Redis结合SpringBoot的秒杀案例
别团等shy哥发育 发表于 2023/02/04 11:36:03 2023/02/04
【摘要】   秒杀(也叫限时秒杀),是商家在某特定时间段里大幅降低网络商品价格的一种营销活动。这里用Redis整合SpringBoot框架的方法给出一个秒杀案例 1、构建SpringBoot项目搭建名为quickbuy的springboot项目,相关的依赖包如下所示:<?xml version="1.0" encoding="UTF-8"?><project xmlns="http://maven.a...
1、构建SpringBoot项目
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 https://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <parent>
        <artifactId>spring-boot-starter-parent</artifactId>
        <version>2.1.13.RELEASE</version>
        <relativePath/> <!-- lookup parent from repository -->
    </parent>
    <groupId>com.baizhi</groupId>
    <artifactId>quickbuy</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <name>quickbuy</name>
    <description>Demo project for Spring Boot</description>
    <properties>
        <java.version>1.8</java.version>
    </properties>
    <dependencies>
        <dependency>
            <artifactId>spring-boot-starter-data-redis</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-web</artifactId>
        </dependency>
        <dependency>
            <artifactId>spring-boot-starter-test</artifactId>
            <scope>test</scope>
        </dependency>
        <dependency>
            <groupId>org.apache.httpcomponents</groupId>
            <artifactId>httpclient</artifactId>
            <version>4.5.5</version>
        </dependency>
        <dependency>
            <artifactId>httpcore</artifactId>
            <version>4.4.10</version>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <plugin>
                <artifactId>spring-boot-maven-plugin</artifactId>
            </plugin>
        </plugins>
    </build>
</project>
引入了Redis、HttpClient等依赖包。
项目结构
2、启动类
package com.baizhi;
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
@SpringBootApplication
public class QuickbuyApplication {
        SpringApplication.run(QuickbuyApplication.class, args);
3、在Controller层里定义秒杀接口
@RestController
public class QuickBuyController {
    @Autowired
    private SellService sellService;
    @RequestMapping("/quickBuy/{item}/{owner}")
    public String quickbuy(@PathVariable String item,@PathVariable String owner){
        String result=sellService.quickBuy(item,owner);
        if(!result.equals("0")){
            return owner+"success";
        }else{
            return owner+"fail";
  通过@RequestMapping注解们可以把"/quickBuy/{item}/{owner}"格式的url映射到quickBuy方法上。
   quickBuy是秒杀接口,该接口包含的两个参数是item和owner,分别表示待秒杀的商品名和发起秒杀请求的用户。这两个参数均被@PathVariable注解修饰,说明来自于url里的{item}和{owner}部分。
  在这个quickBuy秒杀接口中调用了SellService类里的quickBuy方法实现了秒杀功能,并根据SellService类quickBuy方法返回的结果,向外部返回“秒杀成功”或“秒杀失败”的字符串语句。
4、在Service层里通过lua脚本实现秒杀效果
package com.baizhi.service;
import org.springframework.data.redis.connection.RedisConnection;
import org.springframework.data.redis.connection.ReturnType;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.core.script.DefaultRedisScript;
import org.springframework.stereotype.Service;
import javax.annotation.Resource;
@Service
public class SellService {
    @Resource
    private RedisTemplate redisTemplate;
    public String quickBuy(String item, String owner) {
        //用lua脚本实现秒杀
        String luaScript="local owner=ARGV[1]\n" +
                "local item=KEYS[1] \n" +
                "local leftNum=tonumber(redis.call('get',item)) \n" +
                "if(leftNum>=1)\n" +
                "then redis.call('decrby',item,1)\n" +
                "redis.call('rpush','ownerList',owner)\n" +
                "return 1 \n" +
                "else \n" +
                "return 0 \n" +
                "end\n" +
                "\n";
        String key=item;
        String args=owner;
        DefaultRedisScript<String> redisScript=new DefaultRedisScript<String>();
        redisScript.setScriptText(luaScript);
        //调用lua脚本,请注意传入的参数
        Object luaResult=redisTemplate.execute((RedisConnection connection)->connection.eval(
           redisScript.getScriptAsString().getBytes(),
           ReturnType.INTEGER,
           1,
           key.getBytes(),
           args.getBytes()
        //根据lua脚本的执行情况返回结果
        return luaResult.toString();
对lua脚本的解释如下:
   通过ARGV[1]参数传入发起秒杀请求的用户,用KEYS[1]参数传入待秒杀的商品。通过get item命令判断item商品在Redis里还有多少库存。
  if语句中判定剩余库存大于等于1,就会先执行decrby命令把库存数减1,随后调用第6行的rpush命令,在ownerList里记录当前秒杀成功的用户,并通过return 1表示秒杀成功。如果判断库存数已经小于1,那么return 0表示秒杀失败。
  其中将lua脚本赋予redisScript对象,并通过redisTemplate.execute方法执行lua脚本。
在调用redisTemplate.execute方法执行lua脚本时请注意以下三点:
  • 需要以butes方式传入脚本
  • 需要指定返回类型
  • 传入该lua脚本所包含的KEYS类型参数的个数是1.
  • 传入的KEYS和ARGV类型的参数需要转换成bytes类型
5、配置redis连接参数
application.properties
server.port=8081
spring.redis.host=192.168.159.22
spring.redis.port=6379
6、演示秒杀效果
6.1 准备redis环境
我用的刚搭建的redis主从复制集群,一主二从
设置10个商品
6.2 启动项目
  在浏览器访问http://localhost:8081/quickBuy/Computer/abc,测试秒杀接口,该url传入的商品名是“Computer”,需要和上面设置的商品名称一致,传入的发起秒杀请求的客户端名字为abc。输入该url后,能看到表示秒杀成功的如下输出。
进入redis查看
发现商品数量变成了9,且能看到秒杀成功的用户列表。
6.3 多线程形式发起秒杀请求
QuickBuyClients.java
package com.baizhi.client;
import org.apache.http.HttpEntity;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.methods.CloseableHttpResponse;
import org.apache.http.client.methods.HttpGet;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClientBuilder;
import org.apache.http.util.EntityUtils;
public class QuickBuyClients extends Thread{
    @Override
    public void run() {
        QuickBuyUtil.quickBuy();
        //开启15个线程,线程数多余秒杀商品数
        for(int cnt=0;cnt<15;cnt++){
            new QuickBuyClients().start();
//封装秒杀方法的工具类
class QuickBuyUtil{
    //在这个方法里,用HttpGet对象发起秒杀请求
    public static void quickBuy(){
        String user=Thread.currentThread().getName();
        CloseableHttpClient httpClient= HttpClientBuilder.create().build();
        //创建秒杀Get类型的url请求
        HttpGet httpGet=new HttpGet("http://localhost:8081/quickBuy/Computer/"+user);
        //得到响应结果
        CloseableHttpResponse res=null;
        try{
            res=httpClient.execute(httpGet);
            HttpEntity responseEntity=res.getEntity();
            if(res.getStatusLine().equals("200")&&responseEntity!=null){
                System.out.println("秒杀结果:"+ EntityUtils.toString(responseEntity));
        }catch (ClientProtocolException e){
            e.printStackTrace();
        }catch (Exception e){
        }finally {
            try{
                //回收http连接资源
                if(httpClient!=null){
                    httpClient.close();
                if(res!=null){
                    res.close();
先重新设置商品数量为10
启动上面的程序
再次进入Redis查看商品数量和秒杀成功的用户
可以看到,15个线程秒杀商品,最终成功的只有10个。
