自然语言处理实战——命名实体识别(二)
HWCloudAI 发表于 2022/12/19 11:48:01 2022/12/19
【摘要】 8.创建模型,开始训练耗时约15分钟model_fn = model_fn_builder( bert_config=bert_config, num_labels=len(label_list) + 1, init_checkpoint=init_checkpoint, learning_rate=learning_rate, ...
8.创建模型,开始训练
耗时约15分钟
        num_train_steps=num_train_steps,
        num_warmup_steps=num_warmup_steps,
        use_one_hot_embeddings=False)
def file_based_input_fn_builder(input_file, seq_length, is_training, drop_remainder):
    name_to_features = {
        "input_ids": tf.FixedLenFeature([seq_length], tf.int64),
        "input_mask": tf.FixedLenFeature([seq_length], tf.int64),
        "segment_ids": tf.FixedLenFeature([seq_length], tf.int64),
        "label_ids": tf.FixedLenFeature([seq_length], tf.int64),
    def _decode_record(record, name_to_features):
        example = tf.parse_single_example(record, name_to_features)
        for name in list(example.keys()):
            t = example[name]
            if t.dtype == tf.int64:
                t = tf.to_int32(t)
            example[name] = t
        return example
    def input_fn(params):
        params["batch_size"] = 32
        batch_size = params["batch_size"]
        d = tf.data.TFRecordDataset(input_file)
        if is_training:
            d = d.repeat()
            d = d.shuffle(buffer_size=300)
        d = d.apply(tf.contrib.data.map_and_batch(
            lambda record: _decode_record(record, name_to_features),
            batch_size=batch_size,
            drop_remainder=drop_remainder
        return d
    return input_fn
#训练输入
train_input_fn = file_based_input_fn_builder(
            input_file=train_file,
            seq_length=max_seq_length,
            is_training=True,
            drop_remainder=True)
num_train_size = len(train_examples)
tf.logging.info("***** Running training *****")
tf.logging.info("  Num examples = %d", num_train_size)
tf.logging.info("  Batch size = %d", batch_size)
tf.logging.info("  Num steps = %d", num_train_steps)
#模型预测estimator
estimator = tf.estimator.Estimator(
        model_fn=model_fn,
        config=run_config,
        params={
        'batch_size':batch_size
estimator.train(input_fn=train_input_fn, max_steps=num_train_steps)
INFO:tensorflow:***** Running training *****
INFO:tensorflow:  Num examples = 20864
INFO:tensorflow:  Batch size = 64
INFO:tensorflow:  Num steps = 1630
INFO:tensorflow:Using config: {'_model_dir': './ner/output', '_tf_random_seed': None, '_save_summary_steps': 1000, '_save_checkpoints_steps': 1000, '_save_checkpoints_secs': None, '_session_config': allow_soft_placement: true
, '_keep_checkpoint_max': 5, '_keep_checkpoint_every_n_hours': 10000, '_log_step_count_steps': 100, '_train_distribute': None, '_device_fn': None, '_protocol': None, '_eval_distribute': None, '_experimental_distribute': None, '_service': None, '_cluster_spec': <tensorflow.python.training.server_lib.ClusterSpec object at 0x7f68463962b0>, '_task_type': 'worker', '_task_id': 0, '_global_id_in_cluster': 0, '_master': '', '_evaluation_master': '', '_is_chief': True, '_num_ps_replicas': 0, '_num_worker_replicas': 1}
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/op_def_library.py:263: colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
Instructions for updating:
Colocations handled automatically by placer.
WARNING:tensorflow:From <ipython-input-8-ff8f40149364>:37: map_and_batch (from tensorflow.contrib.data.python.ops.batching) is deprecated and will be removed in a future version.
Use `tf.data.experimental.map_and_batch(...)`.
WARNING:tensorflow:From <ipython-input-8-ff8f40149364>:23: to_int32 (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Use tf.cast instead.
INFO:tensorflow:Calling model_fn.
INFO:tensorflow:*** Features ***
INFO:tensorflow:  name = input_ids, shape = (32, 128)
INFO:tensorflow:  name = input_mask, shape = (32, 128)
INFO:tensorflow:  name = label_ids, shape = (32, 128)
INFO:tensorflow:  name = segment_ids, shape = (32, 128)
WARNING:tensorflow:From /home/ma-user/work/ma_share/nlp_ner_0/ner/bert/modeling.py:358: calling dropout (from tensorflow.python.ops.nn_ops) with keep_prob is deprecated and will be removed in a future version.
Please use `rate` instead of `keep_prob`. Rate should be set to `rate = 1 - keep_prob`.
WARNING:tensorflow:From /home/ma-user/work/ma_share/nlp_ner_0/ner/bert/modeling.py:671: dense (from tensorflow.python.layers.core) is deprecated and will be removed in a future version.
