Oracle性能视图
张谱继 发表于 2023/01/02 17:39:40 2023/01/02
【摘要】  扩展条件v$sessionv$sqlsql_id,sql_child_numberv$sqlpre_sql_id,pre_child_numberv$processpaddrdba_usersusernamedba_usersschemanamedba_proceduresplsql_entry_object_id  plsql_entry_subprogram_idplsql_objec...
  扩展 条件
v$session v$sql sql_id,sql_child_number
v$sql pre_sql_id,pre_child_number
v$process paddr
dba_users username
dba_users schemaname
dba_procedures plsql_entry_object_id  plsql_entry_subprogram_id
plsql_object_id,pl_subprogram_id
v$transaction taddr
dba_objects row_wait_obj#,row_wait_block#
dba_data_files row_wait_file#,row_wait_row#
v$event_name event,p1text,p2text,pstext
wait_class,p1raw,p2raw,p3raw
v$session blocking_session,blocking_instance
final_blocking_session,final_blocking_instance
数据字典 采样周期(默认) 保留时间(默认)
gv$session 实时 当前
gv$active_session_history 1s 6小时
dba_hist_active_sess_history 10s 30天
数据字典 解释
gv$transaction 事务表 used_ublk使用了多少回滚块(8k)
used_urec事务影响了多少数据量,包括索引记录
gv$fast_start_transactions 回滚事务表 undoblocksdone、undoblockstotal 待回归数据块
rcvservers用了多少个服务器进程回滚
数据字典 AWR
gv$sql dba_hist_sqltext 原始SQL游标,包括文本等执行信息
gv$sql_plan dba_hist_sql_plan sql执行计划信息
gv$sqlstats dba_hist_sqlstat sql统计信息
gv$sql_bind_capture dba_hist_sqlbind sql绑定变量信息
dba_sql_profiles sql profile执行计划
dba_sql_plan_baselines
gv$sql_monitor SQL Monitor主视图
gv$sql_plan_monitor SQL Monitor执行计划视图
