SpringSecurity认证授权的注解使用
别团等shy哥发育 发表于 2023/02/04 16:45:25 2023/02/04
【摘要】 @toc 1、@Secured注解判断是否具有角色,另外需要注意的是这里匹配的字符串需要添加前缀“ROLE_“。 1.1 启动类开启注解使用注解先要开启注解功能!先在启动类上加如下注解@EnableGlobalMethodSecurity(securedEnabled=true) 1.2 在controller的方法上面使用注解,设置角色 @GetMapping("update") @...
@toc
1、@Secured注解
1.1 启动类开启注解
    @Secured({"ROLE_sale","ROLE_manager"})
    public String update(){
        System.out.println("update......");
        return "hello update";
1.3 userDetailService设置用户角色
关键代码:
完整代码如下:userDetailService.java
package com.atguigu.springsecuritydemo1.service;
import com.atguigu.springsecuritydemo1.entity.Users;
import com.atguigu.springsecuritydemo1.mapper.UsersMapper;
import com.baomidou.mybatisplus.core.conditions.query.QueryWrapper;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.security.core.GrantedAuthority;
import org.springframework.security.core.authority.AuthorityUtils;
import org.springframework.security.core.userdetails.User;
import org.springframework.security.core.userdetails.UserDetails;
import org.springframework.security.core.userdetails.UserDetailsService;
import org.springframework.security.core.userdetails.UsernameNotFoundException;
import org.springframework.security.crypto.bcrypt.BCryptPasswordEncoder;
import org.springframework.stereotype.Service;
import java.util.List;
@Service("userDetailsService")
public class MyUserDetailService implements UserDetailsService {
    @Autowired
    private UsersMapper usersMapper;
    @Override
    public UserDetails loadUserByUsername(String username) throws UsernameNotFoundException {
        //调用userMapper中的方法,根据用户名查询数据库
        QueryWrapper<Users> wrapper=new QueryWrapper<>();//条件构造器
        //where username=?
        wrapper.eq("username",username);
        Users users= usersMapper.selectOne(wrapper);
        //判断
        if(users==null){    //数据库没有用户名,认证失败
            throw new UsernameNotFoundException("用户名不存在!");
        List<GrantedAuthority> auths= AuthorityUtils.commaSeparatedStringToAuthorityList("admins,ROLE_sale");
        //从查询数据库返回user对象,得到用户名和密码,返回
        return new User(users.getUsername(),new BCryptPasswordEncoder().encode(users.getPassword()),auths);
1.4 启动测试
项目启动后,访问http://localhost:8111/test/update
输入 lucy 123
控制台信息:
2、@PreAuthorize注解
@PreAuthorize:注解适合进入方法前的权限验证, @PreAuthorize 可以将登录用户的 roles/permissions 参数传到方法中。
2.1 开启注解功能
@EnableGlobalMethodSecurity(prePostEnabled = true)
2.2 在controller的方法上添加注解
    @PreAuthorize("hasAnyAuthority('admins')")
3、@PostAuthorize注解
先开启注解功能:
@PostAuthorize 注解使用并不多,在方法执行后再进行权限验证,适合验证带有返回值的权限.
4、@PostFilter注解
@PostFilter :权限验证之后对数据进行过滤
表达式中的 filterObject 引用的是方法返回值 List 中的某一个元素
    @GetMapping("getAll")
    @PostAuthorize("hasAnyAuthority('admins')")
    @PostFilter("filterObject.username == 'admin1'")
    public List<Users> getAllUser(){
        ArrayList<Users> list = new ArrayList<>();
        list.add(new Users(11,"admin1","6666"));
        list.add(new Users(21,"admin2","888"));
        System.out.println(list);
        return list;
上面代码只留下用户名是 admin1 的数据
5、@PreFilter注解
@PreFilter: 进入控制器之前对数据进行过滤
