云原生之使用Docker部署webssh工具sshwifty
江湖有缘 发表于 2022/12/11 19:46:39 2022/12/11
【摘要】 云原生之使用Docker部署webssh工具sshwifty
一、sshwifty介绍
1.sshwifty简介
sshwifty是一款Web SSH & Telnet(WebSSH & WebTelnet 客户端工具。
2.shwifty 特点
shwifty 是为 Web 设计的 SSH 和 Telnet 连接器。它可以部署在您的计算机或服务器上,为任何兼容(标准)的网络浏览器提供 SSH 和 Telnet 访问接口。
二、检查本地docker环境
1.检查docker版本
[root@jeven ~]# docker version
Client: Docker Engine - Community
 Version:           20.10.21
 API version:       1.41
 Go version:        go1.18.7
 Git commit:        baeda1f
 Built:             Tue Oct 25 18:04:24 2022
 OS/Arch:           linux/amd64
 Context:           default
 Experimental:      true
Server: Docker Engine - Community
 Engine:
  Version:          20.10.21
  API version:      1.41 (minimum version 1.12)
  Git commit:       3056208
  Built:            Tue Oct 25 18:02:38 2022
  Experimental:     false
 containerd:
  Version:          1.6.12
  GitCommit:        a05d175400b1145e5e6a735a6710579d181e7fb0
 runc:
  Version:          1.1.4
  GitCommit:        v1.1.4-0-g5fd4c4d
 docker-init:
  Version:          0.19.0
  GitCommit:        de40ad0
2.检查docker状态
[root@jeven ~]# systemctl status docker
● docker.service - Docker Application Container Engine
   Loaded: loaded (/usr/lib/systemd/system/docker.service; enabled; vendor preset: disabled)
   Active: active (running) since Sat 2022-12-10 02:07:56 CST; 1 day 16h ago
     Docs: https://docs.docker.com
 Main PID: 3200 (dockerd)
    Tasks: 51
   Memory: 2.2G
   CGroup: /system.slice/docker.service
           ├─ 3200 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
           ├─10894 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8777 -container-ip 192.168.144.3 -container-port 80
           ├─10900 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 8777 -container-ip 192.168.144.3 -container-port 80
           ├─47983 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8030 -container-ip 192.168.160.4 -container-port 8002
           ├─47989 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 8030 -container-ip 192.168.160.4 -container-port 8002
           ├─79289 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8182 -container-ip 172.17.0.2 -container-port 8182
           └─79295 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 8182 -container-ip 172.17.0.2 -container-port 8182
Dec 10 17:59:26 jeven dockerd[3200]: time="2022-12-10T17:59:26.025354968+08:00" level=info msg="ignoring event" container=f12196399ec79af5...skDelete"
Dec 10 17:59:29 jeven dockerd[3200]: time="2022-12-10T17:59:29.686116328+08:00" level=info msg="ignoring event" container=f12196399ec79af5...skDelete"
Dec 10 18:23:34 jeven dockerd[3200]: time="2022-12-10T18:23:34.990641014+08:00" level=info msg="ignoring event" container=c663d02e84709140...skDelete"
Dec 10 18:26:49 jeven dockerd[3200]: time="2022-12-10T18:26:49.278375069+08:00" level=info msg="ignoring event" container=c261a231fd3a667e...skDelete"
Dec 10 18:30:06 jeven dockerd[3200]: time="2022-12-10T18:30:06.474584540+08:00" level=info msg="ignoring event" container=c030677ef4c374ce...skDelete"
Dec 10 18:56:18 jeven dockerd[3200]: time="2022-12-10T18:56:18.697839686+08:00" level=info msg="ignoring event" container=1dee36827375e093...skDelete"
Dec 10 21:38:37 jeven dockerd[3200]: time="2022-12-10T21:38:37.225136574+08:00" level=info msg="ignoring event" container=9eb379c6b627f271...skDelete"
Dec 11 11:25:12 jeven dockerd[3200]: time="2022-12-11T11:25:12.020544314+08:00" level=info msg="Attempting next endpoint for pull after er...er Error"
Dec 11 11:39:16 jeven dockerd[3200]: time="2022-12-11T11:39:16.374445047+08:00" level=info msg="Container failed to exit within 10s of sig...ee64e0fee
Dec 11 11:39:16 jeven dockerd[3200]: time="2022-12-11T11:39:16.417759049+08:00" level=info msg="ignoring event" container=a8ec136f38e4cfa8...skDelete"
Hint: Some lines were ellipsized, use -l to show in full.
三、下载sshwifty镜像
[root@jeven ~]# docker pull  niruix/sshwifty:latest
latest: Pulling from niruix/sshwifty
59bf1c3509f3: Already exists
eb8f919181be: Pull complete
21facffd2b84: Pull complete
ea1365dbf4a0: Pull complete
213ec9aee27d: Already exists
db074b00f828: Pull complete
af1b674602a2: Pull complete
5f786aa6e56f: Pull complete
Digest: sha256:410a48bbce146d01ca7e5f20ff67e55dfdab5afbe46ae41ad696d659c6856670
Status: Downloaded newer image for niruix/sshwifty:latest
docker.io/niruix/sshwifty:latest
四、服务器生成凭证文件
[root@jeven ~]# openssl req   -newkey rsa:4096 -nodes -keyout domain.key -x509 -days 90 -out domain.crt
Generating a 4096 bit RSA private key
writing new private key to 'domain.key'
You are about to be asked to enter information that will be incorporated
into your certificate request.
What you are about to enter is what is called a Distinguished Name or a DN.
There are quite a few fields but you can leave some blank
For some fields there will be a default value,
If you enter '.', the field will be left blank.
Country Name (2 letter code) [XX]:
State or Province Name (full name) []:
Locality Name (eg, city) [Default City]:
Organization Name (eg, company) [Default Company Ltd]:
Organizational Unit Name (eg, section) []:
Common Name (eg, your name or your server's hostname) []:
Email Address []:
五、创建sshwifty容器
1.创建部署目录
mkdir -p  /data/sshwifty
2.创建sshwifty容器
docker run --detach \
  --restart always \
  --publish 8182:8182 \
  --env SSHWIFTY_DOCKER_TLSCERT="$(cat domain.crt)" \
  --env SSHWIFTY_DOCKER_TLSCERTKEY="$(cat domain.key)" \
  --name sshwifty \
3.查看sshwifty容器状态
[root@jeven ~]# docker ps
CONTAINER ID   IMAGE                    COMMAND                  CREATED        STATUS        PORTS                                       NAMES
d03202a5cce7   niruix/sshwifty:latest   "/sshwifty.sh"           8 hours ago    Up 8 hours    0.0.0.0:8182->8182/tcp, :::8182->8182/tcp   sshwifty
六、访问sshwifty首页
七、sshwifty的基本使用
1.进入连接选项界面
2.选择ssh连接
填写服务器IP地址等信息,选择认证方式
3.认证信息配置
4.远程ssh连接服务器
5.查看连接延迟状态
