MyBatis之一对多,多对一 关联查询(内容详细,建议收藏)
Bug 终结者 发表于 2023/02/01 15:38:06 2023/02/01
【摘要】 MyBatis之一对多,多对一 关联查询(内容详细,建议收藏)
MyBatis之一对多, 多对一 关联查询
Hello,大家好,本周博主为大家带来MyBatis中的一对多,多对一查询,关于MyBatis中查询的操作,下面步入正题
开发环境
IDE:IntelliJ IDEA
jdk:1.8
数据库:mysql 5.7
管理工具:Maven
技术栈:Java + MyBatis
需求
现有一个班级,班级内有多个学生,1个老师,该场景为多对一,一对多
要求使用MyBatis查出学生对应的老师,及每个老师教的学生。
数据表准备
teacher:
CREATE TABLE `teacher` (
  `id` int(10) NOT NULL,
  `name` varchar(30) DEFAULT NULL,
  PRIMARY KEY (`id`)
student:
CREATE TABLE `student` (
  `name` varchar(30) COLLATE utf8mb4_unicode_ci DEFAULT NULL,
  `tid` int(10) DEFAULT NULL,
  PRIMARY KEY (`id`),
  KEY `fktid` (`tid`),
  CONSTRAINT `fktid` FOREIGN KEY (`tid`) REFERENCES `teacher` (`id`)
项目结构
项目搭建
MyBatis项目搭建传送门
实体类
Student
package com.wanshi.bean;
public class Student {
    private Integer id;
    private String name;
    private Teacher teacher;
    private Integer tid;
    public Student() {
    public Student(Integer id, String name, Teacher teacher) {
        this.id = id;
        this.name = name;
        this.teacher = teacher;
    public Integer getId() {
        return id;
    public void setId(Integer id) {
        this.id = id;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
    public Teacher getTeacher() {
        return teacher;
    public void setTeacher(Teacher teacher) {
    public Integer getTid() {
        return tid;
    public void setTid(Integer tid) {
        this.tid = tid;
    @Override
    public String toString() {
        return "Student{" +
                "id=" + id +
                ", name='" + name + '\'' +
                ", teacher=" + teacher +
Teacher
import java.util.List;
public class Teacher {
    private Integer id;
    private List<Student> studentList;
    public Teacher() {
    public Teacher(Integer id, String name, List<Student> studentList) {
        this.id = id;
        this.name = name;
        this.studentList = studentList;
        return id;
        this.id = id;
        return name;
        this.name = name;
    public List<Student> getStudentList() {
        return studentList;
    public void setStudentList(List<Student> studentList) {
    @Override
        return "com.wanshi.bean.Teacher{" +
                "id=" + id +
                ", studentList=" + studentList +
多对一
这里以学生对老师,多个学生对应一个老师,查询出每个学生对应的老师信息
第一种:关联查询
<!--    结果集映射,按照结果嵌套查询-->
    <select id="getStudentList" resultMap="StudentTeacher">
        select s.id sid, s.name sname, t.id tid, t.name tname from student s join teacher t on s.tid = t.id;
    </select>
    <resultMap id="StudentTeacher" type="student">
        <result property="id" column="sid" />
        <result property="name" column="sname"/>
        <association property="teacher" javaType="teacher">
            <result property="name" column="tname"/>
        </association>
    </resultMap>
第二种:子查询
<!--    子查询方式实现多对一查询-->
    <select id="getStudentList2" resultType="student" resultMap="getStudentTeacher">
        select * from student
    </select>
    <resultMap id="getStudentTeacher" type="student">
        <result property="id" column="id"/>
        <result property="name" column="name"/>
        <association column="tid" property="teacher" javaType="teacher" select="getTeacher"/>
    </resultMap>
    <select id="getTeacher" resultType="teacher">
        select * from teacher
    </select>
结果
两种结果均为下图所示
一对多
以老师对学生,一个老师对应多个学生,要求查询老师教的所有学生信息
第一种:关联查询
<!--    关联查询实现一对多查询-->
    <select id="getTeacherStudentList" parameterType="int" resultMap="TeacherStudent">
        select t.id tid, t.name tname, s.id sid, s.name sname from student s join teacher t on s.tid = t.id where t.id = #{tid}
    </select>
    <resultMap id="TeacherStudent" type="teacher">
        <result property="id" column="sid"/>
<!--        实体类中有集合,使用collection标签-->
        <collection property="studentList" ofType="Student">
            <result property="tid" column="tid"/>
        </collection>
    </resultMap>
第二种:子查询
<!--    子查询实现一对多查询-->
    <select id="getTeacherStudentList" resultMap="TeacherStudent">
        <where>
            <if test="tid != null">id = #{tid}</if>
        </where>
    </select>
        <collection property="studentList" javaType="ArrayList" ofType="Student" select="getStudentByTeacherId" column="id"/>
    </resultMap>
    <select id="getStudentByTeacherId" resultType="student">
        <where>
            <if test="tid != null">tid = #{tid}</if>
        </where>
    </select>
结果
两种方式,建议使用关联查询
结语
本周分享到此结束了,如果有问题的小伙伴可在评论区留言,若有不对之处,望各位大佬在评论区留言,我们共同进步,每周一个小案例,虚心学习,学习路上我们共行,加油,我们下周见,MyBatis系列文章!
