这个属性,将stackFromBottom 属性设置为true即可,设置后的效果图如下:
4.设置点击颜色cacheColorHint
如果你为ListView设置了一个图片作为Background的话,当你拖动或者点击listView空白位置会发现 item都变成黑色了,这是时候我们可以通过这个cacheColorHint将颜色设置为透明:#00000000
5.隐藏滑动条
我们可以通过设置:android:scrollbars="none" 或者 setVerticalScrollBarEnabled(true); 解决这个问题!
