大数据必学Java基础(九十三):JDBC完成CURD
Lansonli 发表于 2022/12/15 15:44:23 2022/12/15
【摘要】 ​JDBC完成CURD一、删除和修改部门信息package com.lanson.test1;import java.sql.Connection;import java.sql.DriverManager;import java.sql.SQLException;import java.sql.Statement;/** * @Author: Lansonli * @Description...
​JDBC完成CURD
一、删除和修改部门信息
 * @Author: Lansonli
 * @Description: MircoMessage:Mark_7001
public class TestJDBC4 {
    private static String driver ="com.mysql.cj.jdbc.Driver";
    private static String url="jdbc:mysql://127.0.0.1:3306/mydb?useSSL=false&useUnicode=true&characterEncoding=UTF-8&serverTimezone=Asia/Shanghai&allowPublicKeyRetrieval=true";
    private static String user="root";
    private static String password="root";
    public static void main(String[] args)  {
        //testDelete();
        testUpdate();
    public static void testUpdate(){
        Connection connection=null;
        Statement statement=null;
        try{
            Class.forName(driver);
            connection =DriverManager.getConnection(url, user,password);
            statement = connection.createStatement();
            String sql="update dept set dname='总部',loc='北京' where deptno= 30 ";
            int rows = statement.executeUpdate(sql);
            System.out.println("影响数据行数为:"+rows);
        }catch (Exception e){
            e.printStackTrace();
        }finally {
            if(null != statement){
                try {
                    statement.close();
                } catch (SQLException e) {
            if(null != connection){
                try {
                    connection.close();
    public static void testDelete(){
        try{
            String sql="delete from dept where deptno =40";
        }finally {
                try {
                    statement.close();
                try {
                    connection.close();
二、查询全部员工信息
import java.sql.*;
 * @Author: Lansonli
public class TestJDBC5 {
        testQuery();
    public static void testQuery(){
        Connection connection = null;
        ResultSet resultSet=null;
        try{
            connection = DriverManager.getConnection(url, user,password);
            String sql="select * from emp";
            resultSet = statement.executeQuery(sql);
            while(resultSet.next()){
                int empno = resultSet.getInt("empno");
                String ename = resultSet.getString("ename");
                String job = resultSet.getString("job");
                int mgr = resultSet.getInt("mgr");
                Date hiredate = resultSet.getDate("hiredate");
                double sal= resultSet.getDouble("sal");
                double comm= resultSet.getDouble("comm");
                int deptno= resultSet.getInt("deptno");
                System.out.println(""+empno+" "+ename+" "+job+" "+mgr+" "+hiredate+" "+sal+" "+comm+" "+deptno);
        }finally {
            if(null != resultSet){
                try {
                    resultSet.close();
                } catch (SQLException e) {e.printStackTrace();
                try {
                    statement.close();
                try {
                    connection.close();
三、知识补充
  • ResultSet里的数据一行一行排列,每行有多个字段,且有一个记录指针,指针所指的数据行叫做当前数据行,我们只能来操作当前的数据行。我们如果想要取得某一条记录,就要使用ResultSet的next()方法 ,如果我们想要得到ResultSet里的所有记录,就应该使用while循环。
  • ResultSet对象自动维护指向当前数据行的游标。每调用一次next()方法,游标向下移动一行。
  • 初始状态下记录指针指向第一条记录的前面,通过next()方法指向第一条记录。循环完毕后指向最后一条记录的后面。
方法名
说 明
boolean next()
将光标从当前位置向下移动一行
boolean previous()
游标从当前位置向上移动一行
void close()
关闭ResultSet 对象
int getInt(int colIndex)
以int形式获取结果集当前行指定列号值
int getInt(String colLabel)
以int形式获取结果集当前行指定列名值
float getFloat(int colIndex)
以float形式获取结果集当前行指定列号值
Float getFloat(String colLabel)
以float形式获取结果集当前行指定列名值
String getString(int colIndex)
以String 形式获取结果集当前行指定列号值
StringgetString(String colLabel)
以String形式获取结果集当前行指定列名值
作为一种好的编程风格,应在不需要Statement对象和Connection对象时显式地关闭它们。关闭Statement对象和Connection对象的语法形式为:用户不必关闭ResultSet。当它的 Statement 关闭、重新执行或用于从多结果序列中获取下一个结果时,该ResultSet将被自动关闭。
四、为什么将结果封装成对象或者对象集合
  1. java是面向对象的编程语言,java中所有的数据处理都是基于面向对象的编码风格实现的,让数据以符合java风格的形式存在,便于对数据的后续处理
  2. ResultSet 集合虽然可以存放数据,但是它是JDBC中查询数据的一种手段,是一种数据的临时存储方案,使用完毕是要进行释放和关闭
五、封装后台查询数据并在前台显示
如何将结果集中的数据在java中进行存储和传递?
