K8S/Kubernetes 命令
张谱继 发表于 2023/01/02 10:32:34 2023/01/02
【摘要】 命令作用kubectl rollout undo deployment/abcRollback to the previous deploymentkubectl rollout status daemonset/fooCheck the rollout status of a daemonsetkubectl rollout restart deployment/abcRestart a ...
命令
作用
Restart a deployment
kubectl rollout history deployment/abc
View the rollout history of a deployment
kubectl rollout history daemonset/abc --revision=3
View the details of daemonset revision 3  查看daemonset修订版3的详细信息
kubectl rollout undo daemonset/abc --to-revision=3
Roll back to daemonset revision 3
kubectl logs --since=1h nginx
Show all logs from pod nginx written in the last hour  h,m,s
kubectl logs --tail=20 nginx
Display only the most recent 20 lines of output in pod nginx
kubectl exec mypod -- date
Get output from running the 'date' command from pod mypod, using the first container by default
kubectl explain pods.spec.containers
Get the documentation of a specific field of a resource
kubectl top pod POD_NAME --containers
kubectl get pods -o wide
List all pods in ps output format with more information (such as node name)
kubectl get -o json pod web-pod-13je7
List a single pod in JSON output format
List resource information in custom columns
kubectl get pod test-pod -o custom-columns=CONTAINER:.spec.containers[0].name,IMAGE:.spec.containers[0].image
kubectl label pods my-pod new-label=awesome
Add a Label
kubectl scale --replicas=3 rs/foo
Scale a replicaset named 'foo' to 3
kubectl cp my-namespace/my-pod:/tmp/foo /tmp/bar
Copy /tmp/foo from a remote pod to /tmp/bar locally
Delete all pods matching the awk pattern1 or pattern2
kubectl get pods  -n mynamespace --no-headers=true | awk '/pattern1|pattern2/{print $1}' | xargs  kubectl delete -n mynamespace pod
kubectl get quota
查看资源情况
kubectl describe pod xxx
查看状态
kubectl get events
https://moelove.info/2021/12/28/%E5%BD%BB%E5%BA%95%E6%90%9E%E6%87%82-Kubernetes-%E4%B8%AD%E7%9A%84-Events/
管理多個 Kubernetes Cluster:建立、切換、合併 context   来自 <https://www.akiicat.com/2019/04/24/Kubernetes/setup-kubernetes-configuration/>
kubectl config --help
查看kubectl config 命令使用说明
kubectl config view
查看kubeconfig,上下文内容
kubectl config get-contexts
查看有哪些上下文
kubectl config use-context <context-name>
切换上下文,如果权限不足,采用每次kubectl命令指定上下文,kubectl --context=<context-name>  替代
kubectl api-resources
来查看所有api资源,比如pod,service,rs,rc,deploy,resource https://www.cnblogs.com/tylerzhou/p/11043285.html
kubectl get pod -A
加入-A参数,表示查看所有命名空间上的Pod
kubectl get pod podname  -o custom-columns='pod:.metadata.name,container:.spec.containers[*].name'
查看pod中的所有容器   container
获取容器规格限制
kubectl -n xxx get pods -l app=xxx -o=jsonpath='{range .items[*]}{.metadata.name}{"\t"}{range .spec.containers[*]}{.resources.limits.cpu}{"\t"}{.resources.limits.memory}{end}{"\n"}{end}'
kubectl -n namespace get pods -l app=xxx -o=jsonpath='{range .items[*]}{.metadata.name}{"\t"}{range .spec.containers[*]}{.resources.limits.cpu}{"\t"}{.resources.limits.memory}{end}{"\n"}{end}'
容器规格+启动时间
Examples using -o=custom-columns:
kubectl -n namespace get pods -o custom-columns='name:.metadata.name,cpu:.spec.containers[*].resources.limits.cpu,memory:.spec.containers[*].resources.limits.memory,startedAt:.status.containerStatuses[*].state.running.startedAt,image:.status.containerStatuses[*].image'
特殊场景处理样例
 kubectl get node -o custom-columns=node:.metadata.name,zone:.metadata.labels."topology\.kubernetes\.io/zone",region:.metadata.labels."topology\.kubernetes\.io/region",nodepool:.metadata.labels."cce\.cloud\.com/cce-nodepool"
对于特殊字符的处理,\ 转义,并用双引号处理
