Linux下的主辅DNS服务器同步
江湖有缘 发表于 2023/01/16 13:41:55 2023/01/16
【摘要】 Linux下的主辅DNS服务器同步
一、系统环境介绍
系统:rhel8.0
control:192.168.200.150 -》主DNS(已配置)
node1:192.168.200.135 -》辅助DNS
node2:192.168.200.136
二、辅助DNS搭建
1.安装yum包
[root@node1 ~]# yum -y install bind bind-chroot
Updating Subscription Management repositories.
Unable to read consumer identity
This system is not registered to Red Hat Subscription Management. You can use subscription-manager to register.
Repository AppStream is listed more than once in the configuration
Repository BaseOS is listed more than once in the configuration
AppStream        165 kB/s | 3.2 kB     00:00
BaseOS        155 kB/s | 2.7 kB     00:00
ansiable        0.0  B/s |   0  B     00:00
Zabbix        1.3 kB/s | 2.9 kB     00:02
Failed to synchronize cache for repo 'ansiable', ignoring this repo.
Dependencies resolved.
 Package                          Arch                        Version                                     Repository                      Size
Installing:
 bind                             x86_64                      32:9.11.4-16.P2.el8                         AppStream                      2.1 M
 bind-chroot                      x86_64                      32:9.11.4-16.P2.el8                         AppStream                       99 k
Transaction Summary
Install  2 Packages
Total size: 2.2 M
Installed size: 4.7 M
Downloading Packages:
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Preparing        :        1/1
  Running scriptlet: bind-32:9.11.4-16.P2.el8.x86_64        1/2
  Installing       : bind-32:9.11.4-16.P2.el8.x86_64        1/2
  Installing       : bind-chroot-32:9.11.4-16.P2.el8.x86_64        2/2
  Running scriptlet: bind-chroot-32:9.11.4-16.P2.el8.x86_64        2/2
  Verifying        : bind-32:9.11.4-16.P2.el8.x86_64        1/2
  Verifying        : bind-chroot-32:9.11.4-16.P2.el8.x86_64        2/2
Installed products updated.
Installed:
  bind-32:9.11.4-16.P2.el8.x86_64                                    bind-chroot-32:9.11.4-16.P2.el8.x86_64
Complete!
2.设置服务自启
[root@node1 ~]# systemctl enable --now named
Created symlink /etc/systemd/system/multi-user.target.wants/named.service → /usr/lib/systemd/system/named.service.
3.编辑dns主配置文件
[root@node1 ~]# vim /etc/named.conf
options {
        listen-on port 53 { any; };
        listen-on-v6 port 53 { ::1; };
        directory       "/var/named";
        dump-file       "/var/named/data/cache_dump.db";
        statistics-file "/var/named/data/named_stats.txt";
        memstatistics-file "/var/named/data/named_mem_stats.txt";
        secroots-file   "/var/named/data/named.secroots";
        recursing-file  "/var/named/data/named.recursing";
        allow-query     { any; };
4.编辑区域文件
[root@node1 ~]# vim /etc/named.rfc1912.zones
zone "huaxia.com" IN {
        type slave;
        masters { 192.168.200.150; };
        file "slaves/named.zx";
zone "1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.ip6.arpa" IN {
        type master;
        file "named.loopback";
        allow-update { none; };
zone "200.168.192.in-addr.arpa" IN {
        type slave;
        file "slaves/named.fx";
5.配置正向文件
[root@node1 named]# cp -p named.localhost slaves/named.zx
[root@node1 named]# cp -p named.loopback slaves/named.fx
$TTL 1D
@       IN SOA  ns.huaxia.com. root. (
                                        20212401        ; serial
                                        10      ; refresh
                                        1H      ; retry
                                        10      ; expire
                                        10 )    ; minimum
@       NS      ns.huaxia.com.
ns IN   A       192.168.200.150
server0  IN A 192.168.200.150
备注:,正向、反向数据库文件主辅同步时间频率改为 10 秒,增加序列号,为方便快速看到同步效果,并且重启 named 服务。(生产环境中保持默认即可。)
6.配置反向文件
$TTL 1D
                                        20212413       ; serial
                                        10      ; refresh
                                        10      ; retry
                                        1W      ; expire
                                        10 )    ; minimum
@       NS      ns.huaxia.com
150     PTR     server0.example.com
7.重启服务和放行防火墙
[root@node1 named]# systemctl restart named
[root@node1 named]# firewall-cmd --permanent --add-service=dns
success
[root@node1 named]# firewall-cmd --reload
success
三、客户端指向DNS服务器
[root@node2 ~]# vim /etc/resolv.conf
# Generated by NetworkManager
search example.com ilt.example
nameserver 192.168.200.135
四、测试正向解析和反向解析
[root@node2 ~]# nslookup
> server0.huaxia.com
Server:		192.168.200.135
Address:	192.168.200.135#53
Address: 192.168.200.150
> 192.168.200.150
150.200.168.192.in-addr.arpa	name = www.huaxia.com.
六、测试主从同步
1.修改主DNS的正、反向配置文件
$TTL 1D
                                   2021062211           ; serial
                                        10      ; refresh
                                        10      ; retry
                                        1W      ; expire
                                        30 )    ; minimum
@        IN      NS      ns.huaxia.com.
www IN A 192.168.200.150
web IN CNAME web.huaxia.com.
* IN A 192.168.200.150
mail IN A 192.168.200.150
@ MX 10 mail.huaxia.com.
$TTL 1D
@       IN SOA    ns  root.huaxia.com  (
                                   2021062211           ; serial
                                        1D      ; refresh
                                        1H      ; retry
                                        1W      ; expire
                                        3H )    ; minimum
150           PTR      www.huaxia.com.
150     PTR   mail.huaxia.com.
150 PTR server0.example.com.
2.客户端检查是否dns同步
150.200.168.192.in-addr.arpa	name = server0.example.com.
150.200.168.192.in-addr.arpa	name = mail.huaxia.com.
[root@node2 ~]# nslookup server0.huaxia.com
[root@node2 ~]# nslookup www.huaxia.com
七、主DNS服务器搭建链接
Linux下的DNS服务器搭建
