Spring基础(十三):JDBCTemplate的批操作
Lansonli 发表于 2022/12/26 13:19:30 2022/12/26
【摘要】 JDBCTemplate的批操作一次连接,操作表格里的多条数据,就是批量操作。案例操作批量增加批量修改批量删除一、实体类package com.lanson.pojo;import lombok.AllArgsConstructor;import lombok.Data;import lombok.NoArgsConstructor;import java.io.Serializable;/...
JDBCTemplate的批操作
案例操作
  • 批量增加
  • 批量修改
  • 批量删除
一、实体类
import lombok.Data;
 * @Author: Lansonli
 * @Description: MircoMessage:Mark_7001
@AllArgsConstructor
@NoArgsConstructor
@Data
public class Dept implements Serializable {
    private Integer deptno;
    private String dname;
    private String loc;
二、DeptService
package com.lanson.service;
import com.lanson.pojo.Dept;
import java.util.List;
 * @Author: Lansonli
public interface DeptService {
    int[] deptBatchAdd(List<Dept> depts);
    int[] deptBatchUpdate(List<Dept> depts);
    int[] deptBatchDelete(List<Integer> deptnos);
package com.lanson.service.impl;
import com.lanson.dao.DeptDao;
import com.lanson.service.DeptService;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.stereotype.Service;
 * @Author: Lansonli
@Service
public class DeptServiceImpl implements DeptService {
    @Autowired
    private DeptDao deptDao;
    @Override
    public int[] deptBatchAdd(List<Dept> depts) {
        return deptDao.deptBatchAdd(depts);
    @Override
    public int[] deptBatchUpdate(List<Dept> depts) {
        return  deptDao.deptBatchUpdate(depts);
    @Override
    public int[] deptBatchDelete(List<Integer> deptnos) {
        return  deptDao.deptBatchDelete(deptnos);
三、DeptDao
package com.lanson.dao;
 * @Author: Lansonli
public interface DeptDao {
package com.lanson.dao.impl;
import org.springframework.jdbc.core.JdbcTemplate;
import org.springframework.stereotype.Repository;
import java.util.LinkedList;
 * @Author: Lansonli
@Repository
public class DeptDaoImpl implements DeptDao {
    @Autowired
    private JdbcTemplate jdbcTemplate;
    @Override
        String sql ="insert into dept values(DEFAULT,?,?)";
        List<Object[]> args =new LinkedList<>();
        for (Dept dept : depts) {
            Object[] arg ={dept.getDname(),dept.getLoc()};
            args.add(arg);
        return jdbcTemplate.batchUpdate(sql, args);
    @Override
        String sql ="update dept set dname =? ,loc =? where deptno=?";
            Object[] arg ={dept.getDname(),dept.getLoc(),dept.getDeptno()};
            args.add(arg);
    @Override
        String sql ="delete from dept where deptno =?";
        for (Integer deptno : deptnos) {
            Object[] arg ={deptno};
            args.add(arg);
四、测试
package com.lanson.test;
import com.lanson.service.EmpService;
import org.junit.Test;
import org.springframework.context.ApplicationContext;
import org.springframework.context.support.ClassPathXmlApplicationContext;
import java.util.ArrayList;
import java.util.Arrays;
 * @Author: Lansonli
public class Test2 {
    @Test
    public void testBatchAdd(){
        ApplicationContext context=new ClassPathXmlApplicationContext("applicationContext.xml");
        DeptService deptService = context.getBean(DeptService.class);
        List<Dept> depts =new ArrayList<>();
        for (int i = 0; i < 10; i++) {
            depts.add(new Dept(null,"name"+i,"loc"+i));
        int[] ints = deptService.deptBatchAdd(depts);
        System.out.println(Arrays.toString(ints));
    @Test
    public void testBatchUpdate(){
        for (int i = 51; i <=60; i++) {
            depts.add(new Dept(i,"newname","newLoc"));
        int[] ints = deptService.deptBatchUpdate(depts);
    @Test
    public void testBatchDelete(){
        List<Integer> deptnos =new ArrayList<>();
        for (int i = 51; i <=69; i++) {
            deptnos.add(i);
        int[] ints = deptService.deptBatchDelete(deptnos);
