Python 实现文件关键字扫描
LYSHARK 发表于 2022/12/21 18:00:45 2022/12/21
【摘要】 第一段代码用户传入一个文件夹,自动扫描文件夹内特定文件是否存在某些关键字,如果存在则输出该文件的路径信息。# coding=gbkimport sys,os,redef spider(script_path,script_type): final_files = [] for root, dirs, files in os.walk(script_path, topdown=Fa...
# coding=gbk
import sys,os,re
    final_files = []
    for root, dirs, files in os.walk(script_path, topdown=False):
            for fi in files:
                dfile = os.path.join(root, fi)
                if dfile.endswith(script_type):
                    final_files.append(dfile.replace("\\","/"))
    print("[+] 共找到了 {} 个PHP文件".format(len(final_files)))
    return final_files
def scanner(files_list,cmd):
    for item in files_list:
        fp = open(item, "r",encoding="utf-8")
        data = fp.readlines()
        for line in data:
            Code_line = data.index(line) + 1
            Now_code = line.strip("\n")
            for unsafe in [cmd]:
                flag = re.findall(unsafe, Now_code)
                if len(flag) != 0:
                    print("函数: {} ---> 函数所在行: {} ---> 路径: {} " .\
                          format(flag,Code_line,item))
if __name__ == "__main__":
    path = sys.argv[1]
    shell = sys.argv[2]
    ret = spider(path,".php")
    scanner(ret,shell)
第二段代码主要用于监控MWeb页面执行过的SQL语句,在指定页面上访问网页,列出所执行的SQL语句,挖掘SQL注入必备。
# coding=gbk
import pymysql,re
#conn = pymysql.connect(host='127.0.0.1', port=3306, user='root', passwd='123456', db='mysql', charset='utf8')
#cursor = conn.cursor()
#cursor.execute("SET GLOBAL general_log='ON';")
#cursor.execute("set global general_log_file='C:\mysql.log'")
#conn.commit()
#cursor.close()
#conn.close()
try:
    fp = open("C:/mysql.log","r")
    sql = fp.readlines()
    for item in sql:
        temp = item.replace("\n","").split('\t')
        if re.search("Connect",temp[1]) == None and temp[2] != "":
            print("状态:{} ---> 执行语句:  {}".format(temp[1],temp[2]))
    open("C:/mysql.log","w")
except Exception:
    open("C:/mysql.log", "w")
    exit()
