Mybatis-Plus入门案例(springboot项目实现)
别团等shy哥发育 发表于 2023/02/04 16:44:29 2023/02/04
【摘要】 @toc 1、初始化工程使用Spring Initializer快速初始化一个Spring Boot工程 2、添加依赖pom.xml<?xml version="1.0" encoding="UTF-8"?><project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchem...
@toc
1、初始化工程
2、添加依赖
pom.xml
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.5.1</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.baomidou.mybatisplus</groupId>
    <artifactId>mybatisplus01</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>mybatisplus01</name>
    <description>Demo project for Spring Boot</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter</artifactId>
        </dependency>
        <dependency>
            <groupId>org.projectlombok</groupId>
            <artifactId>lombok</artifactId>
            <optional>true</optional>
        </dependency>
        <dependency>
            <groupId>com.baomidou</groupId>
            <artifactId>mybatis-plus-boot-starter</artifactId>
            <version>3.4.3.1</version>
        </dependency>
        <dependency>
            <groupId>mysql</groupId>
            <artifactId>mysql-connector-java</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
                <configuration>
                    <excludes>
                        <exclude>
                        </exclude>
                    </excludes>
                </configuration>
            </plugin>
        </plugins>
    </build>
</project>
3、数据库创建
在数据库中新建一张user表,结构如下:
数据库的Schema 脚本如下:
DROP TABLE IF EXISTS user;
CREATE TABLE user
	id BIGINT(20) NOT NULL COMMENT '主键ID',
	name VARCHAR(30) NULL DEFAULT NULL COMMENT '姓名',
	age INT(11) NULL DEFAULT NULL COMMENT '年龄',
	email VARCHAR(50) NULL DEFAULT NULL COMMENT '邮箱',
	PRIMARY KEY (id)
INSERT INTO user
VALUES
(1, 'Jone', 18, 'test1@baomidou.com'),
(2, 'Jack', 20, 'test2@baomidou.com'),
(3, 'Tom', 28, 'test3@baomidou.com'),
(4, 'Sandy', 21, 'test4@baomidou.com'),
(5, 'Billie', 24, 'test5@baomidou.com');
4、配置
4.1 application.yml
在该文件中配置mysql数据源
# DataSource Config
spring:
  datasource:
    url: jdbc:mysql://localhost:3306/mp?&useSSL=false&serverTimezone=UTC&allowPublicKeyRetrieval=true
    username: root
    password: 123456
    driver-class-name: com.mysql.cj.jdbc.Driver
# mybatis-plus配置控制台打印sql语句:
mybatis-plus:
  configuration:
    log-impl: org.apache.ibatis.logging.stdout.StdOutImpl
4.2 配置
项目结构如下
在启动类上加入@MapperScan注解,扫描mapper文件夹,这里由于每个人的包结构不一样,你看着改下就行
5、编码
5.1 实体类User.java
package com.baomidou.mybatisplus.bean;
import com.baomidou.mybatisplus.annotation.TableName;
import lombok.Data;
@Data
@TableName("user")
public class User {
    private Long id;
    private String name;
    private Integer age;
    private String email;
1、上面的@TableName是为了和数据库中的user表对应
2、用lombok来简化代码
5.2 编写Mapper类UserMapper.java
package com.baomidou.mybatisplus.mapper;
import com.baomidou.mybatisplus.bean.User;
import com.baomidou.mybatisplus.core.mapper.BaseMapper;
public interface UserMapper extends BaseMapper<User> {
6、测试
SpringBoot的测试类
package com.baomidou.mybatisplus;
import com.baomidou.mybatisplus.bean.Employee;
import com.baomidou.mybatisplus.mapper.EmployeeMapper;
import com.baomidou.mybatisplus.mapper.UserMapper;
import org.junit.jupiter.api.Test;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.boot.test.context.SpringBootTest;
import org.springframework.util.Assert;
import java.util.List;
@SpringBootTest
class Mybatisplus01ApplicationTests {
    @Autowired
    private UserMapper userMapper;
    @Autowired
    private EmployeeMapper employeeMapper;
    @Test
    void contextLoads() {
    @Test
    public void testSelect(){
        System.out.println("----selectAll method test----");
        List<User> userList=userMapper.selectList(null);
        userList.forEach(System.out::println);
执行之后,查看控制台输出
数据库中的数据
可以看到,mybatisplus确实强大,我一句sql语句都没写,数据就都查出来了。
7、小结
通过以上几个简单的步骤,我们就实现了 User 表的 CRUD 功能,甚至连 XML 文件都不用编写!
从以上步骤中,我们可以看到集成MyBatis-Plus非常的简单,只需要引入 starter 工程,并配置 mapper 扫描路径即可。
