大数据必学Java基础(九十四):SQL注入攻击
Lansonli 发表于 2022/12/15 15:45:28 2022/12/15
【摘要】 SQL注入攻击一、Sql注入说明SQL注入攻击指的是通过构建特殊的输入作为参数传入Web应用程序,而这些输入大都是SQL语法里的一些组合,通过执行SQL语句进而执行攻击者所要的操作,其主要原因是程序没有细致地过滤用户输入的数据,致使非法数据侵入系统。二、具体实现以模拟登录为例:在前台输入用户名和密码,后台判断信息是否正确,并给出前台反馈信息,前台输出反馈信息。1、创建数据库表2、创建实体类p...
SQL注入攻击
一、Sql注入说明
二、具体实现
1、创建数据库表
2、创建实体类
public class Account implements Serializable {
    private int aid;
    private String username;
    private String password;
    private int money;
3、测试代码
package com.lanson.test2;
import com.lanson.entity.Account;
import com.lanson.entity.Emp;
import java.sql.*;
import java.util.ArrayList;
import java.util.List;
import java.util.Scanner;
 * @Author: Lansonli
 * @Description: MircoMessage:Mark_7001
public class TestInjection {
    private static String driver ="com.mysql.cj.jdbc.Driver";
    private static String url="jdbc:mysql://127.0.0.1:3306/mydb?useSSL=false&useUnicode=true&characterEncoding=UTF-8&serverTimezone=Asia/Shanghai&allowPublicKeyRetrieval=true";
    private static String user="root";
    private static String password="root";
        Scanner sc =new Scanner(System.in);
        System.out.println("请输入用户名");
        String username=sc.next();
        System.out.println("请输入密码");
        String pwd =sc.next();
        Account account = getAccount(username, pwd);
        System.out.println(null!= account?"登录成功":"登录失败");
        sc.close();
    public static Account getAccount(String username,String pwd){
        Connection connection = null;
        Statement statement=null;
        ResultSet resultSet=null;
        Account account =null;
        try{
            Class.forName(driver);
            connection = DriverManager.getConnection(url, user,password);
            statement = connection.createStatement();
            String sql="select * from account where username ='"+username+"' and password ='"+pwd+"'";
            System.out.println(sql);
            resultSet = statement.executeQuery(sql);
            while(resultSet.next()){
                int aid = resultSet.getInt("aid");
                String usernamea = resultSet.getString("username");
                String pwda = resultSet.getString("password");
                double money = resultSet.getDouble("money");
                account=new Account(aid,usernamea,pwda,money);
                System.out.println(account);
        }catch (Exception e){
            e.printStackTrace();
        }finally {
            if(null != resultSet){
                try {
                    resultSet.close();
                } catch (SQLException e) {e.printStackTrace();
            if(null != statement){
                try {
                    statement.close();
            if(null != connection){
                try {
                    connection.close();
        return account;
4、测试结果
三、总结
当输入了精心设计的用户名密码后,即使是错误的,也能登录成功,让登录功能形同虚设。这就是SQL注入风险,原因在于SQL语句是字符串拼接的,SQL语句中拼接的内容破坏了SQL语句原有的判断逻辑。如何解决呢?使用PreparedStatement预编译语句对象就可以解决掉。
