手牵手入门Spring6整合Mybatis3.5
QGS 发表于 2023/02/28 23:15:35 2023/02/28
【摘要】 手牵手入门Spring6整合Mybatis3.5
方式一
Object类
get和set,无参构造+有参构造
Pom.xml引入依赖
<!--    打包方式jar-->
<packaging>jar</packaging>
<!--配置多个仓库 -->
<repositories>
    <!-- Spring6 -->
    <repository>
        <id>repository.spring.milestone</id>
        <name>Spring Milestone Repository</name>
        <url>https://repo.spring.io/milestone</url>
    </repository>
</repositories>
<!-- 依赖-->
<dependencies>
    <!-- 引入Spring context依赖-->
    <dependency>
        <groupId>org.springframework</groupId>
        <artifactId>spring-context</artifactId>
        <version>6.0.0-M2</version>
    </dependency>
    <!--引入Spring-jdbc-->
    <dependency>
        <artifactId>spring-jdbc</artifactId>
    </dependency>
    <!--引入mysql驱动-->
    <dependency>
        <groupId>mysql</groupId>
        <artifactId>mysql-connector-java</artifactId>
        <version>8.0.17</version>
    </dependency>
    <!--引入mybatis依赖-->
    <dependency>
        <groupId>org.mybatis</groupId>
        <artifactId>mybatis</artifactId>
        <version>3.5.11</version>
    </dependency>
    <!--引入mybatis-spring依赖-->
    <dependency>
        <artifactId>mybatis-spring</artifactId>
        <version>3.0.1</version>
    </dependency>
    <!-- 引入德鲁伊连接池-->
    <dependency>
        <groupId>com.alibaba</groupId>
        <artifactId>druid</artifactId>
        <version>1.2.15</version>
    </dependency>
    <!-- Spring框架对Junit支持的依赖-->
    <dependency>
        <artifactId>spring-test</artifactId>
        <!--6.0.0-M2既支持junit4又支持junit5-->
    </dependency>
    <!--junit依赖-->
    <dependency>
        <groupId>org.junit.jupiter</groupId>
        <artifactId>junit-jupiter-api</artifactId>
        <version>5.8.2</version>
        <scope>test</scope>
    </dependency>
    <dependency>
        <groupId>org.example</groupId>
        <artifactId>review-annotation</artifactId>
        <version>1.0-SNAPSHOT</version>
        <scope>test</scope>
    </dependency>
    <!--   @Resource注解的依赖-->
    <dependency>
        <groupId>jakarta.annotation</groupId>
        <artifactId>jakarta.annotation-api</artifactId>
        <version>2.1.0</version>
    </dependency>
</dependencies>
Dao层
public interface TTTDao {
    //查询所有
    List<TTT11> selectAll();
    //插入
    int insert(TTT11 ttt11);
    //通过id删除
    int deleteById(int id);
    //更新
    int update(TTT11 ttt11);
myabtis-Mapper配置文件
<?xml version="1.0" encoding="UTF-8" ?>
<!DOCTYPE mapper
        PUBLIC "-//mybatis.org//DTD Mapper 3.0//EN"
        "https://mybatis.org/dtd/mybatis-3-mapper.dtd">
<mapper namespace="com.bank.dao.TTTDao">
    <select id="selectAll" resultType="com.bank.object.TTT11">
        select id,name,address from TTT11
    </select>
    <insert id="insert">
        insert into TTT11 values(#{id},#{name},#{address})
    </insert>
    <delete id="deleteById" >
        delete from TTT11 where id = #{id}
    </delete>
    <update id="update">
        update TTT11 set address =#{address} where id=#{id}
    </update>
</mapper>
编写jdbc.properties文件和Mybatis.xml核心配置文件
jdbc.properties
jdbc.driver=com.mysql.cj.jdbc.Driver
jdbc.url=jdbc:mysql://IP:3306/mysql?
