开源Flink Kafka Connector源码学习
想要一只猫 发表于 2023/02/14 11:25:08 2023/02/14
【摘要】 本文通过阅读Kafka Connector代码的调用,分析了Kafka partition分配、Commit、线程模型等
简介
Flink版本:1.15
组件:Kafka Connector
源码阅读
org.apache.flink.streaming.connectors.kafka.FlinkKafkaConsumerBase#open
        --> subscribedPartitionsToStartOffsets = new HashMap<>() // 重要的参数
        >> org.apache.flink.streaming.connectors.kafka.internals.AbstractPartitionDiscoverer#discoverPartitions
                --> List<KafkaTopicPartition> newDiscoveredPartitions = getAllPartitionsForTopics(topics) // 获取topic的所有partition
                        --> kafkaConsumer.partitionsFor(topic)
                        >> org.apache.flink.streaming.connectors.kafka.internals.AbstractPartitionDiscoverer#setAndCheckDiscoveredPartition // 根据并发度、subTaskIndex过滤掉partition
                                --> KafkaTopicPartitionAssigner.assign(partition, numParallelSubtasks) == indexOfThisSubtask
                                int startIndex = ((partition.getTopic().hashCode() * 31) & 0x7FFFFFFF) % numParallelSubtasks;
                                return (startIndex + partition.getPartition()) % numParallelSubtasks
                        >> 返回剩下的partitions
        >> if RestoredState != null
                --> 遍历partitions,如果partition不在restoredState中,则在restoredState中添加该partition,offset设置为KafkaTopicPartitionStateSentinel.EARLIEST_OFFSET
                >>  遍历restoredState,如果partition符合KafkaTopicPartitionAssigner.assign(partition, numParallelSubtasks) == indexOfThisSubtask,则subscribedPartitionsToStartOffsets设置该partition和offset
                >>  如果filterRestoredPartitionsWithCurrentTopicsDescriptor=true,则从过滤掉subscribedPartitionsToStartOffsets中与此次作业topic设置不匹配的topic对应的partition
        || >> if RestoredState == null
                --> 如果startupMode 是SPECIFIC_OFFSETS或TIMESTAMP,则设置;其他partition的offset设置为startupMode.getStateSentinel()
                        --> 如果是SPECIFIC_OFFSETS,则遍历subscribedPartitionsToStartOffsets的partition的offset,如果partition和配置的specificStartupOffsets能匹配,则设置该offset,否则offset设置为KafkaTopicPartitionStateSentinel.GROUP_OFFSET
                >>  org.apache.flink.streaming.connectors.kafka.KafkaDeserializationSchema#open
org.apache.flink.streaming.connectors.kafka.FlinkKafkaConsumerBase#run
        -->  this.offsetCommitCallback = new KafkaCommitCallback
        >>  如果subscribedPartitionsToStartOffsets.isEmpty(),则将此source设为IDLE状态
        >>  this.kafkaFetcher = createFetcher
                --> adjustAutoCommitConfig
                     // 如果offset commit mode为ON_CHECKPOINTS,则设置关闭kafka auto commit
                     --> properties.setProperty("enable.auto.commit", "false")
                >> new KafkaFetcher
                        --> org.apache.flink.streaming.connectors.kafka.internals.AbstractFetcher#AbstractFetcher
                                --> this.checkpointLock = sourceContext.getCheckpointLock();
                                >> this.unassignedPartitionsQueue = new ClosableBlockingQueue<>();
                                for (KafkaTopicPartitionState<T, KPH> partition : subscribedPartitionStates) {
                                            unassignedPartitionsQueue.add(partition);
                                >> this.subscribedPartitionStates =
                                                createPartitionStateHolders(
                                                        seedPartitionsWithInitialOffsets,
                                                        timestampWatermarkMode,
                                                        watermarkStrategy,
                                                        userCodeClassLoader)
                                        --> partitionStates = new CopyOnWriteArrayList<>()
                        >> this.handover = new Handover() // 用于存储从kafka消费的数据,
                        >> this.consumerThread = new KafkaConsumerThread  // kafka数据消费线程
                                --> this.nextOffsetsToCommit = new AtomicReference<>()
                                >> this.kafkaCollector = new KafkaCollector()
        >> kafkaFetcher.runFetchLoop
                --> consumerThread.start() // 启动kafka消费线程
                        --> consuemrThread.run()
                                --> this.consumer = getConsumer(kafkaProperties) // 初始化KafkaConsumer
