pytest学习和使用14-Pytest用例执行结果有哪几种状态?
虫无涯 发表于 2023/02/08 08:58:49 2023/02/08
【摘要】 1 用例执行状态状态说明passed测试通过failed断言失败error用例本身代码报错xfail预期失败,加了 @pytest.mark.xfail() 2 xfail示例# -*- coding:utf-8 -*-# 作者:NoamaNelson# 日期:2022/12/27 # 文件名称:test_case_status.py# 作用:用例的执行状态# 联系:VX(NoamaNel...
1 用例执行状态
状态 说明
passed 测试通过
failed 断言失败
error 用例本身代码报错
xfail 预期失败,加了 @pytest.mark.xfail()
2 xfail示例
# 作者:NoamaNelson
# 日期:2022/12/27
# 作用:用例的执行状态
# 联系:VX(NoamaNelson)
# 博客:https://blog.csdn.net/NoamaNelson
import pytest
# 断言装饰器
@pytest.mark.xfail(raises=ZeroDivisionError)
def test_f():
    1 / 0
if __name__ == '__main__':
    pytest.main(["-s", "test_case_status.py"])
test_case_status.py::test_f XFAIL       [100%]
    def test_f():
>       1 / 0
E       ZeroDivisionError: division by zero
test_case_status.py:14: ZeroDivisionError
============================= 1 xfailed in 0.07s ==============================
3 failed示例
# 作者:NoamaNelson
# 日期:2022/12/27
# 作用:用例的执行状态
import pytest
# failed
@pytest.fixture()
def sum():
    add = 3 + 5
    assert add == 8
    return add
def test_case(sum):
    assert sum == 9
sum = 8
    def test_case(sum):
>       assert sum == 9
E       assert 8 == 9
test_case_status.py:24: AssertionError
=========================== short test summary info ===========================
FAILED test_case_status.py::test_case - assert 8 == 9
============================== 1 failed in 0.07s ==============================
4 error示例
  • 正常情况:
# 作者:NoamaNelson
# 日期:2022/12/27
# 作用:用例的执行状态
import pytest
@pytest.fixture()
def userinfo():
    name = "zhang"
    assert name == "zhang"
    return name
def test_case(userinfo):
    assert userinfo == "zhang"
test_case_status.py::test_case PASSED [100%]
============================== 1 passed in 0.02s ==============================
  • 我们把@pytest.fixture()去掉,就会error:
# 作者:NoamaNelson
# 日期:2022/12/27
# 作用:用例的执行状态
import pytest
def userinfo():
    name = "zhang"
    return name
=================================== ERRORS ====================================
_________________________ ERROR at setup of test_case _________________________
file F:\pytest_study\test_case\test_g\test_case_status.py, line 31
E       fixture 'userinfo' not found
>       available fixtures: cache, capfd, capfdbinary, caplog, capsys, capsysbinary, cov, doctest_namespace, metadata, monkeypatch, no_cover, pytestconfig, record_property, record_testsuite_property, record_xml_attribute, recwarn, tmp_path, tmp_path_factory, tmpdir, tmpdir_factory, worker_id
>       use 'pytest --fixtures [testpath]' for help on them.
F:\pytest_study\test_case\test_g\test_case_status.py:31
ERROR test_case_status.py::test_case
============================== 1 error in 0.03s ===============================
