SpringBoot实例
代码的路 发表于 2023/01/12 15:58:14 2023/01/12
【摘要】 原文链接Sprint Boot的完整实例,从数据库读取数据并使用Postman测试。项目地址:https://github.com/Snowstorm0/learn-spring-boot 1 本地数据库本地数据库创建教程:创建本地数据库user_data: 2 代码主体 2.1 Controller文件名MyController,内容为:@RestController@RequestMap...
原文链接
1 本地数据库
本地数据库创建教程:
创建本地数据库user_data:
2 代码主体
2.1 Controller
@RestController
@RequestMapping("/homepage")
public class MyController {
    @Resource
    MyService myService;
    @GetMapping("/learnSpringBoot")
    public String learnController(@RequestParam("number") int number){
        return myService.learnService(number);
2.2 Service
文件名MyService,内容为:
@Service
@EnableScheduling
public class MyService {
    @Resource
    MyMapper myMapper;
    public String learnService(int number){
        UserDTO res = myMapper.LearnMapper(number);
        String name = res.getName();
        System.out.println("name:" + name + "\n");
        return name;
2.3 dao
文件名MyMapper,内容为:
@Mapper
public interface MyMapper {
    UserDTO LearnMapper(int number);
2.4 model
文件名UserDTO,内容为:
@Data
public class UserDTO {
    private Integer number;
    private String name;
    public Integer getNumber() {
        return number;
    public void setNumber(Integer number) {
        this.number = number;
    public String getName() {
        return name;
    public void setName(String name) {
        this.name = name;
2.5 Application
在application.properties配置:
# 设置端口号
server.port=8888
在application.yml配置:
# 连接数据库
spring:
    datasource:
        url: jdbc:mysql://localhost:3306/sys
        driver-class-name: com.mysql.cj.jdbc.Driver
        password: root
        username: root
# 配置mapper.xml路径
mybatis:
    mapper-locations: classpath:mapper/*.xml
    type-aliases-package: com.spring.root.dao
3 Postman
配置Get,地址为: http://localhost:8888/homepage/learnSpringBoot
输入number:1001
即可获得返回的name:赵一
学习更多编程知识,请关注我的公众号:
代码的路
