【愚公系列】2023年02月 .NET/C#知识点-数组复制总结
愚公搬代码 发表于 2023/02/28 22:49:20 2023/02/28
【摘要】 前言C#中有多维数组和交错数组多维数组:就是m×n的矩阵,m行n列交错数组:有m行,但是每一行不一定是n列 1.多维数组C# 里的多维数组 (Multi-dimensional Array) 是这样的byte[,] arr = new byte[10, 10];案例int row = 5;int column = 5;int[,] matrix = new int[row, column]...
前言
C#中有多维数组和交错数组
  • 多维数组:就是m×n的矩阵,m行n列
  • 交错数组:有m行,但是每一行不一定是n列
1.多维数组
案例
int row = 5;
int column = 5;
int[,] matrix = new int[row, column];
//初始化
for (int i = 0; i < row; i++)
    for (int j = 0; j < column; j++)
        matrix[i, j] = (i + 1) * 10 + j + 1;
//输出
Console.WriteLine("该二维数组有:{0}行{1}列!", matrix.GetLength(1), matrix.GetLength(1));
        Console.Write(matrix[i, j] + " ");
    Console.Write('\n');
2.交错数组
C# 里的交错数组 (Jagged Array),就是数组里面套着数组
byte[][] arr = new byte[10][];
案例
int row = 5;
//交错数组空间的申请
int[][] matrix = new int[row][];
    matrix[i] = new int[i + 1];
//数据初始化
for (int i = 0; i < matrix.Length; i++)
    for (int j = 0; j < matrix[i].Length; j++)
        matrix[i][j] = (i + 1) * 10 + j + 1;
//数据输出
        Console.Write(matrix[i][j] + " ");
Console.ReadLine();
一、数组复制总结
定义一下常量,SIZE 表示数组大小,COUNT 表示等会要做拷贝测试的循环次数
//SIZE = 32 << 20  相当于 32的二进制数后面补20个0,相当于 32 * 2 ^ 20
const int COUNT = 32, SIZE = 32 << 20;
1.Array.Clone
在C#中,只要实现了 ICloneable 接口的对象,就有 Clone 方法
byte[]
    dSource = new byte[SIZE],
    dTarget = new byte[SIZE];
var sw = Stopwatch.StartNew();
sw.Start();
for (var i = 0; i < COUNT; i++)
    dTarget = (byte[])dSource.Clone();
sw.Stop();
Console.WriteLine("Array.Clone: {0:N0} ticks, {1} ms", sw.ElapsedTicks, sw.ElapsedMilliseconds);
2.Linq
Linq的原理一个个元素遍历,再重新构造个新的数组
byte[]
    eSource = new byte[SIZE],
    eTarget = new byte[SIZE];
var sw1 = Stopwatch.StartNew();
sw1.Start();
eTarget = eSource.Select(x => x).ToArray();
sw1.Stop();
Console.WriteLine("Array.Clone: {0:N0} ticks, {1} ms", sw1.ElapsedTicks, sw1.ElapsedMilliseconds);
3.Array.Copy
//-------------------------------------3.Array.Copy----------------------------------------------------
byte[]
    cSource = new byte[SIZE],
    cTarget = new byte[SIZE];
var sw2 = Stopwatch.StartNew();
sw2.Start();
//Array.Copy(cSource, 0, cTarget, 0, SIZE);
Array.Copy(cSource, cTarget, SIZE);
sw2.Stop();
Console.WriteLine("Array.Copy: {0:N0} ticks, {1} ms", sw2.ElapsedTicks, sw2.ElapsedMilliseconds);
4.Buffer.BlockCopy
byte[]
    bSource = new byte[SIZE],
    bTarget = new byte[SIZE];
var sw3 = Stopwatch.StartNew();
sw3.Start();
Buffer.BlockCopy(bSource, 0, bTarget, 0, SIZE);
sw3.Stop();
Console.WriteLine("Buffer.BlockCopy: {0:N0} ticks, {1} ms", sw3.ElapsedTicks, sw3.ElapsedMilliseconds);
5.Buffer.MemoryCopy
使用这个方法需要开启非安全访问
第一步:在你需要启用不安全代码的项目上点击右键,然后选择编辑项目文件:
第二步:在你的项目文件的属性组中添加一行 <AllowUnsafeBlocks>true</AllowUnsafeBlocks>:
//-------------------------------------5.Buffer.MemoryCopy----------------------------------------------------
TestBufferMemoryCopy();
static unsafe void TestBufferMemoryCopy()
    byte[]
    fSource = new byte[SIZE],
    fTarget = new byte[SIZE];
    var sw4 = Stopwatch.StartNew();
    sw4.Start();
    fixed (byte* pSrc = fSource, pDest = fTarget)
        for (int i = 0; i < COUNT; i++)
            Buffer.MemoryCopy(pSrc, pDest, SIZE, SIZE);
    sw4.Stop();
    Console.WriteLine("Buffer.MemoryCopy: {0:N0} ticks, {1} ms", sw4.ElapsedTicks, sw4.ElapsedMilliseconds);
2、运行
性能测试结果如下
可以看到Buffer.BlockCopy性能是最好的。
