Structured Streaming报错记录:Overloaded method foreachBatch with alt
WHYBIGDATA 发表于 2023/01/12 15:05:20 2023/01/12
【摘要】 Structured Streaming报错记录:Overloaded method foreachBatch with alternatives
0. 写在前面
  • Spark : Spark3.0.0
  • Scala : Scala2.12
1. 报错
overloaded method value foreachBatch with alternatives:
2. 代码及报错信息
Error:(48, 12) overloaded method value foreachBatch with alternatives:
(function:org.apache.spark.api.java.function.VoidFunction2[org.apache.spark.sql.Dataset[org.apache.spark.sql.Row],java.lang.Long])org.apache.spark.sql.streaming.DataStreamWriter[org.apache.spark.sql.Row] <and>
(function: (org.apache.spark.sql.Dataset[org.apache.spark.sql.Row], scala.Long) => Unit)org.apache.spark.sql.streaming.DataStreamWriter[org.apache.spark.sql.Row]
cannot be applied to ((org.apache.spark.sql.Dataset[org.apache.spark.sql.Row], Any) => org.apache.spark.sql.Dataset[org.apache.spark.sql.Row])
.foreachBatch((df, batchId) => {
import java.util.Properties
import org.apache.spark.sql.streaming.{StreamingQuery, Trigger}
import org.apache.spark.sql.{DataFrame, SparkSession}
object ForeachBatchSink1 {
    def main(args: Array[String]): Unit = {
        val spark: SparkSession = SparkSession
            .builder()
            .master("local[*]")
            .appName("ForeachSink1")
            .getOrCreate()
        import spark.implicits._
        val lines: DataFrame = spark.readStream
            .format("socket") // 设置数据源
            .option("host", "cluster01")
            .option("port", 10000)
            .load
        val props = new Properties()
        props.setProperty("user", "root")
        props.setProperty("password", "1234")
        val query: StreamingQuery = lines.writeStream
            .outputMode("update")
                val result = df.as[String].flatMap(_.split("\\W+")).groupBy("value").count()
                result.persist()
              result.write.mode("overwrite").jdbc("jdbc:mysql://cluster01:3306/test","wc", props)
                result.write.mode("overwrite").json("./foreach1")
                result.unpersist()
//            .trigger(Trigger.ProcessingTime(0))
            .trigger(Trigger.Continuous(10))
            .start
        query.awaitTermination()
  • Error:(43, 12) overloaded method value foreachBatch with alternatives:
  • (function:org.apache.spark.api.java.function.VoidFunction2[org.apache.spark.sql.Dataset[org.apache.spark.sql.Row],java.lang.Long])org.apache.spark.sql.streaming.DataStreamWriter[org.apache.spark.sql.Row] <and>
  • (function: (org.apache.spark.sql.Dataset[org.apache.spark.sql.Row], scala.Long) => Unit)org.apache.spark.sql.streaming.DataStreamWriter[org.apache.spark.sql.Row]
  • cannot be applied to ((org.apache.spark.sql.Dataset[org.apache.spark.sql.Row], Any) => org.apache.spark.sql.DataFrame)
  • .foreachBatch((df, batchId) => {
object ForeachBatchSink {
            .builder()
            .master("local[*]")
            .appName("ForeachSink")
            .getOrCreate()
            .load
            .outputMode("complete")
                result.persist()
                result.write.mode("overwrite").json("./foreach")
                result.unpersist()
            .start
3. 原因及纠错
Scala2.12版本和2.11版本的不同,对于foreachBatch()方法的实现不太一样
正确代码如下
import org.apache.spark.sql.streaming.StreamingQuery
import org.apache.spark.sql.{DataFrame, Dataset, Row, SparkSession}
    def myFun(df: Dataset[Row], batchId: Long, props: Properties): Unit = {
        println("BatchId" + batchId)
        if (df.count() != 0) {
            df.persist()
            df.write.mode("overwrite").jdbc("jdbc:mysql://cluster01:3306/test","wc", props)
            df.write.mode("overwrite").json("./StructedStreaming_sink-ForeachBatchSink")
            df.unpersist()
          .builder()
          .master("local[2]")
          .appName("ForeachBatchSink")
          .getOrCreate()
          .format("socket") // TODO 设置数据源
          .load
        val wordCount: DataFrame = lines.as[String]
          .groupBy("value")
          .count()  // value count
        val query: StreamingQuery = wordCount.writeStream
          .foreachBatch((df : Dataset[Row], batchId : Long) => {
              myFun(df, batchId, props)
          .start
    def myFun(df: Dataset[Row], batchId: Long, props: Properties, spark : SparkSession): Unit = {
        println("BatchId = " + batchId)
            result.persist()
            result.write.mode("overwrite").json("./StructedStreaming_sink-ForeachBatchSink1")
            result.unpersist()
          .builder()
          .master("local[2]")
          .appName("ForeachBatchSink1")
          .getOrCreate()
          .load
                myFun(df, batchId, props, spark)
          .start
4. 参考链接
https://blog.csdn.net/Shockang/article/details/120961968