准备和数据库表格相对应的一个实体类,用于封装结果集中的每一条数据,数据库表格中的每一个字段就是实体类的一个属性,实体类的一个对象就可以用于存储数据库表中的一条记录
准备实体类
package com.lanson.entity;
import java.io.Serializable;
import java.util.Date;
 * @Author: Lansonli
* 实体类:
* 和数据库表格名称和字段是一一对应的类
* 该类的对象主要用处是存储从数据库中查询出来的数据
* 除此之外,该类没有任何的其他功能
* 要求
* 1类名和表名保持一致  (见名知意)
* 2属性个数和数据库的表的列数保持一致
* 3属性的数据类型和列的数据类型保持一致
* 4属性名和数据库表格的列名要保持一致
* 5所有的属性必须都是私有的 (出于安全考虑)
* 6实体类的属性推荐写成包装类
* 7日期类型推荐写成java.util.Date
* 8所有的属性都要有get和set方法
* 9必须具备空参构造方法
* 10实体类应当实现序列化接口 (mybatis缓存  分布式需要 )
* 11实体类中其他构造方法可选
public class Emp implements Serializable {
    private Integer empno;
    private String ename;
    private String job;
    private Integer mgr;
    private Date hiredate;
    private Double sal;
    private Double comm;
    private Integer deptno;
    @Override
    public String toString() {
        return "Emp{" +
                "empno=" + empno +
                ", ename='" + ename + '\'' +
                ", job='" + job + '\'' +
                ", mgr=" + mgr +
                ", hiredate=" + hiredate +
                ", sal=" + sal +
                ", comm=" + comm +
                ", deptno=" + deptno +
    public Emp(Integer empno, String ename, String job, Integer mgr, Date hiredate, Double sal, Double comm, Integer deptno) {
        this.empno = empno;
        this.ename = ename;
        this.job = job;
        this.mgr = mgr;
        this.hiredate = hiredate;
        this.sal = sal;
        this.comm = comm;
        this.deptno = deptno;
    public Emp(){
    public Integer getEmpno() {
        return empno;
    public void setEmpno(Integer empno) {
        this.empno = empno;
    public String getEname() {
        return ename;
    public void setEname(String ename) {
        this.ename = ename;
    public String getJob() {
        return job;
    public void setJob(String job) {
        this.job = job;
    public Integer getMgr() {
        return mgr;
    public void setMgr(Integer mgr) {
        this.mgr = mgr;
    public Date getHiredate() {
        return hiredate;
    public void setHiredate(Date hiredate) {
    public Double getSal() {
        return sal;
    public void setSal(Double sal) {
        this.sal = sal;
    public Double getComm() {
        return comm;
    public void setComm(Double comm) {
        this.comm = comm;
    public Integer getDeptno() {
        return deptno;
    public void setDeptno(Integer deptno) {
使用实体类封装结果集
import com.lanson.entity.Emp;
import java.sql.*;
import java.util.ArrayList;
import java.util.List;
 * @Author: Lansonli
        List<Emp> emps = testQuery();
        // 遍历集合
        for (Emp emp : emps) {
            System.out.println(emp);
    public  static List<Emp>  testQuery(){
        List<Emp> list =null;
        try{
            list=new ArrayList<>();
                Emp emp =new Emp(empno, ename, job, mgr, hiredate, sal, comm, deptno);
                list.add(emp);
        }finally {
                try {
                    resultSet.close();
                try {
                    statement.close();
                try {
                    connection.close();
        return list;
