算法题解—插入区间、杨辉三角、移除链表元素
共饮一杯无 发表于 2023/01/29 16:29:38 2023/01/29
【摘要】 插入区间给你一个** 无重叠的**_ ,_按照区间起始端点排序的区间列表。在列表中插入一个新的区间,你需要确保列表中的区间仍然有序且不重叠(如果有必要的话,可以合并区间)。示例 1:输入:intervals = [[1,3],[6,9]], newInterval = [2,5]输出:[[1,5],[6,9]]示例 2:输入:intervals = [[1,2],[3,5],[6,7],[...
插入区间
示例 1:
输出:[[1,5],[6,9]]
示例 2:
输入:intervals = [[1,2],[3,5],[6,7],[8,10],[12,16]], newInterval = [4,8]
输出:[[1,2],[3,10],[12,16]]
解释:这是因为新的区间 [4,8] 与 [3,5],[6,7],[8,10] 重叠。
示例 3:
输入:intervals = [], newInterval = [5,7]
输出:[[5,7]]
示例 4:
输入:intervals = [[1,5]], newInterval = [2,3]
输出:[[1,5]]
示例 5:
输入:intervals = [[1,5]], newInterval = [2,7]
输出:[[1,7]]
提示:
  • 0 <= intervals.length <= 104
  • intervals[i].length == 2
  • 0 <= intervals[i][0] <= intervals[i][1] <= 105
  • intervals 根据 intervals[i][0] 按 升序 排列
  • newInterval.length == 2
  • 0 <= newInterval[0] <= newInterval[1] <= 105
public class Interval {
    int start;
    int end;
    Interval() {
        start = 0;
        end = 0;
    Interval(int s, int e) {
        start = s;
        end = e;
class Solution {
    public int[][] insert(int[][] intervals, int[] newInterval) {
        int[][] newIntervals = new int[intervals.length + 1][];
        System.arraycopy(intervals, 0, newIntervals, 0, intervals.length);
        newIntervals[intervals.length] = newInterval;
        Arrays.sort(newIntervals, (a, b) -> a[0] - b[0]);
        Stack<int[]> stack = new Stack<>();
        for (int[] num : newIntervals) {
            if (stack.isEmpty()) {
                stack.push(num);
                continue;
            int[] arr = stack.peek();
            if (arr[1] >= num[0]) {
                int[] combine = { arr[0], Math.max(arr[1], num[1]) };
                stack.pop();
                stack.push(combine);
                stack.push(num);
        return stack.toArray(new int[0][]);
杨辉三角
给定一个非负整数 _numRows,_生成「杨辉三角」的前 _numRows _行。
在「杨辉三角」中,每个数是它左上方和右上方的数的和。
示例 1:
输入: numRows = 5 输出: [[1],[1,1],[1,2,1],[1,3,3,1],[1,4,6,4,1]]
示例 2:
输入: numRows = 1 输出: [[1]]
提示:
  • 1 <= numRows <= 30
class Solution {
    public List<List<Integer>> generate(int numRows) {
        List<List<Integer>> res = new ArrayList<List<Integer>>();
        if (numRows == 0) {
            return res;
        for (int i = 0; i < numRows; ++i) {
            List<Integer> temp = new ArrayList<Integer>();
            for (int j = 0; j <= i; ++j) {
                temp.add(numberget(i, j));
            res.add(temp);
        return res;
    public int numberget(int i, int j) {
        if (j == 0 || i == j) {
            return 1;
            return (numberget(i - 1, j - 1) + numberget(i - 1, j));
移除链表元素
给你一个链表的头节点 head 和一个整数 val ,请你删除链表中所有满足 Node.val == val 的节点,并返回 新的头节点 。
示例 1:
输入:head = [1,2,6,3,4,5,6], val = 6 输出:[1,2,3,4,5]
示例 2:
输入:head = [], val = 1 输出:[]
示例 3:
输入:head = [7,7,7,7], val = 7 输出:[]
提示:
  • 列表中的节点数目在范围 [0, 104] 内
  • 1 <= Node.val <= 50
  • 0 <= val <= 50
public class ListNode {
    int val;
    ListNode next;
    ListNode(int x) {
        val = x;
class Solution {
    public ListNode removeElements(ListNode head, int val) {
        ListNode top = new ListNode(0);
        top.next = head;
        ListNode pre = top;
        ListNode temp = head;
        while (temp != null) {
            if (temp.val == val)
                pre.next = temp.next;
            else
                pre = temp;
            temp = temp.next;
        return top.next;
本文内容到此结束了,
如有收获欢迎点赞👍收藏💖关注✔️,您的鼓励是我最大的动力。
如有错误❌疑问💬欢迎各位大佬指出。
保持热爱,奔赴下一场山海。🏃🏃🏃