                                >>  while (running) 循环从kafka拉数据
                                >> if !commitInProgress
                                        >> commitOffsetsAndCallback = nextOffsetsToCommit.getAndSet(null); // 第一次时返回null,只有在checkpoint的时候org.apache.flink.streaming.connectors.kafka.FlinkKafkaConsumerBase#notifyCheckpointComplete设置
                                        >> if commitOffsetsAndCallback != null
                                        >> commitInProgress = true; // 表示正在commit中
                                                >> consumer.commitAsync(  // 运行commit
        commitOffsetsAndCallback.f0,
        new CommitCallback(commitOffsetsAndCallback.f1)
                                >> if hasAssignedPartitions // 第一次为false
                                        >> newPartitions = unassignedPartitionsQueue.pollBatch();
                                else
                                        >> newPartitions = unassignedPartitionsQueue.getBatchBlocking() // 第一次执行这里
                                >> if newPartitions != null
                                        >> org.apache.flink.streaming.connectors.kafka.internals.KafkaConsumerThread#reassignPartitions // 关键操作
                                                --> hasAssignedPartitions = true;
                                                >> oldPartition + newPartitions再reassign一下
                                                >> for newPartitions // 遍历newPartitons
                                                >> 如果partition offset为KafkaTopicPartitionStateSentinel.EARLIEST_OFFSET
                                                        >> org.apache.kafka.clients.consumer.KafkaConsumer#seekToBeginning
                                                >> 如果partition offset为KafkaTopicPartitionStateSentinel.LATEST_OFFSET
                                                        >> org.apache.kafka.clients.consumer.KafkaConsumer#seekToEnd
                                                >> 如果partition offset为KafkaTopicPartitionStateSentinel.GROUP_OFFSET
                                                        >> 直接newPartitionState.setOffset(
                                >> if records == null
                                        >> records = consumer.poll(pollTimeout); // 从kafka拉取数据
                                        >> handover.produce(records);
                                                org.apache.flink.streaming.connectors.kafka.internals.Handover#produce
                                                --> synchronized (lock)
                                                >> next = element;
                >>  while(running) // 循环处理consumerThread从kafka消费的数据
                        >> records = handover.pollNext()
                                >> n = next; next = null; return n;
                        // 遍历subscribedPartitionsToStartOffsets针对指定的partition,调用org.apache.kafka.clients.consumer.ConsumerRecords#records(org.apache.kafka.common.TopicPartition)获取指定partitoin的records
                        // 然后org.apache.flink.streaming.connectors.kafka.internals.KafkaFetcher#partitionConsumerRecordsHandler(partitionRecords, partition)处理partition数据
                                --> 遍历partitionRecords
                                >> deserializer.deserialize(record, kafkaCollector) // 反序列化record,并设置到kafkaCollector
                                 // org.apache.flink.streaming.connectors.kafka.KafkaDeserializationSchema#deserialize(org.apache.kafka.clients.consumer.ConsumerRecord<byte[],byte[]>, org.apache.flink.util.Collector<T>)
                                >> emitRecordsWithTimestamps(kafkaCollector.getRecords(), partition, record.offset(), record.timestamp()) // 发送到下游
                                        // org.apache.flink.streaming.connectors.kafka.internals.AbstractFetcher#emitRecordsWithTimestamps
                                        --> synchronized (checkpointLock)
                                        >>  循环从records.poll()取出数据
                                        >>  org.apache.flink.streaming.connectors.kafka.internals.KafkaTopicPartitionState#extractTimestamp 抽取kafka event或者自定一个timeassigner
                                        >>  org.apache.flink.streaming.api.functions.source.SourceFunction.SourceContext#collectWithTimestamp // 发送到下游