Use keras.layers.dense instead.
shape of input_ids (32, 128)
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/contrib/crf/python/ops/crf.py:213: dynamic_rnn (from tensorflow.python.ops.rnn) is deprecated and will be removed in a future version.
Please use `keras.layers.RNN(cell)`, which is equivalent to this API
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/training/learning_rate_decay_v2.py:321: div (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
Deprecated in favor of operator or tf.math.divide.
INFO:tensorflow:Done calling model_fn.
INFO:tensorflow:Create CheckpointSaverHook.
INFO:tensorflow:Graph was finalized.
INFO:tensorflow:Running local_init_op.
INFO:tensorflow:Done running local_init_op.
INFO:tensorflow:Saving checkpoints for 0 into ./ner/output/model.ckpt.
INFO:tensorflow:loss = 138.63965, step = 0
INFO:tensorflow:global_steps = 0, loss = 138.63965
INFO:tensorflow:global_step/sec: 2.12094
INFO:tensorflow:loss = 36.574963, step = 100 (47.149 sec)
INFO:tensorflow:global_steps = 100, loss = 36.574963 (47.149 sec)
INFO:tensorflow:global_step/sec: 2.82263
INFO:tensorflow:loss = 30.633581, step = 200 (35.428 sec)
INFO:tensorflow:global_steps = 200, loss = 30.633581 (35.428 sec)
INFO:tensorflow:global_step/sec: 2.8278
INFO:tensorflow:loss = 39.07569, step = 300 (35.366 sec)
INFO:tensorflow:global_steps = 300, loss = 39.07569 (35.366 sec)
INFO:tensorflow:global_step/sec: 2.81413
INFO:tensorflow:loss = 41.826813, step = 400 (35.533 sec)
INFO:tensorflow:global_steps = 400, loss = 41.826813 (35.533 sec)
INFO:tensorflow:global_step/sec: 2.82309
INFO:tensorflow:loss = 35.313362, step = 500 (35.422 sec)
INFO:tensorflow:global_steps = 500, loss = 35.313362 (35.422 sec)
INFO:tensorflow:global_step/sec: 2.82153
INFO:tensorflow:loss = 33.8309, step = 600 (35.442 sec)
INFO:tensorflow:global_steps = 600, loss = 33.8309 (35.442 sec)
INFO:tensorflow:global_step/sec: 2.82503
INFO:tensorflow:loss = 32.518703, step = 700 (35.398 sec)
INFO:tensorflow:global_steps = 700, loss = 32.518703 (35.399 sec)
INFO:tensorflow:global_step/sec: 2.81644
INFO:tensorflow:loss = 35.52353, step = 800 (35.505 sec)
INFO:tensorflow:global_steps = 800, loss = 35.52353 (35.505 sec)
INFO:tensorflow:global_step/sec: 2.82622
INFO:tensorflow:loss = 37.82669, step = 900 (35.383 sec)
INFO:tensorflow:global_steps = 900, loss = 37.82669 (35.383 sec)
INFO:tensorflow:Saving checkpoints for 1000 into ./ner/output/model.ckpt.
INFO:tensorflow:global_step/sec: 2.20189
INFO:tensorflow:loss = 30.113663, step = 1000 (45.416 sec)
INFO:tensorflow:global_steps = 1000, loss = 30.113663 (45.415 sec)
INFO:tensorflow:global_step/sec: 2.82651
INFO:tensorflow:loss = 35.227222, step = 1100 (35.381 sec)
INFO:tensorflow:global_steps = 1100, loss = 35.227222 (35.381 sec)
INFO:tensorflow:global_step/sec: 2.82383
INFO:tensorflow:loss = 32.62957, step = 1200 (35.411 sec)
INFO:tensorflow:global_steps = 1200, loss = 32.62957 (35.411 sec)
INFO:tensorflow:global_step/sec: 2.82625
INFO:tensorflow:loss = 33.095165, step = 1300 (35.383 sec)
INFO:tensorflow:global_steps = 1300, loss = 33.095165 (35.383 sec)
INFO:tensorflow:global_step/sec: 2.82021
INFO:tensorflow:loss = 31.56667, step = 1400 (35.458 sec)
INFO:tensorflow:global_steps = 1400, loss = 31.56667 (35.458 sec)
INFO:tensorflow:global_step/sec: 2.82301
INFO:tensorflow:loss = 30.289349, step = 1500 (35.425 sec)
INFO:tensorflow:global_steps = 1500, loss = 30.289349 (35.425 sec)
INFO:tensorflow:global_step/sec: 2.82841
INFO:tensorflow:loss = 32.09925, step = 1600 (35.354 sec)
INFO:tensorflow:global_steps = 1600, loss = 32.09925 (35.354 sec)
INFO:tensorflow:Saving checkpoints for 1630 into ./ner/output/model.ckpt.
