【愚公系列】2023年01月 Dapr分布式应用运行时-Dapr的安装
愚公搬代码 发表于 2023/01/31 21:29:31 2023/01/31
【摘要】 前言Dapr 是一个可移植的事件驱动运行时,使任何开发人员都可以轻松构建可复原的、 在云和边缘上运行的无状态和有状态应用程序,并包含 语言和开发人员框架。利用挎斗架构的优势,Dapr 帮助 您可以应对构建微服务带来的挑战,并使代码平台不可知。 一、Dapr的安装 1.window安装1、安装Daprwind11可以直接使用如下命令安装winget install Dapr.CLIwinge...
前言
一、Dapr的安装
1.window安装
1、安装Dapr
wind11可以直接使用如下命令安装
winget install Dapr.CLI.Preview
其他window系统MSI安装程序安装
Dapr CLI 的每个版本还包括一个 Windows 安装程序。您可以手动下载 MSI:
  • 从最新的 Dapr 版本下载 MSI 程序包。dapr.msi
  • 导航到下载的 MSI 文件,然后双击该文件以运行它。
  • 按照安装提示接受许可证和安装目录。所选文件夹将添加到用户 PATH 环境变量中。默认值设置为 。$Env:SystemDrive\dapr
  • 单击以开始安装。安装完成后,您将看到最后一条消息。Install
2、校验Dapr安装成功
dapr
2.liunx安装
2.1 官方脚本安装
wget -q https://raw.githubusercontent.com/dapr/cli/master/install/install.sh -O - | /bin/bash
通过重新启动终端/命令提示符并运行以下命令来验证 CLI 是否已安装:
dapr
         __
    ____/ /___ _____  _____
   / __  / __ '/ __ \/ ___/
  / /_/ / /_/ / /_/ / /
  \__,_/\__,_/ .___/_/
              /_/
Distributed Application Runtime
Usage:
  dapr [command]
Available Commands:
  completion     Generates shell completion scripts
  components     List all Dapr components. Supported platforms: Kubernetes
  configurations List all Dapr configurations. Supported platforms: Kubernetes
  dashboard      Start Dapr dashboard. Supported platforms: Kubernetes and self-hosted
  help           Help about any command
  init           Install Dapr on supported hosting platforms. Supported platforms: Kubernetes and self-hosted
  invoke         Invoke a method on a given Dapr application. Supported platforms: Self-hosted
  list           List all Dapr instances. Supported platforms: Kubernetes and self-hosted
  logs           Get Dapr sidecar logs for an application. Supported platforms: Kubernetes
  mtls           Check if mTLS is enabled. Supported platforms: Kubernetes
  publish        Publish a pub-sub event. Supported platforms: Self-hosted
  run            Run Dapr and (optionally) your application side by side. Supported platforms: Self-hosted
  status         Show the health status of Dapr services. Supported platforms: Kubernetes
  stop           Stop Dapr instances and their associated apps. . Supported platforms: Self-hosted
  uninstall      Uninstall Dapr runtime. Supported platforms: Kubernetes and self-hosted
  upgrade        Upgrades a Dapr control plane installation in a cluster. Supported platforms: Kubernetes
Flags:
  -h, --help      help for dapr
  -v, --version   version for dapr
Use "dapr [command] --help" for more information about a command.
2.2 二进制文件安装
下载二进制文件网址:https://github.com/dapr/cli/releases
下载完执行如下命令就ok
tar zxvf dapr_linux_amd64.tar.gz
mv dapr /usr/local/bin
3.初始化Dapr
dapr初始化可以在线,也可以离线
以管理员方式启动powershell
dapr uninstall 卸载 先卸载一下,以防有残留
1、在线初始化
powershell执行dapr init 执行成功后可以看到 在 C:\用户\用户名.dapr\ (注:用户名为自己电脑的名字)
2.离线初始化
离线初始话需要下载两个压缩文件
dashboard文件
daprd文件
①. 先在powershell执行dapr init因为网络问题失败也没关系,这里只是让他生成 components和config.yaml文件
②. dapr uninstall 卸载
③. 在 C:\用户\用户名.dapr\ 这个目录下新建 bin目录把两个文件解压后放到bin目录
④. 这时候在powershell上执行 dapr -v 就会发现 CLI和Runtime 都有版本号了
⑤. 在环境变量里面添加 C:\用户\用户名.dapr\ 目录配置
到这里就已经全部安装完成了。有的小伙伴可能在Github下载文件很慢。这里推荐用http://toolwa.com/github/ 这个把要下载的链接丢进去进行加速。
