Redis快速入门
凯哥Java 发表于 2023/01/31 08:55:31 2023/01/31
【摘要】 Redis快速入门,分两个客户端:Jedis和SpringDataRedis​使用Jdedis1、引入依赖<!--jedis--><dependency> <groupId>redis.clients</groupId> <artifactId>jedis</artifactId> <version>3.7.0</version></dependency><!--单元测试-...
ae47afafee6b8c6f753eafea7fb856f7.png​
使用Jdedis
1、引入依赖
<!--jedis-->
<dependency>
</dependency>
<!--单元测试-->
<dependency>
    <groupId>org.junit.jupiter</groupId>
    <artifactId>junit-jupiter</artifactId>
    <version>5.7.0</version>
    <scope>test</scope>
</dependency>
2、创建测试类:
import org.junit.jupiter.api.AfterEach;
import org.junit.jupiter.api.BeforeEach;
import org.junit.jupiter.api.Test;
import redis.clients.jedis.Jedis;
import java.util.HashMap;
import java.util.Map;
 * @author 凯哥Java
public class JedisTest {
    private Jedis jedis;
    @BeforeEach
    public void initJedis(){
        jedis = new Jedis("192.168.50.135",6379);
    @Test
    public void testString(){
        String result = jedis.set("name","kaige");
        System.out.println("set Result"+result);
        String nameValue = jedis.get("name");
        System.out.println("v:"+nameValue);
    @Test
    public void hashTest(){
        Map<String,String> value = new HashMap<>();
        value.put("id","1");
        value.put("name","hset1");
        value.put("age","23");
        Long result = jedis.hset("persion_1",value);
        String age = jedis.hget("persion_1","age");
        System.out.println("age:"+age);
    @AfterEach
    void tearDown() {
        if (jedis != null) {
            jedis.close();
说明:
如果生产环境就这么使用,会出问题的。jedis是线程不安全的,而且创建、销毁也是很消耗的。所以使用连接池方式:
创建连接池:
import redis.clients.jedis.JedisPool;
import redis.clients.jedis.JedisPoolConfig;
 * @author 凯哥Java
 * @description jedis连接池
public class JedisFactory {
    private static final JedisPool jedisPool;
    static {
        JedisPoolConfig poolConfig = new JedisPoolConfig();
        //最大连接数
        poolConfig.setMaxTotal(8);
        //最大空闲连接
        poolConfig.setMaxIdle(8);
        //等待市场
        poolConfig.setMaxWaitMillis(1000);
        //最小空闲连接
        poolConfig.setMinIdle(0);
        jedisPool = new JedisPool(poolConfig,"192.168.50.135",6379);
    public static Jedis getJedis(){
        return jedisPool.getResource();
使用:
二:springDataRedis
springData介绍:
springDataRedis中提供了RedisTemplate工具类,其中封装了各种对Redis的操作。并且将不同数据类型的操作API封装到了不同类型中:
spring 默认使用的是lettuce客户端的。如果要使用jedis的话,需要自己引入相关依赖。
使用springdataRedis步骤:
1:引入依赖
<!--Redis依赖-->
<dependency>
    <artifactId>spring-boot-starter-data-redis</artifactId>
</dependency>
<!--连接池依赖-->
<dependency>
    <groupId>org.apache.commons</groupId>
    <artifactId>commons-pool2</artifactId>
</dependency>
2:配置Redis
application.yaml文件:
spring:
  redis:
    host: 192.168.50.135
    port: 6379
    lettuce:
      pool:
        max-active: 8
        max-idle: 8
        min-idle: 0
        max-wait: 100ms
3:写测试类:
需要注意:在测试类上,一定要写入@RunWith(SpringRunner.class)这个注解。如果不写,会报redisTemplate空指针异常。
执行完成之后,我们到Redis库中查看:
为什么存入进去的数据,是乱码的呢?而且,有一个name,是我们自己set的,乱码的这个是我们通过RedisTemplate插入的,我们来看看RedisTemplate源码
RedisTemplate需要设置序列化:
我们跟set源码,会发现,set是使用了value的序列化:
跟着源码,我们知道,默认使用的是jdk自带的序列化工具。
为了解决两个name(一个是正常的name,一个是乱码的name)问题,乱码的缺点:
1:可读性差
2:内存占用较大
我们可以自定义RedisTemplate的序列化方式,代码如下:
import org.springframework.context.annotation.Bean;
import org.springframework.context.annotation.Configuration;
import org.springframework.data.redis.connection.RedisConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.serializer.GenericJackson2JsonRedisSerializer;
import org.springframework.data.redis.serializer.RedisSerializer;
 * @author 凯哥Java
@Configuration
public class RedisConfig {
    @Bean
    public RedisTemplate<String, Object> redisTemplate(RedisConnectionFactory connectionFactory){
        // 创建RedisTemplate对象
        RedisTemplate<String, Object> template = new RedisTemplate<>();
        // 设置连接工厂
        template.setConnectionFactory(connectionFactory);
        // 创建JSON序列化工具
        GenericJackson2JsonRedisSerializer jsonRedisSerializer =
                new GenericJackson2JsonRedisSerializer();
        // 设置Key的序列化
        template.setKeySerializer(RedisSerializer.string());
        template.setHashKeySerializer(RedisSerializer.string());
        // 设置Value的序列化
        template.setValueSerializer(jsonRedisSerializer);
        template.setHashValueSerializer(jsonRedisSerializer);
        // 返回
        return template;
配置好自定义的之后,再次执行,就可以了。
通过自定义序列化之后,我们在Redis中存入一个user对象:
存入值,我们发现在Redis库中,对象中多了类全路径。
这样有个缺点:增加了额外的内存开销的。那么这个时候怎么办呢?
我们可以规定,在使用String类型的时候,存入对象的是,需要先将对象序列化,然后获取后,在将对象反序列即可。
