软件测试|Pytest必会技巧(三)
霍格沃兹测试开发 发表于 2023/02/08 18:35:12 2023/02/08
【摘要】 Pytest参数化——pytest.mark.parametrize parametrizing首先来看一个实现检查一定的输入和期望输出测试功能的典型例子# content of test_expectation.py# coding:utf-8import pytest@pytest.mark.parametrize("test_input,expected", ...
parametrizing
# coding:utf-8
import pytest
                         [ ("3+5", 8),
                           ("2+4", 6),
                           ("6 * 9", 42),
def test_eval(test_input, expected):
    assert eval(test_input) == expected
if __name__ == "__main__":
    pytest.main(["-s", "test_demo.py"])
运行结果
============================= test session starts =============================
collecting ... collected 3 items
test_demo.py::test_eval[3+5-8]
test_demo.py::test_eval[2+4-6]
test_demo.py::test_eval[6 * 9-42] PASSED                                    [ 33%]PASSED                                    [ 66%]FAILED                                 [100%]
test_demo.py:5 (test_eval[6 * 9-42])
54 != 42
Expected :42
Actual   :54
<Click to see difference>
test_input = '6 * 9', expected = 42
                             [ ("3+5", 8),
                               ("2+4", 6),
                               ("6 * 9", 42),
E       assert 54 == 42
test_demo.py:12: AssertionError
========================= 1 failed, 2 passed in 0.04s =========================
在这个例子中设计的,只有一条输入/输出值的简单测试功能。和往常一样,函数的参数,你可以在运行结果看到在输入和输出值。
标记单个测试实例参数化
import pytest
@pytest.mark.parametrize("test_input,expected", [
                        ("3+5", 8),
                        ("2+4", 6),
                        pytest.param("6 * 9", 42, marks=pytest.mark.xfail),
    print("-------开始用例------")
运行结果:
======================== 2 passed, 1 xfailed in 0.06s =========================
Process finished with exit code 0
PASSED                                    [ 33%]-------开始用例------
PASSED                                    [ 66%]-------开始用例------
XFAIL                                  [100%]-------开始用例------
                            ("3+5", 8),
                            ("2+4", 6),
E       assert 54 == 42
test_demo.py:10: AssertionError
标记为失败的用例,预期结果是失败,实际运行也是失败,显示xfailed
参数组合
若要获得多个参数化参数的所有组合,可以堆叠参数化装饰器
import pytest
@pytest.mark.parametrize("x", [0, 1])
@pytest.mark.parametrize("y", [2, 3])
def test_foo(x, y):
    print("测试数据组合:x->%s, y->%s" % (x, y))
运行结果:
collecting ... collected 4 items
test_demo.py::test_foo[2-0] PASSED                                       [ 25%]测试数据组合:x->0, y->2
test_demo.py::test_foo[2-1] PASSED                                       [ 50%]测试数据组合:x->1, y->2
test_demo.py::test_foo[3-0] PASSED                                       [ 75%]测试数据组合:x->0, y->3
test_demo.py::test_foo[3-1] PASSED                                       [100%]测试数据组合:x->1, y->3
============================== 4 passed in 0.03s ==============================
这将运行测试,参数设置为x=0/y=2,x=1/y=2,x=0/y=3,x=1/y=3组合参数。
