【愚公系列】2023年02月 .NET CORE工具案例-WebWindow的使用
愚公搬代码 发表于 2023/02/28 22:35:48 2023/02/28
【摘要】 前言WebWindow顾名思义就是Windows中的web。WebWindow是跨平台的库,要运行WebWindow必须有以下条件:Windows – 需要基于Chromium的EdgeLinux – 使用WebKitMac – 需要Safari必须是预览版Edge下载地址:https://www.microsoft.com/en-us/edge/business/downloadWebW...
前言
  • Windows – 需要基于Chromium的Edge
  • Linux – 使用WebKit
  • Mac – 需要Safari
WebWindow官网:https://github.com/SteveSandersonMS/WebWindow
还有另一个库,这边不做详细介绍,WebWindowNetCore官网:https://github.com/uriegel/WebWindowNetCore
一、WebWindowNetCore的使用
1.安装包
NuGet\Install-Package WebWindow -Version 0.1.0-20200807.1
2.基于html的运行
using WebWindows;
var window = new WebWindow("My super app");
window.NavigateToString("<h1>Hello, world!</h1> This window is from a .NET Core app.");
window.WaitForExit();
3.基于vue的运行
class Program
        static void Main(string[] args)
            var window = new WebWindow(".NET Core + Vue.js file explorer");
            window.OnWebMessageReceived += HandleWebMessageReceived;
            window.NavigateToLocalFile("wwwroot/index.html");
        static void HandleWebMessageReceived(object sender, string message)
            var window = (WebWindow)sender;
            var parsedMessage = JsonDocument.Parse(message).RootElement;
            switch (parsedMessage.GetProperty("command").GetString())
                case "ready":
                    ShowDirectoryInfo(window, Directory.GetCurrentDirectory());
                    break;
                case "navigateTo":
                    var basePath = parsedMessage.GetProperty("basePath").GetString();
                    var relativePath = parsedMessage.GetProperty("relativePath").GetString();
                    var destinationPath = Path.GetFullPath(Path.Combine(basePath, relativePath)).TrimEnd(Path.DirectorySeparatorChar);
                    ShowDirectoryInfo(window, destinationPath);
                    break;
                case "showFile":
                    var fullName = parsedMessage.GetProperty("fullName").GetString();
                    ShowFileContents(window, fullName);
                    break;
        static void ShowDirectoryInfo(WebWindow window, string path)
            window.Title = Path.GetFileName(path);
            var directoryInfo = new DirectoryInfo(path);
            SendCommand(window, "showDirectory", new
                name = path,
                isRoot = Path.GetDirectoryName(path) == null,
                directories = directoryInfo.GetDirectories().Select(directoryInfo => new
                    name = directoryInfo.Name + Path.DirectorySeparatorChar,
                files = directoryInfo.GetFiles().Select(fileInfo => new
                    name = fileInfo.Name,
                    size = fileInfo.Length,
                    fullName = fileInfo.FullName,
        private static void ShowFileContents(WebWindow window, string fullName)
            var fileInfo = new FileInfo(fullName);
            SendCommand(window, "showFile", null); // Clear the old display first
            SendCommand(window, "showFile", new
                text = ReadTextFile(fullName, maxChars: 100000),
        private static string ReadTextFile(string fullName, int maxChars)
            var stringBuilder = new StringBuilder();
            var buffer = new char[4096];
            using (var file = File.OpenText(fullName))
                int charsRead = int.MaxValue;
                while (maxChars > 0 && charsRead > 0)
                    charsRead = file.ReadBlock(buffer, 0, Math.Min(maxChars, buffer.Length));
                    stringBuilder.Append(buffer, 0, charsRead);
                    maxChars -= charsRead;
                return stringBuilder.ToString();
        static void SendCommand(WebWindow window, string commandName, object arg)
            window.SendMessage(JsonSerializer.Serialize(new { command = commandName, arg = arg }));
4.基于Blazor的运行
Blazor 是可以和 JS 互操作的,不需要底层通信API
    ComponentsDesktop.Run<Startup>("My Blazor App", "wwwroot/index.html");
5.相关介绍
相关API介绍:
  • NavigateToString(html) 从硬编码的 .NET 字符串渲染 HTML
  • NavigateToUrl(url) 来显示来自 HTTP 服务器的内容(本地或远程)
  • NavigateToLocalFile(path) 来显示来自本地磁盘的 HTML 文件,其中 path是绝对路径或相对于当前工作目录的路径。
运行中的web程序通信方式如下:
  • JS中和.NET通信:window.external.sendMessage/receiveMessage
  • .NET中和JS通信:webWindowInstance.SendMessage/webWindowInstance.OnWebMessageReceived
