linux运维常用脚本
torchstar 发表于 2022/12/23 23:29:18 2022/12/23
【摘要】 linux运维常用脚本
一、找出占用CPU 内存过高的进程
#!/bin/bash
echo "-------------------CUP占用前10排序--------------------------------"
ps -eo user,pid,pcpu,pmem,args --sort=-pcpu  |head -n 10
echo "-------------------内存占用前10排序--------------------------------"
ps -eo user,pid,pcpu,pmem,args --sort=-pmem  |head -n 10
二、查看网卡的实时流量
#!/bin/bash
eth0=$1
echo  -e    "流量进入--流量传出    "
while true; do
    old_in=$(cat /proc/net/dev |grep $eth0 |awk '{print $2}')
    old_out=$(cat /proc/net/dev |grep $eth0 |awk '{print $10}')
    sleep 1
    new_in=$(cat /proc/net/dev |grep $eth0 |awk '{print $2}')
    new_out=$(cat /proc/net/dev |grep $eth0 |awk '{print $10}')
    in=$(printf "%.1f%s" "$((($new_in-$old_in)/1024))" "KB/s")
    out=$(printf "%.1f%s" "$((($new_out-$old_out)/1024))" "KB/s")
    echo "$in $out"
done
三、一键部署LNMP网站平台脚本
#!/bin/bash
NGINX_V=1.15.6
PHP_V=5.6.36
TMP_DIR=/tmp
INSTALL_DIR=/usr/local
PWD_C=$PWD
echo
echo -e "\tMenu\n"
echo -e "1. Install Nginx"
echo -e "2. Install PHP"
echo -e "3. Install MySQL"
echo -e "4. Deploy LNMP"
echo -e "9. Quit"
function command_status_check() {
    if [ $? -ne 0 ]; then
        echo $1
        exit
    fi
function install_nginx() {
    cd $TMP_DIR
    yum install -y gcc gcc-c++ make openssl-devel pcre-devel wget
    wget http://nginx.org/download/nginx-${NGINX_V}.tar.gz
    tar zxf nginx-${NGINX_V}.tar.gz
    cd nginx-${NGINX_V}
    ./configure --prefix=$INSTALL_DIR/nginx \
    --with-http_ssl_module \
    --with-http_stub_status_module \
    --with-stream
    command_status_check "Nginx - 平台环境检查失败!"
    make -j 4
    command_status_check "Nginx - 编译失败!"
    make install
    command_status_check "Nginx - 安装失败!"
    mkdir -p $INSTALL_DIR/nginx/conf/vhost
    alias cp=cp ; cp -rf $PWD_C/nginx.conf $INSTALL_DIR/nginx/conf
    rm -rf $INSTALL_DIR/nginx/html/*
    echo "ok" > $INSTALL_DIR/nginx/html/status.html
    echo '<?php echo "ok"?>' > $INSTALL_DIR/nginx/html/status.php
    $INSTALL_DIR/nginx/sbin/nginx
    command_status_check "Nginx - 启动失败!"
function install_php() {
    cd $TMP_DIR
    yum install -y gcc gcc-c++ make gd-devel libxml2-devel \
        libcurl-devel libjpeg-devel libpng-devel openssl-devel \
        libmcrypt-devel libxslt-devel libtidy-devel
    wget http://docs.php.net/distributions/php-${PHP_V}.tar.gz
    tar zxf php-${PHP_V}.tar.gz
    cd php-${PHP_V}
    ./configure --prefix=$INSTALL_DIR/php \
    --with-config-file-path=$INSTALL_DIR/php/etc \
    --enable-fpm --enable-opcache \
    --with-mysql --with-mysqli --with-pdo-mysql \
    --with-openssl --with-zlib --with-curl --with-gd \
    --with-jpeg-dir --with-png-dir --with-freetype-dir \
    --enable-mbstring --enable-hash
    command_status_check "PHP - 平台环境检查失败!"
    make -j 4
    command_status_check "PHP - 编译失败!"
    make install
    command_status_check "PHP - 安装失败!"
    cp php.ini-production $INSTALL_DIR/php/etc/php.ini
    cp sapi/fpm/php-fpm.conf $INSTALL_DIR/php/etc/php-fpm.conf
    cp sapi/fpm/init.d.php-fpm /etc/init.d/php-fpm
    chmod +x /etc/init.d/php-fpm
    /etc/init.d/php-fpm start
    command_status_check "PHP - 启动失败!"
