springmvc中报错Request processing failed;
穆雄雄 发表于 2022/12/16 20:45:31 2022/12/16
【摘要】 今天在整个ssm的时候出现了个低级错误,找了好久才找出来,在发现真理的那一刻,我都有死的冲动了。报错如下:HTTP Status 500 - Request processing failed; nested exception is java.lang.IllegalStateException: Optional int parameter ‘eid’ is present but ca...
报错如下:
HTTP Status 500 - Request processing failed; nested exception is java.lang.IllegalStateException: Optional int parameter ‘eid’ is present but cannot be translated into a null value due to being declared as a primitive type. Consider declaring it as object wrapper for the corresponding primitive type.
type Exception report
message Request processing failed; nested exception is java.lang.IllegalStateException: Optional int parameter ‘eid’ is present but cannot be translated into a null value due to being declared as a primitive type. Consider declaring it as object wrapper for the corresponding primitive type.
description The server encountered an internal error that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.IllegalStateException: Optional int parameter ‘eid’ is present but cannot be translated into a null value due to being declared as a primitive type. Consider declaring it as object wrapper for the corresponding primitive type.
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:965)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:844)
javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:829)
javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:88)
org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:106)
root cause
org.springframework.web.method.annotation.AbstractNamedValueMethodArgumentResolver.handleNullValue(AbstractNamedValueMethodArgumentResolver.java:188)
org.springframework.web.method.annotation.AbstractNamedValueMethodArgumentResolver.resolveArgument(AbstractNamedValueMethodArgumentResolver.java:94)
org.springframework.web.method.support.HandlerMethodArgumentResolverComposite.resolveArgument(HandlerMethodArgumentResolverComposite.java:77)
org.springframework.web.method.support.InvocableHandlerMethod.getMethodArgumentValues(InvocableHandlerMethod.java:157)
org.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:124)
org.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:104)
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandleMethod(RequestMappingHandlerAdapter.java:745)
org.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:685)
org.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:80)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:919)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:851)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:953)
note The full stack trace of the root cause is available in the Apache Tomcat/7.0.70 logs.
截图如下所示:
错误截图
解决方法:
删除
这一行代码中的eid后面有个空格,删除掉了就可以了!!
评论(0
