Helm 安装 Kubernetes 监控套件
小陈运维 发表于 2023/02/15 17:57:34 2023/02/15
【摘要】 Helm 安装 Grafana Prometheus Altermanager 套件 安装helm# 安装helm工具curl -fsSL -o get_helm.sh https://raw.githubusercontent.com/helm/helm/main/scripts/get-helm-3chmod 700 get_helm.sh./get_helm.sh 下载离线包# 添加...
安装helm
# 安装helm工具
./get_helm.sh
下载离线包
# 添加 prometheus-community 官方Helm Chart仓库
helm repo add prometheus-community https://prometheus-community.github.io/helm-charts
# 下载离线包
helm pull  prometheus-community/kube-prometheus-stack
# 解压下载下来的包
tar xvf kube-prometheus-stack-45.1.0.tgz
修改镜像地址
# 进入目录进行修改images地址
cd kube-prometheus-stack/
sed -i "s#registry.k8s.io/kube-state-metrics/kube-state-metrics#registry.cn-hangzhou.aliyuncs.com/chenby/kube-state-metrics#g" charts/kube-state-metrics/values.yaml
# 修改为如下
vim values.yaml
      image:
        registry: registry.cn-hangzhou.aliyuncs.com
        repository: chenby/kube-webhook-certgen
安装
# 进行安装
helm install  op  .
WARNING: Kubernetes configuration file is group-readable. This is insecure. Location: /root/.kube/config
WARNING: Kubernetes configuration file is world-readable. This is insecure. Location: /root/.kube/config
LAST DEPLOYED: Wed Feb 15 17:28:47 2023
NAMESPACE: default
STATUS: deployed
REVISION: 1
NOTES:
kube-prometheus-stack has been installed. Check its status by running:
  kubectl --namespace default get pods -l "release=op"
Visit https://github.com/prometheus-operator/kube-prometheus for instructions on how to create & configure Alertmanager and Prometheus instances using the Operator.
修改 svc
# 修改 svc 将其设置为NodePort
kubectl  edit svc op-grafana
kubectl  edit svc op-kube-prometheus-stack-prometheus
		type: NodePort
查看
root@hello:~# kubectl --namespace default get pods -l "release=op"
NAME                                                READY   STATUS    RESTARTS   AGE
op-kube-prometheus-stack-operator-bf67f6dbc-dsqgq   1/1     Running   0          12m
op-kube-state-metrics-d94c76d4f-r9nkg               1/1     Running   0          12m
op-prometheus-node-exporter-2hlmc                   1/1     Running   0          12m
op-prometheus-node-exporter-8trpl                   1/1     Running   0          12m
op-prometheus-node-exporter-j2lns                   1/1     Running   0          12m
op-prometheus-node-exporter-j4l69                   1/1     Running   0          12m
op-prometheus-node-exporter-krw2v                   1/1     Running   0          12m
root@hello:~#
# 查看svc
root@hello:~# kubectl --namespace default get svc | grep op
alertmanager-operated                   ClusterIP   None             <none>        9093/TCP,9094/TCP,9094/UDP   12m
op-grafana                              NodePort    10.102.25.207    <none>        80:32174/TCP                 12m
op-kube-prometheus-stack-alertmanager   ClusterIP   10.102.32.128    <none>        9093/TCP                     12m
op-kube-prometheus-stack-operator       ClusterIP   10.109.56.209    <none>        443/TCP                      12m
op-kube-prometheus-stack-prometheus     NodePort    10.101.74.136    <none>        9090:30777/TCP               12m
op-kube-state-metrics                   ClusterIP   10.99.39.208     <none>        8080/TCP                     12m
op-prometheus-node-exporter             ClusterIP   10.99.213.34     <none>        9100/TCP                     12m
prometheus-operated                     ClusterIP   None             <none>        9090/TCP                     12m
root@hello:~#
# 查看POD
root@hello:~# kubectl --namespace default get pod | grep op
alertmanager-op-kube-prometheus-stack-alertmanager-0   2/2     Running            1 (13m ago)   13m
op-grafana-5cd75cfd86-4df7g                            3/3     Running            0             13m
op-kube-prometheus-stack-operator-bf67f6dbc-dsqgq      1/1     Running            0             13m
op-kube-state-metrics-d94c76d4f-r9nkg                  1/1     Running            0             13m
op-prometheus-node-exporter-2hlmc                      1/1     Running            0             13m
op-prometheus-node-exporter-8trpl                      1/1     Running            0             13m
op-prometheus-node-exporter-j2lns                      1/1     Running            0             13m
op-prometheus-node-exporter-j4l69                      1/1     Running            0             13m
op-prometheus-node-exporter-krw2v                      1/1     Running            0             13m
prometheus-op-kube-prometheus-stack-prometheus-0       2/2     Running            0             13m
root@hello:~#
访问
# 访问
http://192.168.1.61:30777
http://192.168.1.61:32174
关于
https://www.oiox.cn/
https://www.oiox.cn/index.php/start-page.html
CSDN、GitHub、51CTO、知乎、开源中国、思否、掘金、简书、华为云、阿里云、腾讯云、哔哩哔哩、今日头条、新浪微博、个人博客
全网可搜《小陈运维》
文章主要发布于微信公众号