jdbc.user= root
jdbc.password= 111111
Mybatis.xml主配置文件
<!DOCTYPE configuration
        PUBLIC "-//mybatis.org//DTD Config 3.0//EN"
        "https://mybatis.org/dtd/mybatis-3-config.dtd">
<configuration>
    <!--settings控制mybatis全局行为-->
    <settings>
        <!-- logImpl设置mybatis输出日志-->
        <setting name="logImpl" value="STDOUT_LOGGING"/>
    </settings>
</configuration>
Service接口和serviceimp
接口
public interface TTTService {
    int save(TTT11 ttt11);
    int delecyById(int id);
实现类
@Transactional
@Service("tTTService")
public class TTTServiceimpl implements TTTService {
    @Resource
    private TTTDao tttDao;
    @Override
    public int save(TTT11 ttt11) {
        return tttDao.insert(ttt11);
    @Override
    public int delecyById(int id) {
        return tttDao.deleteById(id);
    @Override
    public List<TTT11> selectAll() {
        return tttDao.selectAll();
    @Override
    public int update(TTT11 ttt11) {
        return tttDao.update(ttt11);
Spring.xml配置
<beans xmlns="http://www.springframework.org/schema/beans"
       xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
       xmlns:context="http://www.springframework.org/schema/context" xmlns:tx="http://www.springframework.org/schema/tx"
       xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
                           http://www.springframework.org/schema/context http://www.springframework.org/schema/context/spring-context.xsd http://www.springframework.org/schema/tx http://www.springframework.org/schema/tx/spring-tx.xsd">
        <context:component-scan base-package="com.bank"></context:component-scan>
        <!--引入外部文件-->
        <context:property-placeholder location="jdbc.properties"/>
        <bean id="dateSource" class="com.alibaba.druid.pool.DruidDataSource">
                <property name="driverClassName" value="${jdbc.driver}"></property>
                <property name="url" value="${jdbc.url}"></property>
                <property name="username" value="${jdbc.user}"></property>
                <property name="password" value="${jdbc.password}"></property>
        </bean>
        <!--配置SqlSessionFactoryBean-->
        <bean class="org.mybatis.spring.SqlSessionFactoryBean">
        <!--注入数据源-->
                <property name="dataSource" ref="dateSource"/>
                <!--指定Mybatis-config.xml文件-->
                <property name="configLocation" value="mybatis-config.xml"/>
               <!--注册实体类-->
                <property name="typeAliasesPackage" value="com.bank.object"/>
        </bean>
                <!--扫描mapper配置器-->
        <bean class="org.mybatis.spring.mapper.MapperScannerConfigurer">
                <property name="basePackage" value="com.bank.dao"/>
        </bean>
                <!--事务管理器-->
        <bean id="TransactionManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
        </bean>
<!--        启动事务注解-->
        <tx:annotation-driven transaction-manager="TransactionManager"/>
</beans>
测试类
public class springMybatisTest {
    @Test
    public void sMybatisTest(){
        ApplicationContext applicationContext =new ClassPathXmlApplicationContext("SpringConfig.xml");
        TTTService tTTService = applicationContext.getBean("tTTService", TTTService.class);
        tTTService.selectAll();
方式二
pom.xml配置
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <artifactId>spring6mybatis</artifactId>
    <properties>
        <maven.compiler.source>17</maven.compiler.source>
        <maven.compiler.target>17</maven.compiler.target>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
    </properties>
    <!--    打包方式jar-->
    <!--配置多个仓库 -->
    <repositories>
        <!-- Spring6 -->
        <repository>
        </repository>
    </repositories>
    <!-- 依赖-->
    <dependencies>
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <!--引入mysql驱动-->
        <dependency>
        </dependency>
        <!--引入mybatis依赖-->
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <!-- 引入德鲁伊连接池-->
        <dependency>
        </dependency>
        <dependency>
        </dependency>
        <!--junit依赖-->
        <dependency>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <resources>
            <resource>
                <!--所在的目录-->
                <directory>src/main/java</directory>
                <includes>
                    <!--包括目录下的.properties .xml文件都会扫描到-->
                    <include>**/*.properties</include>
                    <include>**/*.xml</include>
                </includes>
                <filtering>false</filtering>
            </resource>
        </resources>
    </build>
</project>
实体类
get、set、toString、无参有参构造方法。
接口
    //查询所有
mapper.xml文件
<!DOCTYPE mapper
<mapper namespace="com.dao.TTTDao">
    <select id="selectAll" resultType="com.object.TTT11">
    </select>
    </insert>
    </delete>
    </update>
</mapper>
Service接口和实现类
    public TTTServiceimpl(TTTDao tttDao) {
        this.tttDao = tttDao;
    @Override
jdbc.properties
jdbc.user= root
mybatis-config.xml主配置文件
<configuration>
    <settings>
    </settings>
    <mappers>
        <package name="com.dao"/>
    </mappers>
</configuration>
SpringConfig.xml配置文件
<!--        组件扫描-->
        <context:component-scan base-package="com"></context:component-scan>
        <!--引入外部文件-->
<!--        声明数据来源-->
        </bean>
        <bean id="factory" class="org.mybatis.spring.SqlSessionFactoryBean">
                <!--注入数据源-->
                <!--指定Mybatis-config.xml主配置文件-->
               <!--注册实体类-->
                <property name="typeAliasesPackage" value="com.object"/>
        </bean>
                <!--扫描mapper配置器 SqlSession.Mapper()-->
                <property name="sqlSessionFactoryBeanName" value="factory"></property>
                <property name="basePackage" value="com.dao"/>
        </bean>
        <bean id="tttServiceimpl" class="com.service.TTTServiceimpl">
                <!--构造注入-->
                <constructor-arg index="0" ref="TTTDao"></constructor-arg>
        </bean>
                <!--事务管理器-->
        </bean>
<!--        启动事务注解-->
</beans>
测试类
public class smtest {
    @Test
    public void test(){
        TTTService tttServiceimpl = applicationContext.getBean("tttServiceimpl", TTTService.class);
        tttServiceimpl.selectAll();
