GEE——Classifier confusionMatrix: Property 'type' of feature
此星光明 发表于 2022/12/04 11:41:52 2022/12/04
【摘要】 ​问题:I'm trying to use a classifier to classify the land use of Landsat images, but when I use the function which is "classifier. conflusionMatrix", I get an error as follows: Classifier confusionMa...
问题:
I'm trying to use a classifier to classify the land use of Landsat images, but when I use the function which is "classifier. conflusionMatrix", I get an error as follows: Classifier confusionMatrix: Property 'type' of feature '00000000000000000014_ 0' is missing.  (Error code: 3). I don't know how to correct it. I really need your help to solve this problem. By the way, I finally remembered to share the assets.
我正在尝试使用分类器对 Landsat 图像的土地利用进行分类,但是当我使用“classifier.conflusionMatrix”函数时,出现如下错误:Classifier confusionMatrix: Property 'type' of feature '000000000000000000014_ 0 ' 不见了。 (错误代码:3)。我不知道如何纠正它。我真的需要你的帮助来解决这个问题。对了,我终于记得分享资产了。
This is the link:
https://code.earthengine.google.com/d789c5e1a86b1406dbb93d5d9420d4a5?noload=1
 代码:
var table = ee.FeatureCollection("users/yongxin/henan_bese"),
    table3 = ee.FeatureCollection("users/yongxin/zhengzhou_sample");
//确定区域
var table = ee.FeatureCollection("users/yongxin/henan_bese");
var roi = ee.Geometry.Point([113.663221,34.7568711]);
var sCol = table.filterBounds(roi);
Map.centerObject(sCol,6);
Map.addLayer(sCol,{color:"red"},"zhengzhou");
forest 0
urban 1
paddyrice 2
water 3
crop 4
//iazai加载yangbendianshujv加载样本点数据
var sampleData = ee.FeatureCollection("users/yongxin/zhengzhou_sample");
Map.addLayer(sampleData, {}, "sampleData");
//Landsat8 SR数据去云
function rmCloud(image) {
  var cloudShadowBitMask = (1 << 3);
  var cloudsBitMask = (1 << 5);
  var qa = image.select("pixel_qa");
  var mask = qa.bitwiseAnd(cloudShadowBitMask).eq(0)
                 .and(qa.bitwiseAnd(cloudsBitMask).eq(0));
  return image.updateMask(mask);
//缩放
function scaleImage(image) {
  var time_start = image.get("system:time_start");
  image = image.multiply(0.0001);
  image = image.set("system:time_start", time_start);
  return image;
//NDVI
function NDVI(image) {
  return image.addBands(
    image.normalizedDifference(["B5", "B4"])
         .rename("NDVI"));
//NDWI
function NDWI(image) {
    image.normalizedDifference(["B3", "B5"])
         .rename("NDWI"));
//NDBI
function NDBI(image) {
    image.normalizedDifference(["B6", "B5"])
         .rename("NDBI"));
//加载影像数据(未分类的Landsat影像数据)
var l8Col = ee.ImageCollection("LANDSAT/LC08/C01/T1_SR")
              .filterBounds(sCol)
              .filterDate("2016-1-1", "2017-1-1")
              .map(rmCloud)
              .map(scaleImage)
              .map(NDVI)
              .map(NDWI)
              .map(NDBI);
//DEM
var srtm = ee.Image("USGS/SRTMGL1_003");
var dem = ee.Algorithms.Terrain(srtm);
var elevation = dem.select("elevation");
var slope = dem.select("slope");
//定义波段
var bands = [
  "B1", "B2", "B3", "B4", "B5", "B6", "B7",
  "NDBI", "NDWI", "NDVI","SLOPE", "ELEVATION"
//影像处理
var l8Image = l8Col.median()
                   .addBands(elevation.rename("ELEVATION"))
                   .addBands(slope.rename("SLOPE"))
                   .clip(sCol)
                   .select(bands);
//rgb参数设置
var rgbVisParam = {
  min: 0,
  max: 0.3,
  bands: ["B4", "B3", "B2"]
Map.addLayer(l8Image, rgbVisParam, "l8Image");
//切分生成训练数据和验证数据
sampleData = sampleData.randomColumn('random');
var sample_training = sampleData.filter(ee.Filter.lte("random", 0.7));
var sample_validate  = sampleData.filter(ee.Filter.gt("random", 0.7));
print("sample_training", sample_training);
print("sample_validate", sample_validate);
// //生成监督分类训练使用的样本数据
// var training = l8Image.sampleRegions({
//   collection: sample_training,
//   properties: ["type"],
//   scale: 30
// //生成监督分类验证使用的样本数据
// var validation = l8Image.sampleRegions({
//   collection: sample_validate,
//   scale: 30
// //初始化分类器
// var classifier = ee.Classifier.smileCart().train({
//   features: training,
//   classProperty: "type",
//   inputProperties: bands
//生成监督分类训练使用的样本数据
  properties: ["class"],
  scale: 30
//生成监督分类验证使用的样本数据
  scale: 30
//初始化分类器
  features: training,
  classProperty: "class",
//影像数据调用classify利用训练数据训练得到分类结果
var classified = l8Image.classify(classifier);
//训练结果的混淆矩阵
var trainAccuracy = classifier.confusionMatrix();
//导出训练精度结果CSV
Export.table.toDrive({
  collection: ee.FeatureCollection([
    ee.Feature(null, {
      matrix: trainAccuracy.array(),
      kappa: trainAccuracy.kappa(),
      accuracy: trainAccuracy.accuracy()
  description: "l8TrainConf_zhengzhou",
  folder:"training_zhengzhou",
  fileFormat: "CSV"
//导出影像
var resultImg = classified.clip(sCol).toByte();
resultImg = resultImg.remap([0,1,2,3,4], [1,2,3,4,5]);
Export.image.toAsset({
  image: resultImg,
  description: 'Asset-l8Classifiedmap_zhengzhou',
  assetId: "training_zhengzhou/l8Classifiedmap_zhengzhou",
  region: sCol,
  scale:30,
  crs: "EPSG:4326",
  maxPixels: 1e13
//影像导出
Export.image.toDrive({
  image:resultImg,
  description:'Drive-l8Classifiedmap_zhengzhou',
  fileNamePrefix: "l8Classifiedmap_zhengzhou",
  region: sCol,
  scale:30,
  crs: "EPSG:4326",
  maxPixels:1e13
我们根据提示可以看出,文件中不存在属性,所以我们需要查看我们打印或者输出的结果中到底有没有这个属性,可以看到这个属性中并没有“type”属性。我们要注意的是这里我们所需的不是矢量文件中每个属性,这是值得注意的,这里选择的就是分类后产生的新的分类属性。
 矢量中的类型“type”代表的并不是属性列表,而是表明矢量类型就是矢量。
需要修改的代码:
//生成监督分类训练使用的样本数据
  scale: 30
//生成监督分类验证使用的样本数据
  scale: 30
//初始化分类器
  features: training,
修改后成功的下载结果
