熵速率定义与各类熵的关系
timerring 发表于 2023/02/23 11:51:52 2023/02/23
【摘要】 本专栏包含信息论与编码的核心知识,按知识点组织,可作为教学或学习的参考。markdown版本已归档至【Github仓库:information-theory】,需要的朋友们自取。或者公众号【AIShareLab】回复 信息论 也可获取。 熵速率 (entropy rate)定义:一个平稳的时域离散随机过程的熵速率 (entropy rate) 定义为H=lim⁡n→∞H(Xn∣X1,X2,…...
熵速率 (entropy rate)
H = lim ⁡ n → ∞ H ( X n ∣ X 1 , X 2 , … , X n − 1 ) H=\lim _{n \rightarrow \infty} H(X_{n} \mid X_{1}, X_{2}, \ldots, X_{n-1})
具有记忆性的信源的熵速率定义为
H = lim ⁡ n → ∞ 1 n H ( X 1 , X 2 , … , X n ) H=\lim _{n \rightarrow \infty} \frac{1}{n} H\left(X_{1}, X_{2}, \ldots, X_{n}\right)
Example 两个二进制随机变量 X \mathbf{X} 和 Y \mathbf{Y} , 其联合分布为 p(X=Y=0) = p( X=0, Y=1) = p( X=Y=1) = 1/3 。
计算 H ( X ) H(X) , H ( Y ) H(Y) , H ( X ∣ Y ) H(X \mid Y) , H ( Y ∣ X ) H(Y \mid X) , and H ( X , Y ) H(X, Y) 。
Solution:
p ( X = 0 ) = p ( X = 0 , Y = 0 ) + p ( X = 0 , Y = 1 ) = 2 3 p ( X = 1 ) = p ( X = 1 , Y = 0 ) + p ( X = 1 , Y = 1 ) = 1 3 p ( Y = 0 ) = p ( X = 0 , Y = 0 ) + p ( X = 1 , Y = 0 ) = 1 3 p ( Y = 1 ) = p ( X = 0 , Y = 1 ) + p ( X = 1 , Y = 1 ) = 2 3 H ( X ) = 1 3 log ⁡ 3 + 2 3 log ⁡ 3 2 = 0.9183 H ( Y ) = 1 3 log ⁡ 3 + 2 3 log ⁡ 3 2 = 0.9183 H ( X , Y ) = ∑ i = 1 n p ( X , Y ) log ⁡ ( X , Y ) = log ⁡ 3 = 1.585 H ( X ∣ Y ) = H ( X , Y ) − H ( Y ) = 0.6667 H ( Y ∣ X ) = H ( X , Y ) − H ( X ) = 0.6667 \begin{array}{l} p(X=0)=p(X=0, Y=0)+p(X=0, Y=1)=\frac{2}{3} \\ p(X=1)=p(X=1, Y=0)+p(X=1, Y=1)=\frac{1}{3} \\ p(Y=0)=p(X=0, Y=0)+p(X=1, Y=0)=\frac{1}{3} \\ p(Y=1)=p(X=0, Y=1)+p(X=1, Y=1)=\frac{2}{3} \\ H(X)=\frac{1}{3} \log 3+\frac{2}{3} \log \frac{3}{2}=0.9183 \quad H(Y)=\frac{1}{3} \log 3+\frac{2}{3} \log \frac{3}{2}=0.9183 \\ H(X, Y)=\sum_{i=1}^{n} p(X, Y) \log (X, Y)=\log 3=1.585 \\ H(X \mid Y)=H(X, Y)-H(Y)=0.6667 \quad H(Y \mid X)=H(X, Y)-H(X)=0.6667 \end{array}
各类熵的关系
  1. 条件熵不大于信息熵。熵的不增原理: H ( Y / X ) ≤ H ( Y ) H(Y / X) \leq H(Y)
  2. 联合熵不大于个信息熵的和,即
    H ( X 1 X 2 … X N ) ≤ ∑ i = 1 N H ( X i ) H\left(X_{1} X_{2} \ldots X_N\right) \leq \sum_{i=1}^{N} H\left(X_{i}\right)
    仅当各 X i X_{i} 相互独立时, 等号成立。
  3. H ( X Y ) = H ( X ) + H ( Y ∣ X ) = H ( Y ) + H ( X ∣ Y ) H(X Y)=H(X)+H(Y \mid X)=H(Y)+H(X \mid Y)
  4. H ( X ) ≥ H ( X ∣ Y ) ; H ( Y ) ≥ H ( Y ∣ X ) H(X) \geq H(X \mid Y) ; H(Y) \geq H(Y \mid X)
参考文献:
  1. Proakis, John G., et al. Communication systems engineering. Vol. 2. New Jersey: Prentice Hall, 1994.
  2. Proakis, John G., et al. SOLUTIONS MANUAL Communication Systems Engineering. Vol. 2. New Jersey: Prentice Hall, 1994.
  3. 周炯槃. 通信原理(第3版)[M]. 北京:北京邮电大学出版社, 2008.
  4. 樊昌信, 曹丽娜. 通信原理(第7版) [M]. 北京:国防工业出版社, 2012.