read -p "请输入编号:" number
case $number in
    1)
        install_nginx;;
    2)
        install_php;;
    3)
        install_mysql;;
    4)
        install_nginx
        install_php
    9)
        exit;;
esac
四、服务器系统配置初始化
#/bin/bash
# 安装系统性能分析工具及其他
yum install gcc make autoconf vim sysstat net-tools iostat iftop iotp wget lrzsz lsof unzip openssh-clients net-tool vim ntpdate -y
# 设置时区并同步时间
ln -s /usr/share/zoneinfo/Asia/Shanghai /etc/localtime
if ! crontab -l |grep ntpdate &>/dev/null ; then
    (echo "* 1 * * * ntpdate time.windows.com >/dev/null 2>&1";crontab -l) |crontab
fi
# 禁用selinux
sed -i '/SELINUX/{s/permissive/disabled/}' /etc/selinux/config
# 关闭防火墙
if egrep "7.[0-9]" /etc/redhat-release &>/dev/null; then
    systemctl stop firewalld
    systemctl disable firewalld
elif egrep "6.[0-9]" /etc/redhat-release &>/dev/null; then
    service iptables stop
    chkconfig iptables off
fi
# 历史命令显示操作时间
if ! grep HISTTIMEFORMAT /etc/bashrc; then
    echo 'export HISTTIMEFORMAT="%Y-%m-%d %H:%M:%S  `whoami` "' >> /etc/bashrc
fi
# SSH超时时间
if ! grep "TMOUT=600" /etc/profile &>/dev/null; then
    echo "export TMOUT=600" >> /etc/profile
fi
# 禁止root远程登录 切记给系统添加普通用户,给su到root的权限
sed -i 's/#PermitRootLogin yes/PermitRootLogin no/' /etc/ssh/sshd_config
# 禁止定时任务向发送邮件
sed -i 's/^MAILTO=root/MAILTO=""/' /etc/crontab
# 设置最大打开文件数
if ! grep "* soft nofile 65535" /etc/security/limits.conf &>/dev/null; then
cat >> /etc/security/limits.conf << EOF
    * soft nofile 65535
    * hard nofile 65535
EOF
fi
# 系统内核优化
cat >> /etc/sysctl.conf << EOF
net.ipv4.tcp_syncookies = 1
net.ipv4.tcp_max_tw_buckets = 20480
net.ipv4.tcp_max_syn_backlog = 20480
net.core.netdev_max_backlog = 262144
net.ipv4.tcp_fin_timeout = 20
EOF
# 减少SWAP使用
echo "0" > /proc/sys/vm/swappiness
五、批量创建多个用户并设置密码
#!/bin/bash
USER_LIST=$@
USER_FILE=./user.info
for USER in $USER_LIST;do
    if ! id $USER &>/dev/null; then
        PASS=$(echo $RANDOM |md5sum |cut -c 1-8)
        useradd $USER
        echo $PASS | passwd --stdin $USER &>/dev/null
        echo "$USER   $PASS" >> $USER_FILE
        echo "$USER User create successful."
    else
        echo "$USER User already exists!"
    fi
done
六、一键查看服务器利用率
#!/bin/bash
function cpu(){
    util=$(vmstat | awk '{if(NR==3)print $13+$14}')
    iowait=$(vmstat | awk '{if(NR==3)print $16}')
    echo "CPU -使用率:${util}% ,等待磁盘IO相应使用率:${iowait}:${iowait}%"
function memory (){
    total=`free -m |awk '{if(NR==2)printf "%.1f",$2/1024}'`
    used=`free -m |awk '{if(NR==2) printf "%.1f",($2-$NF)/1024}'`
    available=`free -m |awk '{if(NR==2) printf "%.1f",$NF/1024}'`
    echo "内存 - 总大小: ${total}G , 使用: ${used}G , 剩余: ${available}G"
disk(){
    fs=$(df -h |awk '/^\/dev/{print $1}')
    for p in $fs; do
        mounted=$(df -h |awk '$1=="'$p'"{print $NF}')
        size=$(df -h |awk '$1=="'$p'"{print $2}')
        used=$(df -h |awk '$1=="'$p'"{print $3}')
        used_percent=$(df -h |awk '$1=="'$p'"{print $5}')
        echo "硬盘 - 挂载点: $mounted , 总大小: $size , 使用: $used , 使用率: $used_percent"
    done
function tcp_status() {
    summary=$(ss -antp |awk '{status[$1]++}END{for(i in status) printf i":"status[i]" "}')
    echo "TCP连接状态 - $summary"
cpu
memory
disk
tcp_status
七、Nginx访问日志分析
#!/bin/bash
# 日志格式: $remote_addr - $remote_user [$time_local] "$request" $status $body_bytes_sent "$http_referer" "$http_user_agent" "$http_x_forwarded_for"
LOG_FILE=$1
echo "统计访问最多的10个IP"
awk '{a[$1]++}END{print "UV:",length(a);for(v in a)print v,a[v]}' $LOG_FILE |sort -k2 -nr |head -10
echo "----------------------"
echo "统计时间段访问最多的IP"
awk '$4>="[01/Dec/2018:13:20:25" && $4<="[27/Nov/2018:16:20:49"{a[$1]++}END{for(v in a)print v,a[v]}' $LOG_FILE |sort -k2 -nr|head -10
echo "统计访问最多的10个页面"
awk '{a[$7]++}END{print "PV:",length(a);for(v in a){if(a[v]>10)print v,a[v]}}' $LOG_FILE |sort -k2 -nr
echo "统计访问页面状态码数量"
awk '{a[$7" "$9]++}END{for(v in a){if(a[v]>5)print v,a[v]}}' $LOG_FILE |sort -k3 -nr
