mybatis中,collection配置后查询只显示一条记录
穆雄雄 发表于 2022/12/13 22:02:12 2022/12/13
【摘要】 描述一下问题:已知有两个表,一个是user表,一个是address,一(user)对多(address)的关系,在user的实体类里面写属性:private List<Address> addressList = new ArrayList<Address>(); public List<Address> getAddressList() { return addressList; } ...
描述一下问题:
		return addressList;
	public void setAddressList(List<Address> addressList) {
		this.addressList = addressList;
然后写了一个测试方法,根据用户的编号查询地址信息,一个用户对应多个地址。
配置如下:
<resultMap type="User" id="userAddMap">
	<id property="id" column="id"/>
		<result property="userName" column="userName"/>
		<result property="userCode" column="userCode"/>
		<result property="userPassword" column="userPassword"/>
		<result property="gender" column="gender"/>
		<result property="birthday" column="birthday"/>
		<result property="phone" column="phone"/>
		<result property="address" column="address"/>
		<result property="userRole" column="userRole"/>
		<result property="createdBy" column="createdBy"/>
		<result property="creationDate" column="creationDate"/>
		<result property="modifyBy" column="modifyBy"/>
		<result property="modifyDate" column="modifyDate"/>
		<result property="roleName" column="roleName"/>
		<collection property="addressList" ofType="Address">
			<id property="aid" column="id"/>
			<result property="contact" column="contact"/>
			<result property="addressDesc" column="addressDesc"/>
			<result property="postCode" column="postCode"/>
			<result property="tel" column="tel"/>
			<result property="userId" column="userId"/>
		</collection>
	</resultMap>
sql映射如下:
<select id="findUserByidAndAddress" parameterType="Integer" resultMap="userAddMap">
SELECT u.*,a.id,a.contact,a.addressdesc,a.postCode
		FROM smbms_user u,smbms_address a
		WHERE u.id = a.userid AND  u.id = #{id}
  </select>
看起来没有任何问题吧,写了个测试方法:
@Test
	public void findUserByidAndAddress(){
		SqlSession sqlSession = utils.getSqlSession();
		User user = sqlSession.getMapper(IUserDao.class).findUserByidAndAddress(1);
		List<Address> addressList = user.getAddressList();
		for (Address address : addressList) {
			System.out.println(address.getAddressDesc());
运行结果如图所示:
可是数据库中却有三条记录:
经过自己琢磨,不行。
然后上网查了下,原来是数据库中两个表中的主键都是id,如果配置collection一对多关联的话需要改别名,我就试着改了下,发现,可以了。
改过之后的映射文件如下:
			<id property="aid" column="aid"/>
		</collection>
	</resultMap>
sql语句如下:
SELECT u.*,a.id as aid,a.contact,a.addressdesc,a.postCode
  </select>
注意:resultMap中的property对应的是实体类里面的属性,而column严格意义上来说对应的是结果集里面的列名,而不是数据库中的列,比如起别名的话就对应的是别名,不是原来的列,切记切记!!!
欢迎关注:雄雄的小课堂