INFO:tensorflow:Loss for final step: 34.578945.
<tensorflow_estimator.python.estimator.estimator.Estimator at 0x7f684fdad6d8>
9.在验证集上验证模型
eval_examples = processor.get_dev_examples(data_dir)
eval_file = os.path.join(output_dir, "eval.tf_record")
filed_based_convert_examples_to_features(
                eval_examples, label_list, max_seq_length, tokenizer, eval_file)
data_config['eval.tf_record_path'] = eval_file
data_config['num_eval_size'] = len(eval_examples)
num_eval_size = data_config.get('num_eval_size', 0)
tf.logging.info("***** Running evaluation *****")
tf.logging.info("  Num examples = %d", num_eval_size)
eval_steps = None
eval_drop_remainder = False
eval_input_fn = file_based_input_fn_builder(
            input_file=eval_file,
            is_training=False,
            drop_remainder=eval_drop_remainder)
result = estimator.evaluate(input_fn=eval_input_fn, steps=eval_steps)
output_eval_file = os.path.join(output_dir, "eval_results.txt")
with codecs.open(output_eval_file, "w", encoding='utf-8') as writer:
    tf.logging.info("***** Eval results *****")
    for key in sorted(result.keys()):
        tf.logging.info("  %s = %s", key, str(result[key]))
        writer.write("%s = %s\n" % (key, str(result[key])))
if not os.path.exists(data_config_path):
    with codecs.open(data_config_path, 'a', encoding='utf-8') as fd:
        json.dump(data_config, fd)
INFO:tensorflow:Writing example 0 of 4631
INFO:tensorflow:***** Running evaluation *****
INFO:tensorflow:  Num examples = 4631
INFO:tensorflow:  name = input_ids, shape = (?, 128)
INFO:tensorflow:  name = input_mask, shape = (?, 128)
INFO:tensorflow:  name = label_ids, shape = (?, 128)
INFO:tensorflow:  name = segment_ids, shape = (?, 128)
shape of input_ids (?, 128)
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/ops/metrics_impl.py:363: to_float (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
INFO:tensorflow:Starting evaluation at 2021-03-11T07:52:30Z
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/training/saver.py:1266: checkpoint_exists (from tensorflow.python.training.checkpoint_management) is deprecated and will be removed in a future version.
Use standard file APIs to check for files with this prefix.
INFO:tensorflow:Restoring parameters from ./ner/output/model.ckpt-1630
INFO:tensorflow:Finished evaluation at 2021-03-11-07:52:57
INFO:tensorflow:Saving dict for global step 1630: eval_loss = 0.040791675, global_step = 1630, loss = 27.17968
INFO:tensorflow:Saving 'checkpoint_path' summary for global step 1630: ./ner/output/model.ckpt-1630
INFO:tensorflow:***** Eval results *****
INFO:tensorflow:  eval_loss = 0.040791675
INFO:tensorflow:  global_step = 1630
INFO:tensorflow:  loss = 27.17968
10.在测试集上进行测试
token_path = os.path.join(output_dir, "token_test.txt")
if os.path.exists(token_path):
    os.remove(token_path)
with codecs.open(os.path.join(output_dir, 'label2id.pkl'), 'rb') as rf:
    label2id = pickle.load(rf)
    id2label = {value: key for key, value in label2id.items()}
predict_examples = processor.get_test_examples(data_dir)
predict_file = os.path.join(output_dir, "predict.tf_record")
filed_based_convert_examples_to_features(predict_examples, label_list,
                                                 predict_file, mode="test")
tf.logging.info("***** Running prediction*****")
tf.logging.info("  Num examples = %d", len(predict_examples))
predict_drop_remainder = False
predict_input_fn = file_based_input_fn_builder(
            input_file=predict_file,
            is_training=False,
            drop_remainder=predict_drop_remainder)
predicted_result = estimator.evaluate(input_fn=predict_input_fn)
output_eval_file = os.path.join(output_dir, "predicted_results.txt")
    tf.logging.info("***** Predict results *****")
    for key in sorted(predicted_result.keys()):
        tf.logging.info("  %s = %s", key, str(predicted_result[key]))
        writer.write("%s = %s\n" % (key, str(predicted_result[key])))
result = estimator.predict(input_fn=predict_input_fn)
output_predict_file = os.path.join(output_dir, "label_test.txt")
def result_to_pair(writer):
    for predict_line, prediction in zip(predict_examples, result):
        idx = 0
        line = ''
        line_token = str(predict_line.text).split(' ')
        label_token = str(predict_line.label).split(' ')
        if len(line_token) != len(label_token):
            tf.logging.info(predict_line.text)
            tf.logging.info(predict_line.label)
        for id in prediction:
            if id == 0:
                continue
            curr_labels = id2label[id]
            if curr_labels in ['[CLS]', '[SEP]']:
                continue
            try:
                line += line_token[idx] + ' ' + label_token[idx] + ' ' + curr_labels + '\n'
            except Exception as e:
                tf.logging.info(e)
                line = ''
                break
            idx += 1
        writer.write(line + '\n')
from ner.src.conlleval import return_report
with codecs.open(output_predict_file, 'w', encoding='utf-8') as writer:
eval_result = return_report(output_predict_file)
for line in eval_result:
    print(line)
INFO:tensorflow:Writing example 0 of 68
INFO:tensorflow:***** Running prediction*****
INFO:tensorflow:  Num examples = 68
INFO:tensorflow:Starting evaluation at 2021-03-11T07:53:01Z
INFO:tensorflow:Finished evaluation at 2021-03-11-07:53:04
INFO:tensorflow:Saving dict for global step 1630: eval_loss = 0.007008272, global_step = 1630, loss = 25.96924
INFO:tensorflow:***** Predict results *****
INFO:tensorflow:  eval_loss = 0.007008272
INFO:tensorflow:  loss = 25.96924
processed 2270 tokens with 78 phrases; found: 76 phrases; correct: 67.
