Unittest接口和UI自动化测试框架中的发送邮件服务如何使用?
虫无涯 发表于 2023/01/12 15:32:25 2023/01/12
【摘要】 在写Unittest接口和UI自动化测试的时候,需要封装邮件模块来进行发送邮件。如何做呢?简单做一下整理。 1、在框架工具集中封装send_mail.py如图,我的在common中封装了send_mail.py代码如下:#coding=utf-8from email.mime.text import MIMETextimport timeimport smtplibimport getpas...
代码如下:
#coding=utf-8
import time
import smtplib
import getpass
from email.mime.multipart import MIMEMultipart
from email.mime.base import MIMEBase
from email import encoders
import email
import os
def sendmain(file_path,mail_to = 'xxxx@sdsdsd.com'):
    mail_from = 'xxx@126.com' # 发送邮件账号
    f = open(file_path,'rb')
    mail_body=f.read()
    f.close()
    #msg = email.MIMEMultipart.MIMEMultipart()
    msg = MIMEMultipart()
    # 构造MIMEBase对象做为文件附件内容并附加到根容器
    contype = 'application/octet-stream'
    maintype, subtype = contype.split('/', 1)
    ## 读入文件内容并格式化
    data = open(file_path, 'rb')
    file_msg = MIMEBase(maintype, subtype)
    file_msg.set_payload(data.read( ))
    data.close( )
    encoders.encode_base64(file_msg)
    ## 设置附件头
    basename = os.path.basename(file_path)
    file_msg.add_header('Content-Disposition',
                        'attachment', filename = basename)
    msg.attach(file_msg)
    print(u'msg 附件添加成功')
    msg1 = MIMEText(mail_body,_subtype='html',_charset='utf-8')
    msg.attach(msg1)
    if isinstance(mail_to,str):
        msg['To'] = mail_to
    else:
        msg['To'] = ','.join(mail_to)
    msg['From'] = mail_from
    msg['Subject'] = u'zzzz项目接口自动化测试'
    msg['date']=time.strftime('%Y-%m-%d-%H_%M_%S')
    print(msg['date'])
    smtp = smtplib.SMTP()
    smtp.connect('smtp.126.com')
    smtp.login('xxx@126.com','123456') # 发送邮件账号密码
    smtp.sendmail(mail_from, mail_to, msg.as_string())
    smtp.quit()
    print('email has send out !')
if __name__=='__main__':
    sendmain('../report/2017-08-18-10_18_57_result.html')
2、 在主框架入口调用邮件模块
    # HTML报告
    now = datetime.datetime.now().strftime('%Y-%m-%d_%H_%M_%S')
    htmlreport = reportpath + "/" + now + r"result.html"
    print("测试报告生成地址:%s"% htmlreport)
    fp = open(htmlreport, "wb")
    runner = HTMLTestRunner.HTMLTestRunner(stream=fp, verbosity=2, title="xxxx项目接口自动化测试报告", description="用例执行情况")
    # 调用add_case函数返回值
    runner.run(all_case)
    fp.close()
    time.sleep(2)
    sendmain(htmlreport, mail_to=['yyyyy@qq.com']) # 填写需要发送给对方邮件账号,用逗号隔开,可写多个
