Python 实现Web隐藏目录扫描
LYSHARK 发表于 2022/12/21 18:04:07 2022/12/21
【摘要】 Web隐藏目录扫描: 首先你需要自己寻找一个靠谱的字典,放入脚本根目录并命名为dict.log每行一个路径名称.import requests,threadingimport argparsefrom queue import Queuehead={'user-agent':'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KH...
import argparse
head={'user-agent':'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36'}
class DirScan(threading.Thread):
    def __init__(self,queue):
        threading.Thread.__init__(self)
        self._queue = queue
    def run(self):
        while not self._queue.empty():
            url = self._queue.get()
            try:
                req = requests.get(url=url,headers=head,timeout=5)
                if req.status_code == 200:
                    print("[+] " + url)
                    wr = open("result.html","a+")
                    wr.write('<a href="' + url + '" target="_blank">' + url + '</a></br>')
            except Exception:
                pass
def StartThread(url,count):
    queue = Queue()
    threads = []
    thread_count = int(count)
    fp = open("dict.log","r",encoding="utf-8")
    for item in fp:
        queue.put(url+item.rstrip("\n"))
    for item in range(thread_count):
        threads.append(DirScan(queue))
    for t in threads:
        t.start()
    for t in threads:
        t.join()
def Banner():
    print("  _          ____  _                _    ")
    print(" | |   _   _/ ___|| |__   __ _ _ __| | __")
    print(" | |  | | | \___ \| '_ \ / _` | '__| |/ /")
    print(" | |__| |_| |___) | | | | (_| | |  |   < ")
    print(" |_____\__, |____/|_| |_|\__,_|_|  |_|\_\\")
    print("       |___/                             \n")
    print("E-Mail: me@lyshark.com")
if __name__ == "__main__":
    # 使用方式: main.py -u http://www.lyshark.com -t 10
	Banner()
    parser = argparse.ArgumentParser()
    parser.add_argument("-u","--url",dest="url",help="Specify the URL of the blast")
    parser.add_argument("-t","--thread",dest="count",default=5,help="Specify the number of threads to open")
    args = parser.parse_args()
    if args.url:
        StartThread(args.url,args.count)
    else:
        parser.print_help()
Web应用目录扫描器: 这里的前提是Web服务器使用的是开源CMS来建站的,而且自己也下载了一套相应的开源代码,感觉意义并不大。
import Queue
import threading
import os
import urllib2
threads = 10
target = "http://www.lyshark.com/"
directory = "/lysh"
filters = [".jpg",".gif",".png",".css"]
os.chdir(directory)
web_paths = Queue.Queue()
for r,d,f in os.walk("."):
    for files in f:
        remote_path = "%s/%s"%(r,files)
        if remote_path.startswith("."):
            remote_path = remote_path[1:]
        if os.path.splitext(files)[1] not in filters:
            web_paths.put(remote_path)
def test_remote():
    while not web_paths.empty():
        path = web_paths.get()
        url = "%s%s"%(target,path)
        request = urllib2.Request(url)
        try:
            response = urllib2.urlopen(request)
            content = response.read()
            print("[%d] => %s"%(response.code,path))
            response.close()
        except urllib2.HTTPError as error:
            pass
for i in range(threads):
    t = threading.Thread(target=test_remote)
    t.start()
暴力破解目录和文件位置:
import urllib2
import threading
import Queue
import urllib
threads = 50
target_url = "http://testphp.vulnweb.com"
wordlist_file = "/tmp/all.txt" # from SVNDigger
resume = None
user_agent = "Mozilla/5.0 (X11; Linux x86_64; rv:52.0) Gecko/20100101 Firefox/52.0"
def build_wordlist(wordlist_file):
    #读入字典文件
    fd = open(wordlist_file,"rb")
    raw_words = fd.readlines()
    fd.close()
    found_resume = False
    words = Queue.Queue()
    for word in raw_words:
        word = word.rstrip()
        if resume is not None:
            if found_resume:
                words.put(word)
            else:
                if word == resume:
                    found_resume = True
                    print "Resuming wordlist from: %s"%resume
        else:
            words.put(word)
    return words
def dir_bruter(word_queue,extensions=None):
    while not word_queue.empty():
        attempt = word_queue.get()
        attempt_list = []
        #检测是否有文件扩展名,若没有则就是要暴力破解的路径
        if "." not in attempt:
            attempt_list.append("/%s/"%attempt)
        else:
            attempt_list.append("/%s"%attempt)
        #如果我们想暴破扩展
        if extensions:
            for extension in extensions:
                attempt_list.append("/%s%s"%(attempt,extension))
        #迭代我们要尝试的文件列表
        for brute in attempt_list:
            url = "%s%s"%(target_url,urllib.quote(brute))
            try:
                headers = {}
                headers["User-Agent"] = user_agent
                r = urllib2.Request(url,headers=headers)
                response = urllib2.urlopen(r)
                if len(response.read()):
                    print "[%d] => %s"%(response.code,url)
            except urllib2.URLError, e:
                if hasattr(e,'code') and e.code != 404:
                    print "!!! %d => %s"%(e.code,url)
                pass
word_queue = build_wordlist(wordlist_file)
extensions = [".php",".bak",".orig",".inc"]
    t = threading.Thread(target=dir_bruter,args=(word_queue,extensions,))
    t.start()
