Oracle数据库创建自增主键
别团等shy哥发育 发表于 2023/02/04 16:56:15 2023/02/04
【摘要】 @[toc] 1、建表CREATE TABLE "PCOCA2"."CY3_FORMATION_FLOW_PRESSURE" ("wellId" VARCHAR2(255 BYTE) NOT NULL ,"formationPressure" NUMBER(10,2) NOT NULL ,"flowPressure" NUMBER(10,2) NOT NULL ,"batchTime" DA...
@[toc]
1、建表
"batchTime" DATE NOT NULL ,
"batchId" NUMBER(12) NOT NULL
2、创建序列
create Sequence SEQ_FORMATION_FLOW
 minvalue 1
maxvalue  999999999999
start with 1 --从1开始
increment by 1 --增量为1
nocache
order;
3、创建触发器
create or replace trigger FORMATION_FLOW_AUTOINCREMENT
before insert on CY3_FORMATION_FLOW_PRESSURE
for each row
begin
select SEQ_FORMATION_FLOW.nextval into:new."batchId" from dual;
end;
OK了,先在插入数据测试下看自增主键是否生效。
