pycharm2022最新安装与激活(亲测有效)
沙师弟 发表于 2022/12/09 22:13:28 2022/12/09
【摘要】 pyacharm安装与激活:https://cloud.fynote.com/share/d/pIOqoASW
遇到问题可关注UP主私信,回复不一定实时还请见谅!如果觉得有帮助请回B站关注点赞,谢谢!
b站视频不能发布完全,详细安装与激活步骤视频地址:
https://cloud.tencent.com/developer/video/33962
如果失效:
视频文件链接:https://pan.baidu.com/s/1HeiKQhU1N5n0OLiZUVGPSg?pwd=vuat
提取码:vuat
–来自百度网盘超级会员V7的分享
获取激活文件
激活码
EUWT4EE9X2-eyJsaWNlbnNlSWQiOiJFVVdUNEVFOVgyIiwibGljZW5zZWVOYW1lIjoic2lnbnVwIHNjb290ZXIiLCJhc3NpZ25lZU5hbWUiOiIiLCJhc3NpZ25lZUVtYWlsIjoiIiwibGljZW5zZVJlc3RyaWN0aW9uIjoiIiwiY2hlY2tDb25jdXJyZW50VXNlIjpmYWxzZSwicHJvZHVjdHMiOlt7ImNvZGUiOiJQU0kiLCJmYWxsYmFja0RhdGUiOiIyMDI1LTA4LTAxIiwicGFpZFVwVG8iOiIyMDI1LTA4LTAxIiwiZXh0ZW5kZWQiOnRydWV9LHsiY29kZSI6IlBDIiwiZmFsbGJhY2tEYXRlIjoiMjAyNS0wOC0wMSIsInBhaWRVcFRvIjoiMjAyNS0wOC0wMSIsImV4dGVuZGVkIjpmYWxzZX0seyJjb2RlIjoiUFBDIiwiZmFsbGJhY2tEYXRlIjoiMjAyNS0wOC0wMSIsInBhaWRVcFRvIjoiMjAyNS0wOC0wMSIsImV4dGVuZGVkIjp0cnVlfSx7ImNvZGUiOiJQV1MiLCJmYWxsYmFja0RhdGUiOiIyMDI1LTA4LTAxIiwicGFpZFVwVG8iOiIyMDI1LTA4LTAxIiwiZXh0ZW5kZWQiOnRydWV9LHsiY29kZSI6IlBDV01QIiwiZmFsbGJhY2tEYXRlIjoiMjAyNS0wOC0wMSIsInBhaWRVcFRvIjoiMjAyNS0wOC0wMSIsImV4dGVuZGVkIjp0cnVlfV0sIm1ldGFkYXRhIjoiMDEyMDIyMDkwMlBTQU4wMDAwMDUiLCJoYXNoIjoiVFJJQUw6MzUzOTQ0NTE3IiwiZ3JhY2VQZXJpb2REYXlzIjo3LCJhdXRvUHJvbG9uZ2F0ZWQiOmZhbHNlLCJpc0F1dG9Qcm9sb25nYXRlZCI6ZmFsc2V9-FT9l1nyyF9EyNmlelrLP9rGtugZ6sEs3CkYIKqGgSi608LIamge623nLLjI8f6O4EdbCfjJcPXLxklUe1O/5ASO3JnbPFUBYUEebCWZPgPfIdjw7hfA1PsGUdw1SBvh4BEWCMVVJWVtc9ktE+gQ8ldugYjXs0s34xaWjjfolJn2V4f4lnnCv0pikF7Ig/Bsyd/8bsySBJ54Uy9dkEsBUFJzqYSfR7Z/xsrACGFgq96ZsifnAnnOvfGbRX8Q8IIu0zDbNh7smxOwrz2odmL72UaU51A5YaOcPSXRM9uyqCnSp/ENLzkQa/B9RNO+VA7kCsj3MlJWJp5Sotn5spyV+gA==-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
第一步:下载 Pycharm 安装包
访问 Pycharm 官网,下载 Pycharm 2022.2.4 版本的安装包,下载链接如下 :
https://www.jetbrains.com/pycharm/download
下载 Pycharm 2022.2.4 安装包
打开页面后,点击 Download 按钮, 等待 Pycharm 专业版下载完毕。
第二步:安装 Pycharm 2022.2.4 版本
如果电脑之前有安装老版本 Pycharm, 需要先卸载。卸载完成后,双击刚刚下载好的 Pycharm 2022.2.4 版本安装包。弹框会提示选择安装路径,我这里直接选择的默认安装路径
C:\Program Files\JetBrains\IntelliJ Pycharm 2022.2.4 , 然后点击 Next 按钮:
然后,勾选 Create Desktop Shortcut 创建 Pycharm 桌面快捷启动方式,以方便后面快速打开 Pycharm,再点击 Next 按钮 :
开始安装 Pycharm 2022.2.4 版本:创建快捷启动图标
点击 Install 按钮,开始安装:
开始安装 Pycharm 2022.2.4 版本:点击 Install 按钮
等待安装完成后,勾选 Run IntellJ Pycharm, 点击 Finish 按钮即运行 Pycharm :
安装 Pycharm 2022.2.4 版本成功
Pycharm 运行成功后,会弹出如下对号框,强制用户需要先登录 JetBrains 账户才能使用:
Pycharm 2022.2.4 版本提示需要先登录 JetBrains 账户
不用管登录的事,点击 Exit 按钮退出对话框,装备开始破解激活。
第四步:破解补丁下载
破解补丁我放置在了网盘中,提供了多个备用链接,以防下载失效。
提示:破解补丁的网盘链接文末获取~
补丁下载成功后,记得先解压 **, 解压后的目录如下, 本文后面所需补丁都在下面标注的这个文件夹中 :
Pycharm 破解补丁下载
点击【方式3】文件夹 , 进入到文件夹 /jetbra,目录如下:
Pycharm 破解补丁文件夹最底层目录
第五步:开始破解
Windows 用户
将上面图示的补丁的所属文件夹 /jetbra 复制电脑某个位置,笔者这里放置到了 D:/ 盘根目录下:
注意: 补丁所属文件夹需单独存放,且放置的路径不要有中文与空格,以免 Pycharm 读取补丁错误。
将 Pycharm 破解补丁放置到 D 盘下
点击进入 /jetbra 补丁目录,再点击进入 /scripts 文件夹,双击执行 install-current-user.vbs 破解脚本:
Pycharm 破解补丁执行脚本
注意:如果执行脚本被安全软件提示有风险拦截,允许执行即可。
Pycharm 破解脚本执行后弹框提示信息
会提示安装补丁需要等待数秒。点击【 确定 】按钮后,过程大概 10 - 30 秒,如看到弹框提示 Done 时,表示激活破解成功:
补丁执行成功后,提示 Done
Mac / Linux 用户
Mac / Linux 系统与上面 Windows 系统一样,需将补丁所属文件 /jetbra 复制到某个路径,且 路径不能包含空格与中文 。
之后,打开终端,进入到 /jetbra/scripts 文件夹, 执行 install.sh 脚本, 命令如下:
sudo bash install.sh
看到提示 Done , 表示激活成功。
Mac/Linux 系统执行破解补丁成功后,提示 Done
部分小伙伴 Mac 系统执行脚本遇到如下错误:
Mac 执行破解脚本报错
解决方法:
可先执行如下命令,再执行脚本:
export LC_COLLATE='C'
export LC_CTYPE='C'
执行脚本,都干了些啥?
  • Windows 用户执行脚本后,脚本会自动在环境变量 -> 用户变量下添加了 Pycharm_VM_OPTIONS 变量,变量值为 /jetbra 文件夹下的 .vmoptions 参数文件绝对路径,如下所示:
    然后,脚本自动在 pycharm.vmoptions 文件中引用了破解补丁 :
    提示: 细心的小伙伴应该也发现了,本文的破解方式与文章开头《第二种 Pycharm 破解方法》的区别在于,这种方式提供了自动化脚本,脚本免去了手动引入补丁的繁琐步骤,一切都由脚本来完成了。
  • Mac / Linux 用户执行脚本后,脚本会自动在当期用户环境变量文件中添加了相关参数文件,Mac / Linux 需重启系统,以确保环境变量生效。
小伙伴们也可自行检查一下,如果没有自动添加这些参数,说明脚本执行没有成功。
第六步:重启 Pycharm
脚本执行成功后,一定要重启 Pycharm ~~
第七步:填入指定激活码完成激活
重新打开 Pycharm 后,复制下面的激活码:
粘贴到输入框内,点击 Activate 按钮,就激活成功了。
输入 Pycharm 破解激活码
PS: 有部分小伙伴反应,重启 Pycharm 填入激活码依然无法激活,重启系统才行,如果有小伙伴遇到这种情况,不妨试试看~
激活成功后,又可以开心的 coding 了 ~
Pycharm 2022.2.4 版本激活破解成功