accuracy:  99.47%; precision:  88.16%; recall:  85.90%; FB1:  87.01
              LOC: precision: 100.00%; recall: 100.00%; FB1: 100.00  45
              ORG: precision:  77.78%; recall:  87.50%; FB1:  82.35  9
              PER: precision:  68.18%; recall:  60.00%; FB1:  63.83  22
11.命名实体识别效果测试 —— 交互式测试方式
接下来我们将使用BERT模型测试一些具体的句子,看看命名实体识别的效果怎样。我们采用交互式的方式来测试,交互式是指你输入一个句子,模型就预测一个句子,可以不断输入,不断预测,直到你退出测试。
测试步骤如下所示:
  1. 找到本页面顶部的菜单栏,点击 Kernel -> Restart;
  2. 执行下面的 “%run ner/src/terminal_predict.py” 命令;
  3. 手动输入一个句子,按回车进行预测;
  4. 如果想结束测试,则输入“再见”。
/home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:526: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint8 = np.dtype([("qint8", np.int8, 1)])
/home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:527: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint8 = np.dtype([("quint8", np.uint8, 1)])
/home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:528: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint16 = np.dtype([("qint16", np.int16, 1)])
/home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:529: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_quint16 = np.dtype([("quint16", np.uint16, 1)])
/home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:530: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  _np_qint32 = np.dtype([("qint32", np.int32, 1)])
/home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/framework/dtypes.py:535: FutureWarning: Passing (type, 1) or '1type' as a synonym of type is deprecated; in a future version of numpy, it will be understood as (type, (1,)) / '(1,)type'.
  np_resource = np.dtype([("resource", np.ubyte, 1)])
checkpoint path:./ner/output/checkpoint
going to restore checkpoint
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/contrib/crf/python/ops/crf.py:567: dynamic_rnn (from tensorflow.python.ops.rnn) is deprecated and will be removed in a future version.
WARNING:tensorflow:From /home/ma-user/anaconda3/envs/TensorFlow-1.13.1/lib/python3.6/site-packages/tensorflow/python/ops/rnn.py:626: to_int32 (from tensorflow.python.ops.math_ops) is deprecated and will be removed in a future version.
{1: 'O', 2: 'B-PER', 3: 'I-PER', 4: 'B-ORG', 5: 'I-ORG', 6: 'B-LOC', 7: 'I-LOC', 8: 'X', 9: '[CLS]', 10: '[SEP]'}
输入句子:
 今天(3月11日)下午,第十三届全国人大四次会议闭幕后,国务院总理李克强将在人民大会堂三楼金色大厅出席记者会并回答中外记者提问。
[['O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'B-ORG', 'I-ORG', 'I-ORG', 'I-ORG', 'I-ORG', 'I-ORG', 'I-ORG', 'I-ORG', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'B-ORG', 'I-ORG', 'I-ORG', 'O', 'O', 'B-PER', 'I-PER', 'I-PER', 'O', 'O', 'B-LOC', 'I-LOC', 'I-LOC', 'I-LOC', 'I-LOC', 'O', 'I-LOC', 'B-LOC', 'I-LOC', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'O', 'B-LOC', 'O', 'O', 'O', 'O', 'O', 'O']]
LOC, 人民大会堂, 楼, 金色, 中
PER, 李克强
ORG, 第十三届全国人大, 国务院
time used: 0.831476 sec
输入句子:
 再见
再见
本案例到此结束
