SpringSecurity配置403权限访问页面
别团等shy哥发育 发表于 2023/02/04 16:45:48 2023/02/04
【摘要】 @toc 1、未配置之前 2、开始配置 2.1 新建一个unauth.html<!DOCTYPE html><html lang="en"><head> <meta charset="UTF-8"> <title>Title</title></head><body><h1>没有访问的权限</h1></body></html> 2.2 在继承WebSecurityConfigure...
@toc
1、未配置之前
2、开始配置
2.1 新建一个unauth.html
<!DOCTYPE html>
<html lang="en">
<head>
</head>
<body>
<h1>没有访问的权限</h1>
</body>
</html>
2.2 在继承WebSecurityConfigurerAdapter的配置类中设置
关键代码:
 //配置没有权限访问自定义跳转的页面
  http.exceptionHandling()
  .accessDeniedPage("/unauth.html");
配置类完整代码:
package com.atguigu.springsecuritydemo1.config;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.security.config.annotation.authentication.builders.AuthenticationManagerBuilder;
import org.springframework.security.config.annotation.web.builders.HttpSecurity;
import org.springframework.security.config.annotation.web.configuration.WebSecurityConfigurerAdapter;
import org.springframework.security.core.userdetails.UserDetailsService;
import org.springframework.security.crypto.bcrypt.BCryptPasswordEncoder;
import org.springframework.security.crypto.password.PasswordEncoder;
@Configuration
public class SecurityConfigTest extends WebSecurityConfigurerAdapter {
    @Autowired
    private UserDetailsService userDetailsService;
    @Override
    protected void configure(AuthenticationManagerBuilder auth) throws Exception {
        auth.userDetailsService(userDetailsService).passwordEncoder(password());
    @Bean
    PasswordEncoder password(){
       return new BCryptPasswordEncoder();
    @Override
    protected void configure(HttpSecurity http) throws Exception {
        //退出配置
        http.logout().logoutUrl("/logout")
                .logoutSuccessUrl("/test/hello")
                .permitAll();
        //配置没有权限访问自定义跳转的页面
        http.exceptionHandling().accessDeniedPage("/unauth.html");
        http.formLogin()             //自定义自己编写的登陆页面
            .loginPage("/login.html")    //登录页面设置
            .loginProcessingUrl("/user/login") //登录访问路径
            .defaultSuccessUrl("/success.html").permitAll()    //登录成功之后,跳转路径
            .and().authorizeRequests()
               //设置哪些路径可以直接访问,不需要认证
                .antMatchers("/","/test/hello","/user/login").permitAll()
                //当前登录的用户,只有具有admins权限才可以访问这个路径
               //1、hasAuthority方法
               //.antMatchers("/test/index").hasAuthority("admins")
               //2、hasAnyAuthority方法
              // .antMatchers("/test/index").hasAnyAuthority("admins,manager")
              //3、hasRole方法  ROLE_sale
               .antMatchers("/test/index").hasRole("sale")
                //4、hasAnyRole方法
            .anyRequest().authenticated()
            .and().csrf().disable();    //关闭csrf防护
2.3 继承UserDetailsService接口的实现类
package com.atguigu.springsecuritydemo1.service;
import com.atguigu.springsecuritydemo1.entity.Users;
import com.atguigu.springsecuritydemo1.mapper.UsersMapper;
import com.baomidou.mybatisplus.core.conditions.query.QueryWrapper;
import org.springframework.security.core.GrantedAuthority;
import org.springframework.security.core.authority.AuthorityUtils;
import org.springframework.security.core.userdetails.User;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.security.core.userdetails.UsernameNotFoundException;
import org.springframework.stereotype.Service;
import java.util.List;
@Service("userDetailsService")
public class MyUserDetailService implements UserDetailsService {
    @Autowired
    private UsersMapper usersMapper;
    @Override
    public UserDetails loadUserByUsername(String username) throws UsernameNotFoundException {
        //调用userMapper中的方法,根据用户名查询数据库
        QueryWrapper<Users> wrapper=new QueryWrapper<>();//条件构造器
        //where username=?
        wrapper.eq("username",username);
        Users users= usersMapper.selectOne(wrapper);
        //判断
        if(users==null){    //数据库没有用户名,认证失败
            throw new UsernameNotFoundException("用户名不存在!");
        List<GrantedAuthority> auths= AuthorityUtils.commaSeparatedStringToAuthorityList("admins,ROLE_sale");
        //从查询数据库返回user对象,得到用户名和密码,返回
        return new User(users.getUsername(),new BCryptPasswordEncoder().encode(users.getPassword()),auths);
3、测试
现在我故意将原先的sale改为sale1制造错误
启动项目并访问http://localhost:8111/test/index
输入lucy 123
成功实现
