SpringBoot2.x自动创建表并初始化数据库
别团等shy哥发育 发表于 2023/02/04 16:54:59 2023/02/04
【摘要】 1、使用springboot jdbc初始化数据库项目结构: 1.1 application.yml配置文件:spring: datasource: username: root password: 123456 url: jdbc:mysql://192.168.56.101:3306/jdbc driver-class-name: com.mysql.cj.j...
项目结构:
spring:
  datasource:
    username: root
    password: 123456
    driver-class-name: com.mysql.cj.jdbc.Driver
    initialization-mode: always
    schema:
      - classpath:department.sql
1.2 department.sql:
Navicat MySQL Data Transfer
Source Server         : 本地
Source Server Version : 50528
Source Host           : 127.0.0.1:3306
Source Database       : restful_crud
Target Server Type    : MYSQL
Target Server Version : 50528
File Encoding         : 65001
Date: 2018-03-05 10:41:40
SET FOREIGN_KEY_CHECKS=0;
-- Table structure for department
DROP TABLE IF EXISTS `department`;
CREATE TABLE `department` (
  `id` int(11) NOT NULL AUTO_INCREMENT,
  `departmentName` varchar(255) DEFAULT NULL,
  PRIMARY KEY (`id`)
) ENGINE=InnoDB AUTO_INCREMENT=1 DEFAULT CHARSET=utf8;
1.3 在SpringBoot2.x中,我们需要在配置文件中配置一下:
spring.datasource.initialization-mode: always
1.4 启动项目后查看数据库,如下图,确实是创建了department表:
