金融情绪分析FinBERT
HWCloudAI 发表于 2022/12/05 11:07:21 2022/12/05
【摘要】 FinBERT Example NotebookThis notebooks shows how to train and use the FinBERT pre-trained language model for financial sentiment analysis. 代码和数据下载import osimport moxing as moxmox.file.copy('obs://...
代码和数据下载
import os
mox.file.copy('obs://obs-aigallery-zc/algorithm/finBERT.zip','finBERT.zip')
os.system('unzip finBERT.zip')
Modules
安装依赖库
!pip install textblob
!pip install transformers
!pip install ipywidgets
!pip install torch==1.6.0
!pip install torchvision==0.7.0
from pathlib import Path
import shutil
import os
import logging
import sys
sys.path.append('./finBERT')
# os.chdir('./finBERT')
from textblob import TextBlob
from pprint import pprint
from sklearn.metrics import classification_report
from transformers import AutoModelForSequenceClassification
from finbert.finbert import *
import finbert.utils as tools
%load_ext autoreload
%autoreload 2
project_dir = Path.cwd()/'finBERT'
pd.set_option('max_colwidth', -1)
logging.basicConfig(format = '%(asctime)s - %(levelname)s - %(name)s -   %(message)s',
                    datefmt = '%m/%d/%Y %H:%M:%S',
                    level = logging.ERROR)
Prepare the model
Setting path variables:
  1. lm_path: the path for the pre-trained language model (If vanilla Bert is used then no need to set this one).
  2. cl_path: the path where the classification model is saved.
  3. cl_data_path: the path of the directory that contains the data files of train.csv, validation.csv, test.csv.
In the initialization of bertmodel, we can either use the original pre-trained weights from Google by giving bm = 'bert-base-uncased, or our further pre-trained language model by bm = lm_path
All of the configurations with the model is controlled with the config variable.
lm_path = project_dir/'models'/'language_model'/'finbertTRC2'
cl_path = project_dir/'models'/'classifier_model'/'finbert-sentiment'
cl_data_path = project_dir/'data'/'sentiment_data'
Configuring training parameters
You can find the explanations of the training parameters in the class docsctrings.
# Clean the cl_path
try:
    shutil.rmtree(cl_path)
except:
    pass
bertmodel = AutoModelForSequenceClassification.from_pretrained(lm_path,cache_dir=None, num_labels=3)
config = Config(   data_dir=cl_data_path,
                   bert_model=bertmodel,
                   num_train_epochs=4,
                   model_dir=cl_path,
                   max_seq_length = 48,
                   train_batch_size = 32,
                   learning_rate = 2e-5,
                   output_mode='classification',
                   warm_up_proportion=0.2,
                   local_rank=-1,
                   discriminate=True,
                   gradual_unfreeze=True)
Some weights of the model checkpoint at /home/ma-user/work/finBERT/models/language_model/finbertTRC2 were not used when initializing BertForSequenceClassification: ['cls.seq_relationship.weight', 'cls.predictions.bias', 'cls.predictions.transform.dense.weight', 'cls.predictions.transform.LayerNorm.bias', 'cls.predictions.decoder.weight', 'cls.seq_relationship.bias', 'cls.predictions.transform.dense.bias', 'cls.predictions.transform.LayerNorm.weight']
- This IS expected if you are initializing BertForSequenceClassification from the checkpoint of a model trained on another task or with another architecture (e.g. initializing a BertForSequenceClassification model from a BertForPreTraining model).
- This IS NOT expected if you are initializing BertForSequenceClassification from the checkpoint of a model that you expect to be exactly identical (initializing a BertForSequenceClassification model from a BertForSequenceClassification model).
Some weights of BertForSequenceClassification were not initialized from the model checkpoint at /home/ma-user/work/finBERT/models/language_model/finbertTRC2 and are newly initialized: ['classifier.weight', 'classifier.bias']
You should probably TRAIN this model on a down-stream task to be able to use it for predictions and inference.
finbert is our main class that encapsulates all the functionality. The list of class labels should be given in the prepare_model method call with label_list parameter.
finbert = FinBert(config)
finbert.base_model = 'bert-base-uncased'
finbert.config.discriminate=True
finbert.config.gradual_unfreeze=True
finbert.prepare_model(label_list=['positive','negative','neutral'])
Fine-tune the model
# Get the training examples
train_data = finbert.get_data('train')
model = finbert.create_the_model()
[Optional] Fine-tune only a subset of the model
The variable freeze determines the last layer (out of 12) to be freezed. You can skip this part if you want to fine-tune the whole model.
Important:
Execute this step if you want a shorter training time in the expense of accuracy.
# This is for fine-tuning a subset of the model.
freeze = 6
for param in model.bert.embeddings.parameters():
    param.requires_grad = False
for i in range(freeze):
    for param in model.bert.encoder.layer[i].parameters():
Training
trained_model = finbert.train(train_examples = train_data, model = model)
Test the model
bert.evaluate outputs the DataFrame, where true labels and logit values for each example is given
test_data = finbert.get_data('test')
results = finbert.evaluate(examples=test_data, model=trained_model)
Prepare the classification report
def report(df, cols=['label','prediction','logits']):
    #print('Validation loss:{0:.2f}'.format(metrics['best_validation_loss']))
    cs = CrossEntropyLoss(weight=finbert.class_weights)
    loss = cs(torch.tensor(list(df[cols[2]])),torch.tensor(list(df[cols[0]])))
    print("Loss:{0:.2f}".format(loss))
    print("Accuracy:{0:.2f}".format((df[cols[0]] == df[cols[1]]).sum() / df.shape[0]) )
    print("\nClassification Report:")
    print(classification_report(df[cols[0]], df[cols[1]]))
results['prediction'] = results.predictions.apply(lambda x: np.argmax(x,axis=0))
report(results,cols=['labels','prediction','predictions'])
Get predictions
With the predict function, given a piece of text, we split it into a list of sentences and then predict sentiment for each sentence. The output is written into a dataframe. Predictions are represented in three different columns:
  1. logit: probabilities for each class
  2. prediction: predicted label
  3. sentiment_score: sentiment score calculated as: probability of positive - probability of negative
Below we analyze a paragraph taken out of this article from The Economist. For comparison purposes, we also put the sentiments predicted with TextBlob.
Later that day Apple said it was revising down its earnings expectations in the fourth quarter of 2018, largely because of lower sales and signs of economic weakness in China. The news rapidly infected financial markets. Apple’s share price fell by around 7% in after-hours trading and the decline was extended to more than 10% when the market opened. The dollar fell by 3.7% against the yen in a matter of minutes after the announcement, before rapidly recovering some ground. Asian stockmarkets closed down on January 3rd and European ones opened lower. Yields on government bonds fell as investors fled to the traditional haven in a market storm.
text = "Later that day Apple said it was revising down its earnings expectations in \
the fourth quarter of 2018, largely because of lower sales and signs of economic weakness in China. \
The news rapidly infected financial markets. Apple’s share price fell by around 7% in after-hours \
trading and the decline was extended to more than 10% when the market opened. The dollar fell \
by 3.7% against the yen in a matter of minutes after the announcement, before rapidly recovering \
some ground. Asian stockmarkets closed down on January 3rd and European ones opened lower. \
Yields on government bonds fell as investors fled to the traditional haven in a market storm."
model = AutoModelForSequenceClassification.from_pretrained(cl_path, cache_dir=None, num_labels=3)
import nltk
nltk.download('punkt')
[nltk_data] Downloading package punkt to /home/ma-user/nltk_data...
[nltk_data]   Unzipping tokenizers/punkt.zip.
True
result = predict(text,model)
blob = TextBlob(text)
result['textblob_prediction'] = [sentence.sentiment.polarity for sentence in blob.sentences]
result
print(f'Average sentiment is %.2f.' % (result.sentiment_score.mean()))
Average sentiment is -0.94.
Here is another example
text2 = "Shares in the spin-off of South African e-commerce group Naspers surged more than 25% \
in the first minutes of their market debut in Amsterdam on Wednesday. Bob van Dijk, CEO of \
Naspers and Prosus Group poses at Amsterdam's stock exchange, as Prosus begins trading on the \
Euronext stock exchange in Amsterdam, Netherlands, September 11, 2019. REUTERS/Piroschka van de Wouw \
Prosus comprises Naspers’ global empire of consumer internet assets, with the jewel in the crown a \
31% stake in Chinese tech titan Tencent. There is 'way more demand than is even available, so that’s \
good,' said the CEO of Euronext Amsterdam, Maurice van Tilburg. 'It’s going to be an interesting \
hour of trade after opening this morning.' Euronext had given an indicative price of 58.70 euros \
per share for Prosus, implying a market value of 95.3 billion euros ($105 billion). The shares \
jumped to 76 euros on opening and were trading at 75 euros at 0719 GMT."
result2 = predict(text2,model)
blob = TextBlob(text2)
result2['textblob_prediction'] = [sentence.sentiment.polarity for sentence in blob.sentences]
result2
print(f'Average sentiment is %.2f.' % (result2.sentiment_score.mean()))
